Go Back   Diesel Forum - The Diesel Stop.com > Other Topics > Other Technical Questions
Other Technical Questions Discussion of other technical topics. Please see the sticky post at the top of the thread listing for specific rules. The rules for this forum are more restrictive than they have been in the past. Topics will expire automatically in 60 days.
Old 09-09-2008, 10:46 AM   #1 (permalink)
Gas tank sealant?
I fabbed up a gas for a sport bike/ quad project I am making. I made the tank out of steel and welded the seams. Now that I put gas in it I have found some leaks in spots I can no longer reach with a welder. Does anyone know of some kind of sealant that I could apply to areas inside the tank to take care of this?
Thanks,
-Rob
'94 F250 XLT 7.3L. Turbo Diesel 4X4 "OFF ROAD" package, X-Cab, 4.10 grears, Now a 5 speed, original IP, just did injectors,"Wallace mod" 3.5" turbo outlet housing and 3.5" DP and straight piped exhaust, 113K on the clock. Repainted it black. Ispro pyro and boost gauges, turned up pump.
ClassicFordGuy is offline
Old 09-09-2008, 12:31 PM   #2 (permalink)
Supporting Member
bugman's Avatar
My Photos: (15)
There is one or two types out there but I can't remember the names of them. I would go down to your local cycle shop and ask them. You poor it in the tank and then swirll the tank around to get coverage and then let it dry. It is made for gas tanks.
Jim
96 F250 PS XLT 4X4 long box, 5sp,4.10, manual hubs,pyro+boost guages,Dark Toumaline, add a leaf,Dale's TYMAR,and HX hose, downpipe, coolant filter with coolant eye
bugman is offline
Old 09-09-2008, 03:00 PM   #3 (permalink)
POR 15
POR-15 Inc.
PORPATCH-POR-15 Inc.
SUPER STARTER KIT-POR-15 Inc.
Works great, just read ALL the instructions. The other product is called Kream. Works good also, (or so I've been told) but has some nasty fumes whereas POR can be used inside without special ventilation.
97 F-250 Crewcab,4X4, 4.10 gears, coolant filter, 203 deg. thermostat, coolant eye, Bilsteins, 255/85R16s.
00 Ural BC-65.
97 Honda Foreman.
"A little rebellion, now and then, is a good thing." Thomas Jefferson
pigdog is offline
Old 09-09-2008, 04:04 PM   #4 (permalink)
I didn't know por15 would survive in gas....I guess it should, It stayed on my hands for a month. I have a gallon of por15, theoreticaly I can just use many coats of that instead of buying the tube of thick por15 right?
Its between that and some putty made by permatex for fixing leaky tanks. Should I just try coating the entire inside of the tank with POR15?
-Rob
Old 09-10-2008, 10:57 PM   #5 (permalink)
-Rob
I've been running it in my gas tank of my Ural for over a year now. No Problems. If you go to their website, you can read a PDF of the instructions. It talks about leaks and what the normal stuff may or may not take care of. Besides being rusty, my tank had a small crack at the pet****. I used a little on the outside at the crack and then did the whole tank.
As for the whole tank, if it is metal, might as well do it and save yourself a clogged carb later.
It really went well and I highly recommend the tank kit. I've never used the putty, but i have a leaky oil pan and rear fuel tank on the truck and I'm thinking of trying the putty on both.
00 Ural BC-65.
97 Honda Foreman.
pigdog is offline
Old 09-21-2008, 12:35 PM   #6 (permalink)
Well I poured some regular por15 in the tank and sloshed it around. Did that about a week ago, one aplication took care of all my leaks and the tank works great now. That stuff is great. Thanks for the help guys.
-Rob
