Browse ebay or Car Audio Video - Car Subwoofers - Car Amplifiers and Speakers , look for an amp with 150-300wrms output at the rated ohms impedance of your subwoofer. Something like this:
Power Acoustik Reactor REACT1-1100 (react11100) Mono Subwoofer Amps Car Amplifiers - Sonic Electronix Don't need to spend a ton of money.
A slightly more powerful amp won't clip/distort but you have to watch the volume knob so you don't push the sub past it's limits.
My first sub was a 10" in a 90' Ranger. Wanted more bass after a week. LOL
If you're running off a factory deck and hooking into rear speakers then get an amp that has hi-level speaker inputs. If not any amp will do. Look for class-D (higher efficiency than traditional class A-B designs). Need to run at least 8gauge power cables from the battery to power it.
2001 F250 4x4 crew lariat 7.3L auto, clear corners & taillights, DP Tuner F5 no-start/valet/20tow/80econo/140aggressive, PI Stallion converter, modded valve body, ISSPRO egt/boost/pyro, foil delete, 6" stainless tip, Walker 21470 BTM muffler, dieselsite boots & coolant filter & HX crossover, Fleetguard LF9027 or LF3630 hi-cap oil filter, Rotella T 15w40, DIY Tymar, billet grill, line-x bedliner, bug deflector, tint, 08' alum diff cover, Xtreme XT855 reverse lights, 1500w inverter, Tekonsha Primus, EQX, Epicenter, Autotek MM4000.1D, Audiobahn AWT12X, 2/0 cables, JVC KD-AVX44 El Kameleon dvd deck.
