good question? I would like to know the same. I would like to buy a used F450 but I cannot find a site that has values for used ones.
Late 99 SD PS CC SB 4x4 Lariat. 7.3l TS 6xchip Stock-140hp , Banks 6gun, Full Banks Gauges, 4"SS turbo back exhaust, UMP Intake w/ Donaldson Filter, Auburn posi F&R 3.73, ATS Trans W/ 5Star converter and CoPilot, 18k trans cooler, Dynatrac FreeSpin front hub kit, ITP oil X over, ITP boost regulator, Aero Fuel Tanks Replacement 55 Gallon tank, New timing cover,oil pan,oil cooler, water pump,turbo petastel, reman HPOP, new fuel filter housing, slotted brakes all 4 corners W/ Ceramic pads, Adjustable trac-bar, Front 1.5" level kit only. 188,000 miles 10/1/09 Best mpg 27.3.. (Current Highway MPG 19.6 unloaded and going over the Grapevine 2X's on a 781 mile trip, 39.7gal, 3/4 tank of fuel used  11/09)
Early 99 CC LB 2WD Manual 6....Stock 218k (11/09) and running strong, only repairs Clutch, water pump, alternator. K&N FIPK since 36k and loving it!
2006 CC LB 4WD Lariat 6.0l 5R110 Stock 137k (12/09) "Dad's" 3 injectors and GP harness(12/09)
