Ford F650 with 429 - Diesel Forum - TheDieselStop.com
Old 12-21-2007, 10:38 PM   #1 (permalink)
Ford F650 with 429
Can i put a 460 from a car in a F 650 that has a 429 in it, The 429 has a front mount and the 460 has side motor mount but will the front mount bolt on to the 460 block?
1997 f350 4x4 7.3PS 5 sp 50200 miles bought new in 96. 1705 Superchips.Cat extended life coolant.
1973 pa28-235
03 peterbilt 379 C16 CAT
15265 is offline
Old 12-22-2007, 11:54 PM   #2 (permalink)
Re: Ford F650 with 429
This would probably get a better response if posted in the F650 forums here.
'01 PSD F350/SC Lariat 6x6 Hercules
"Save the Planet. Its the only one with Chocolate"
h2guy is offline
Old 12-23-2007, 12:03 AM   #3 (permalink)
429/460 blocks are the same.
1992 F350 Crew Cab 4x4 7.3l IDI E4OD No Turbo
1993 F350 Crew Cab 4x4 7.3l IDI E4OD No Turbo
1990 F250 Super Cab 2x4 7.3l IDI E4OD Utility bed
1987 E250 Quadravan 4x4 6.9 IDI C6 Banks Turbo, Gearvendor, and U.S. Gear Exhaust Brake
DragRag is offline
Old 12-23-2007, 12:41 AM   #4 (permalink)
bearings, main & rods, will be different.
Crank will likely be different.
NRA member...GUN(s) Owner...Bluegrass performer and festival promoter. Now have an International 9400 Eagle, Cummins N14, 10 speed, 72" mid-rise sleeper. Pulling a 45' Teton 4 axle, triple slide.
http://www.youtube.com/watch?v=GqI14CfACjU (I'm the old guy singing lead, w/beard)
http://www.myspace.com/trustingheartaz featuring
4 more original songs...one traditional standard (Fields Have Turned Brown).
Now fighting the big Kidney Cancer, Stage IV.
Prayers, attitude and the Mayo Clinic!
bilbo is offline
Old 12-23-2007, 01:52 PM   #5 (permalink)
What truck 429 used in 1982 + heavy trucks is not the same engine as the car 429 used 1973 and before. They are in the same engine series but I would venture to guess that parts interchange is limited. That would extend to the car - based 460.
*ASE Master Certified, Medium & Heavy Trucks*
Mr_Roboto is offline
Old 12-23-2007, 08:16 PM   #6 (permalink)
88beast's Avatar
they are too different to bolt in but if you have a welder just make a place for the side mounts to go
88 F-250 body,550 rear frame setup, 7.3 idi, back up camera, class 5 bumper hitch welded to frame and gusseted, front mount hitch and off road lights,93 front clip, headache rack, 37" humvee tires, ac power converter,factory buckets from quadcab, power windows and locks,cobra 29 cb w/ 102" whip, high lift jack behind seat, toolbox for the junk, visor, running lights, huge front bumper, oba,
in progress western style mirrors, holset turbo, airhorns, and some other goodies
88beast is offline
Old 12-27-2007, 01:46 PM   #7 (permalink)
i drove a f-700 with a 429 in it with airbrakes that thing was nothing but a gas hog no power what soever
92 F-250 with luk clutch, got 304,000 miles out of old motor, now have IDI out of a 94 With factory turbo. Bought and installed ATS Exhuast housing, wastegate, downpipe. Turned up pump electric fuel pump. Runs like a bat out of hell.
andre7910 is offline
Old 12-27-2007, 05:58 PM   #8 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: andre7910</div><div class="ubbcode-body">i drove a f-700 with a 429 in it with airbrakes that thing was nothing but a gas hog no power what soever </div></div>
Ditto: 4-5 mpg on a GOOD day!
Too much junk/toys to mention, ever changing due to too getting bored too quickly. I need a 10 step program!
Want to call? I'm in the book. Want to argue....First explain the square root of negative one....lol
roofeditor is offline
Old 12-27-2007, 06:29 PM   #9 (permalink)
Mine in my Torino is gallons per hour verses MPG. Trip to town and back is 1/4 tank, and I am only 6 miles from town. But a 12 to 1 roller motor will chew up the fuel fast.
DragRag is offline
Old 12-27-2007, 10:20 PM   #10 (permalink)
FleetMan's Avatar
15265,
If you can successfully mate the transmission to the engine, go ahead with the swap. You can make the engine fit. I once had a truck 429 replaced with an automobile 428 from the junk yard and got several more good years of service from the truck involved.
Early 99 F250 PSD (XLE4) XLT, Extended Cab, Short Bed, 4X2, BTS Trans/TC, 3.73 Limited Slip, Transfer Flow 48 Gal. Mid-Ship Tank
Western WA - Member since August 2001
FleetMan is online now
Old 12-28-2007, 12:50 AM   #11 (permalink)
To mix it up even more I have heard the Lincoln 460's are different from the Ford 460's, they cannot be used in a lot of swaps due to some odd way they are set up.
Just another thing to maybe look at.
early 99 F350 4x4
DieselDeaf is offline
Old 12-28-2007, 10:56 AM   #12 (permalink)
Our FPD has a F650 tanker with a 2,000 gallon tank and a 429 / 4spd Allison Auto combination. It is one of the least enjoyable vehicles I have ever driven. With a full tank of water, it will barely, barely make 55 mph on flat ground, and will not hold even 40 mph up the slightest of hills.
FarmDiesel is offline
Old 12-28-2007, 11:59 AM   #13 (permalink)
MarkEkberg's Avatar
My Photos: (13)
Going with a 460 is not going to help it any. With power or mpg.
UPDATED 1/1/09 Replace so far. 1 LUK flywheel+clutch, 2 thermostats, 2 set of brakes, 1 set of calipers, 5 CPS, 3 sets of tires, 2 Transfer pumps, 1 Injector modual, 1 Computer, 2 Alt, 2 sets of batteries, 1 Water pump, 6 Belts, 1 PS hose, 2 Sets ball joints, 2 set u-joints, 2 carrier bearing, 2 Speed sensors, 1 oil pres sender, 1 temp sender, 4 sets of e-break cables, 1 front fuel tank, 2 rear fuel tanks, 2 set of glow plugs, 7 Glow plug relays, Oil galley o-rings, Turbo pedistal o-rings, EBPV o-rings, 3 sets of Injector O-rings, 1 Vac-pump, 1 new carpet, 1 total paint job.Total $$$ in repairs v/s miles driven = 4.6 cents per mile. Add fuel to that it jumps to 16.5 cents per mile over the life of the truck.
MarkEkberg is offline
Old 12-28-2007, 12:43 PM   #14 (permalink)
Keep in mind the truck 429 is a custom engine - designed for heavy truck use. Swapping to a car engine - even a larger one - will probably result in lower useable power and a shorter life span.
Old 12-30-2007, 11:10 AM   #15 (permalink)
429(370 is worse) is a gas drinking slug, I would rather a 300 6 cylinder. I had the displeasure of driving an F-800 with a 12 foot plow, and a 10 yard sander, and 10 gears wern't enough. I say find a nice diesel that needs a home and let it live where the gas hog was.
2000 F-350 4X4 Diesel Welding Rig
70' Lincoln SA200 powered by a Red Seal Continental
"Weld It And You Wont Be Screwed"
bigblue250 is offline
