electric generators - Diesel Forum - TheDieselStop.com
Old 12-08-2007, 12:51 AM   #1 (permalink)
88beast's Avatar
electric generators
what kind of electric generators for houses is there and are there any that will be a good ac gen? or will i need a dc converter?
anything will help and if you could explain the diferencce between an ac and dc genset taht would be great thanks tom
88 F-250 body,550 rear frame setup, 7.3 idi, back up camera, class 5 bumper hitch welded to frame and gusseted, front mount hitch and off road lights,93 front clip, headache rack, 37" humvee tires, ac power converter,factory buckets from quadcab, power windows and locks,cobra 29 cb w/ 102" whip, high lift jack behind seat, toolbox for the junk, visor, running lights, huge front bumper, oba,
in progress western style mirrors, holset turbo, airhorns, and some other goodies
88beast is offline
Old 12-08-2007, 01:47 AM   #2 (permalink)
F350Lariat's Avatar
Re: electric generators
All kinds of generators:
Standbypermanently installed with auto transfer ability) that are using propane or natural gas. Diesel are the most expensive. Gas standby units are harder to find. The bottom of the barrel standby is Generac (Home Depot) and air cooled. The more expensive units are water cooled (diesel). Cheapest unit is 7 Kw ($1899), 10 Kw unit ($2600) and include the auto transfer GENSET unit (also limited in the number of breakers).
Portable (gas or diesel, but most are gas): You can get a gas portable generator up to about 17 Kw but very expensive and comparable to the cheaper Generac standby units (about $3000). Portables over 10 Kw using have a 50 Amp plug vice 30 Amp plug.
Almost all gas portable generators under 10 Kw have 30 Amp (120/240 VAC) plugs to connect to your house. Thus, the unit can power a maximum of 7.2 KW (30 A x 240 Volts = 7.2 Kw), thus the extra power is money waster unless you also pull extension cords in addition to the main plug.
GENSET manual transfer switches are a complete waste of money and severely restrict your ability to manage loads. For a 30 Amp plug, I could not find anything bigger than 100 Amp with 12 circuit breakers (2 were 30 amp (240V) leaving 10 individual 120 V breakers).
I called the electrician who wired my new home. He installed a new cover panel with a Mechanical Interlock Transfer switch and 30 Amp generator plugged connected to my main panel (200 Amp). Now, I turn off the main 200 Amp breaker, move the slide cover up to lock the breaker in OFF, turn on the Mechanical Interlock Switch located in the panel and plug my 30 Amp cord to the box and generator. I can power any load in my house using the original load breakers in the panel. You can selectively turn on and off loads to manage to wattage so that you do not exceed 7.2 Kw.
The mechanical transfer switch option is also significantly cheaper to install. My local Costco is selling a 7 Kw Honda Power Boss portable for $999. I purchased a Troy-Bilt 8000 Kw portable for $1159.
2004 Ford F350 Crew Cab
4WD Lariat 6.0L PSD Torqshift SRW
Med Wedgewood Blue / Arizona Beige
Tuff Country 1.5" Leveling Kit ... Hardcover Tonneau
Pro-Flap Mud Guards ... Toyo M55 LT285/75R16 Range E
GOS Racing Headlight Harness with Silverstar bulbs
Factory Ordered and Delivered: Feb 7, 2004.
<movieshow2003 at yahoo.com>
F350Lariat is offline
Old 12-08-2007, 06:13 AM   #3 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Quote:</div><div class="ubbcode-body">The mechanical transfer switch option is also significantly cheaper to install. My local Costco is selling a 7 Kw Honda Power Boss portable for $999. I purchased a Troy-Bilt 8000 Kw portable for $1159.
</div></div>
Good advice.
Unless you lose power a lot, a built-in gen-set is hardly necessary and quite restrictive. The biggest advantage to one is they can run off of natural gas so when you do lose power, bang it fires up without you doing anything.
I would spend a bit more money and get a Honda or Yamaha as those Powerboss generators are crap.
checkthisout is offline
Old 12-08-2007, 10:59 AM   #4 (permalink)
88beast's Avatar
well im planning to make a plan for my father hes int ofree power and he thinks there is a good way to power it off the water main or something similar maybe a creek and i wanted to know what would be best for plugging into the box then? i think i will go with a standby
and a 30-40 amp service is needed
other than look for honda or yamaha any good ones?
and can you tell me where to find the generator iteself not the frame and engine with it? im trying looking up part#s today but i googled and nothing
88beast is offline
Old 12-08-2007, 10:39 PM   #5 (permalink)
You can get just the generator motor from Northern tool or harbor freight
2006 F250 CC FX4 5.4L 3.73 gears, 2007 Palomino Bronco B1251 Truck Camper, 2002 Carolina Skiff DLX16 25hp Yamaha 4 stroke,2004 Kawasaki Bayou 250, 2000 Kawasaki Bayou 220
NEG297F is offline
Old 12-08-2007, 11:27 PM   #6 (permalink)
88beast's Avatar
ok thanks ill stop out tomorrow to look
88beast is offline
Old 12-09-2007, 12:54 PM   #7 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Quote:</div><div class="ubbcode-body">well im planning to make a plan for my father hes int ofree power and he thinks there is a good way to power it off the water main or something similar maybe a creek and i wanted to know what would be best for plugging into the box then? </div></div>
If this is the case, you need to google "hydro power". You may also want to research "off grid" power solutions. You will need to get a water right from you state. Using a "water main" do you mean city water or the main from your well?
