Garage door opener timer - Diesel Forum - TheDieselStop.com
Old 12-09-2007, 07:34 PM   #1 (permalink)
MGX
Wife and older son can not remember to close the garage door about half the time. They drive off and even come in and leave it up at all hours. Not only does it create a security issue, it also wastes heating and AC. Is there some kind of timer that can be added that will automatically close the door after a couple of minutes? It is a mid-range Genie .
Thanks,
Marc
Marc
2000 Excursion Ltd 2WD, Build Date 9/30/99, Oxford White, Medium Parchment Leather, 6 disk CD Changer, 3.73 LS, Magnum Deflecta-Shield, Vent Shades Ford Rear Air Deflector, AC Mod, Home Made Tymar, More to come sooner or later!
Let us put an end, once and for all, to this discussion of what a good man should be - and be one. -Marcus Aurelius-
Politics is the art of looking for trouble, finding it, misdiagnosing it, and then misapplying the wrong remedies. -Groucho Marx-
MGX is offline
Old 12-09-2007, 07:55 PM   #2 (permalink)
My Photos: (17)
Re: Garage door opener timer
Use a time delay relay that is activated when the garage door is opened, set your time delay (30 minutes) and then it closes the garage.
Shimon Mor
1985 F250XL, 6.9L, C6, 4x4 (BW1345), Dana 44HD front, Dana 70 LS 3.54 rear, 190,000 miles, Rebuilt longblock (88,000 miles), ARP studs, electric fuel pump, Edelbrock Performer IAS shocks, Velvet-Ride Shackles, Firestone Airbags all around, Transfer Flow fillnecks, lots of gauges, Line-X, Jordon Brake Controller, B&M Stacked Plate Transmission Cooler, TCI Aluminum Transmission Pan, Banks Sidewinder (wastegated)
shimonmor is offline
Old 12-09-2007, 09:06 PM   #3 (permalink)
weasel79's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: shimonmor</div><div class="ubbcode-body">Use a time delay relay that is activated when the garage door is opened, set your time delay (30 minutes) and then it closes the garage. </div></div>
Does that go in the signal to close wire? That relay works off of 120v according to that page. Is the signal wire 120v? Just curious. I would like to get one.
2003 F-250SD XLT X-Cab short box March 03 6.0L Torque shift, manual 4x4 superwinch hubs, 121,000 miles,315/75/16 BF Goodrich mud terrains, autometer boost/fuel psi/tranny temp, AFE 4" straight pipe, tire clearance and guage photos
weasel79 is offline
Old 12-09-2007, 10:11 PM   #4 (permalink)
88beast's Avatar
if you do that make sure you have one of those object in the way sensors not motion but something in the way so if you have the truck parked half out while changing the air filter whatever it does not close on your truck
88 F-250 body,550 rear frame setup, 7.3 idi, back up camera, class 5 bumper hitch welded to frame and gusseted, front mount hitch and off road lights,93 front clip, headache rack, 37" humvee tires, ac power converter,factory buckets from quadcab, power windows and locks,cobra 29 cb w/ 102" whip, high lift jack behind seat, toolbox for the junk, visor, running lights, huge front bumper, oba,
in progress western style mirrors, holset turbo, airhorns, and some other goodies
88beast is offline
