Other Technical QuestionsDiscussion of other technical topics. Please see the sticky post at the top of the thread listing for specific rules. The rules for this forum are more restrictive than they have been in the past.
For Christmas, my family got me a roller to make "logs" out of newspaper. I remember reading years ago that you should only burn newspaper without colored ink, because the colored ink had lead. Now there is a lot more colored ink, so I'm hoping there is less lead. Does anybody have any tips on burning paper for heat?
Charlie Brown, North Alabama
'97 F-350 Crew Cab, 5 speed, Dually. Pretty Stock. Traded
'07 GMC Sierra 1500 Crew Cab
heat go for it if the chimney is working itll all go out and if you do burn all this lead inked paper for whe whole winter every year it wont do anything to the enviroment because of such low levels
yes it has been reduced
but think of the children they shouldnt be in the fireplace anyway
and id usereal wood for cooking no paper cause of other chemicals in ink and not too good taste
88 F-250 body,550 rear frame setup, 7.3 idi, back up camera, class 5 bumper hitch welded to frame and gusseted, front mount hitch and off road lights,93 front clip, headache rack, 37" humvee tires, ac power converter,factory buckets from quadcab, power windows and locks,cobra 29 cb w/ 102" whip, high lift jack behind seat, toolbox for the junk, visor, running lights, huge front bumper, oba,
in progress western style mirrors, holset turbo, airhorns, and some other goodies
I'd be surprised if there is still lead in newspaper ink. Not a good ingredient for something you touch. It was removed from paint long ago, don't see why it would still be allowed in ink.
2000 F250 CC, PSD, Lariat, 4X4, DP Tuner 80HP PCM, AIS air filter, 4" Magnaflow SS Exhaust, Isspro Overhead Gauges, In-tank mod, Homemade CCV, AIH delete
2004 Honda Pilot EX-L for the wifey
2011 Hyundai Sonata 2.0T
2003 Yamaha Kodiak 450
"Extremism in the defense of liberty is no vice. And moderation in the pursuit of justice is no virtue." - Barry Goldwater
"They that can give up essential liberty to obtain a little temporary safety
deserve neither liberty nor safety." Benjamin Franklin
"What you want is irrelevant, what you have choosen is at hand." - Mr. Spock
i tried one of those 20 years ago. Made smoke, big mess, no heat. Now I have a wood stove at the cabin. If I was going to burn wood at this house I would use an insert and still burn wood. New houses with a real fireplace are not allowed here to be built. I have an older place so I stll can burn wood if I want to. I like the looks of the inserts also.
95 F250,XLT, 4WD, Auto Trans,bbshimmed,synthetic trans oil,4:10 gears ,Truck Trunk ,Nerf Bars ,crome Mud flaps, Aux. trans cooler, front diff. drain plug. External trans.filter, trimmed snorkel. American wheels water temp guage, front fuel tank mod,Warn Manual hubs,Putman class 4 hitch 189k mi.
It is said if you sit by the river and watch the water flow by long enough, your enemies will pass by. This I believe to be true. It is also possible to watch your loved ones pass by as well.
Wife Candi 08/14/07 missing her always
Newspaper ink is made from vegetable oil these days instead of solvent based inks, that is why it smudges everywhere. Most of the lead in older printings came from the press plates that were made with a lot of lead. The color inks these days are made from mostly from dyes as compared to pigments, so there is almost no (Not None) heavy metals.
One cavet to all of this is the glossy advertisement inserts that your Sunday edition is full of. Those do use high solvent inks and I am not sure about the heavy metal content. However, as had been stated above, it will all go up the chimney and the amounts you are talking about are insignificant.
Marc
2000 Excursion Ltd 2WD, Build Date 9/30/99, Oxford White, Medium Parchment Leather, 6 disk CD Changer, 3.73 LS, Magnum Deflecta-Shield, Vent Shades Ford Rear Air Deflector, AC Mod, Home Made Tymar, More to come sooner or later!
Let us put an end, once and for all, to this discussion of what a good man should be - and be one. -Marcus Aurelius-
Politics is the art of looking for trouble, finding it, misdiagnosing it, and then misapplying the wrong remedies. -Groucho Marx-
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Gone Fishen</div><div class="ubbcode-body">i tried one of those 20 years ago. Made smoke, big mess, no heat. Now I have a wood stove at the cabin. If I was going to burn wood at this house I would use an insert and still burn wood. New houses with a real fireplace are not allowed here to be built. I have an older place so I stll can burn wood if I want to. I like the looks of the inserts also. </div></div>
The newspaper logs would be good for starting a wood fire but I wouldn't use them for heat. I got an insert from Buck Stove Corp. and man, this thing will run you out of the house when I feed it some good red or white oak. I have to watch using too much paper to start it or the ashes will plug the catalyst.
The insert works great; highest gas bill so far has been $49 - all the wood is free if you don't mind sweating a bit to cut it.
2003 F250 XLT CC Long Bed 4x4, 6.0 w/Auto
You know the old saying: If you cut your own wood, it warms you twice.
Friend of mine in Utah would stop at several places on the way home and pick up old smashed pallets for wood. Price was really good to.
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Dualie</div><div class="ubbcode-body">just be warned clean out the nails regularly. Otherwise you get a nasty untangleable mess of nails. </div></div>
How cool is that? Modern art. The kids burned up all the old pallets in the New Year's Eve bon fire.
Remeber that most pallets are made of Pine. Pine is one of the softer woods out there and will leave more creosote on your chimney liner. You will need to clean your chimney more often to prevent chimney fires. I would advise against burning pallets.
Happy 2008!
2005 F-250 Supercab 4x4 Lariat long bed 6 speed, Vegistroke V3 WVO system, integrated brake controller, upfitter switches, TTM, South Texas Outfitters custom front end replacement, Whelen Liberty LED lightbar, Whelen Dominator LED front bar, hidden front strobes, rear LED's and strobes, Rhino liner, Whelen 200 watt siren, Havis Consolidator console, and other hidden goodies. Pictures are in "Shoebox" album. http://community.webshots.com/user/vtfireftr