There is really no such thing as "free power". Its going to cost some money to generate it somehow. If your have a water source on your property that has about 50 to 60' of head, you might get a smallish system that would power a house. You'll most likely be generating DC, so you'll need storage (batteries) and a converter to get AC to power appliances, or change everything over to DC, much like a trailer.
If you are looking a generator that uses a fuel of some sort, take the fuel into account too. Each fuel has it's own benefits and drawbacks. One neat thing you might look into is a turbine co-gen if you're thinking of propane, natural gas or diesel/kerosene.
OMC
OMCUSNR is offline
Old 12-09-2007, 08:08 PM   #8 (permalink)
My Photos: (17)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: F350Lariat</div><div class="ubbcode-body">I called the electrician who wired my new home. He installed a new cover panel with a Mechanical Interlock Transfer switch and 30 Amp generator plugged connected to my main panel (200 Amp). Now, I turn off the main 200 Amp breaker, move the slide cover up to lock the breaker in OFF, turn on the Mechanical Interlock Switch located in the panel and plug my 30 Amp cord to the box and generator. I can power any load in my house using the original load breakers in the panel. You can selectively turn on and off loads to manage to wattage so that you do not exceed 7.2 Kw. </div></div>
So how are you disconnecting the neutral from the power company grid? Turning off your main breaker only disconnects the two hot wires but not the neutral. Did your electrician have a permit and have the work inspected?
In essence, you are just backfeeding your panel from a generator and using the 200A main breaker as a disconnect. In most areas this is not to code. You need to sever all connections with the power company grid (all hots and neutrals). What can happen is that you have a short to ground, but your grounding system isn't up to snuff for some reason so the short travels back up the neutral searching for ground, goes through the transformer at your pole, gets upconverted to 10,000v (or whatever) and can kill a lineman working on the poles. Granted the breaker on your gen may trip before that happens since you may end up trying to feed your neighborhood...but it's still a safety issue.
If you are disconnecting the neutral then pardon my post...but I think it's important that people understand that when running a generator when the power is out and using the main breaker only to disconnect yourself from the power company grid...then that is not legal in most areas. Some people pull the meter which will disconnect the two hots and the neutral...but if you do that beware the wrath of the power company...best to call them first.
Shimon Mor
1985 F250XL, 6.9L, C6, 4x4 (BW1345), Dana 44HD front, Dana 70 LS 3.54 rear, 190,000 miles, Rebuilt longblock (88,000 miles), ARP studs, electric fuel pump, Edelbrock Performer IAS shocks, Velvet-Ride Shackles, Firestone Airbags all around, Transfer Flow fillnecks, lots of gauges, Line-X, Jordon Brake Controller, B&M Stacked Plate Transmission Cooler, TCI Aluminum Transmission Pan, Banks Sidewinder (wastegated)
shimonmor is offline
Old 12-09-2007, 10:56 PM   #9 (permalink)
F350Lariat's Avatar
Yes, the system was inspected by the county, and it does isolate the main grid from the generator and my house.
Old 12-09-2007, 11:54 PM   #10 (permalink)
Even if you pull the meter, the neutral is not disconnected, single phase or three phase. Even the single phase and three phase double pole/ double throw safety switches(transfer swithces) do not disconnect the neutral.
Curt
1997 F350 cc/lb, 4x4, E4OD, 4.10, Pyro/Trans Temp/Boost Gauges. Torn apart- installing h2e, sd intercooler, bronco tank, bosch 044 fuel pump, dahl 150, regulated return, big oil, b codes.
CEMeyer is offline
Old 12-10-2007, 12:44 AM   #11 (permalink)
I have a Kubota 5500 watt. It is every bit as good as the Honda construction wise, as well as the noise level. It is VERY good.
03 F-250xlt 6.0, SOLD April 2010! Replaced by an 07 GMC Yukon XL, and a 99 F350 crew cab, long bed 4x4, 6 speed. 69 Shelby GT500, 428 Cobra Jet, 4 speed toploader.
67 Fairlane 500, 347 Stroker, AOD trans, 3.25 rear end... work in progress. I am looking for parts that I thought I had so carefully put away...............
Work "Truck" 110 foot, 1999 Spartan/ LTI quint, Detroit Series 60, Allison auto. Work "Engine" 06 Pierce Arrow, Detroit Series 60, 475 horse, Allison Auto. Work Medic unit, 08 E450 6.0 by Northstar.
shelbyandadiesel is offline
