Go Back   Diesel Forum - The Diesel Stop.com > Other Topics > Other Technical Questions
Other Technical Questions Discussion of other technical topics. Please see the sticky post at the top of the thread listing for specific rules. The rules for this forum are more restrictive than they have been in the past. Topics will expire automatically in 60 days.
Old 02-03-2008, 05:08 PM   #1 (permalink)
My Photos: (5)
How do I resurrect my black and decker firestorm 18v batteries?
I hear there is a way to get these batteries to hold a charge again. Any idea? I am trying to avoid dropping down 50 bucks in batteries. Thanks
2002 F-250, PSD 6-speed, CC, short bed, 4X4, Toreador Red w/ Silver accent, A.R.E mx cap, Weld Super Single II and 33s in the summer, x-springs, F-350 blocks and badges, AIC, proflaps, ITP intank mod, AirDog with 3 micron filter, isspro guages and TTM, scangauge, husky liners, alarm, xm stereo,stull 5399-p grille, centramatics, ccv mod, AIS Air Filter, Southbend CON O, Detroit Truetrac LSD, coolant filter, 203 stat with billet housing, blackcloud intake heater plug/boost fitting, reese titan hitch, fabcraft PTO cover/temp sender port, prodigy brake controller, ITP Boost Annihalator, oilguard bypass filter, Mag-Hytec rear dif, bilsteins, hellwig rear stabilizer bar, ATS housing, non-ebpv pedistal and exhaust flange, magnaflow 3.5dp exhaust, ITP reg return, turbomaster wastegate controller, and ceramic coated bellowed up pipes, PHP 50t and 80p, currently 85,100 miles. truck Pictures
clydesdale is offline
Old 02-03-2008, 05:27 PM   #2 (permalink)
i have the same question for makita 14.4 batteries. they are at the point of charging them and after resting for a day there is little or no charge.
NOVAPS MEMBER
Scott
Y2K 350 WEDGEWOOD BLUE/HARVEST GOLD CC DRW LB AUTO 4X4 ESOF LARIAT AMSOIL DUAL BYPASS, AMSOIL FLUIDS, REESE 20K FIFTH WHEEL HITCH, BD BRAKELOC, BD PRESSURELOC, PRODIGY P3 BRAKE CONTROL, RANCHO 9000'S PULLING 2002 CEDARCREEK 362BBS, 2002 BRIMAR 5 TON DUMP OR 2006 APPALACHIAN 24' GOOSENECK DECK OVER.
bgirls is offline
Old 02-03-2008, 06:37 PM   #3 (permalink)
LC
LC's Avatar
Send a message via AIM to LC
I have been told that Batteries Plus may be able to rebuild them. Don't quote me on that however. I haven't taken mine in yet.
Antiquis temporibus, nati tibi similes in rupibus ventosissimis exponebantur ad necem. (In the good old days, children like you were left to perish on windswept crags.)
LC is offline
Old 02-03-2008, 06:45 PM   #4 (permalink)
I've tried to run the batteries flat; clamping the trigger on, then recharging and then completely discharging again, it's never made a difference - when the battery stops holding a good long charge it's time for new batteries, however the replacement batteries often cost more than the drill did originally.
'93 F-250, - most original at 252K miles, rebuilt E4OD 220K miles
Greenie is offline
Old 02-04-2008, 03:01 AM   #5 (permalink)
Originally Posted by Greenie View Post
I've tried to run the batteries flat; clamping the trigger on, then recharging ...
For reconditioning to be successful, it has to be on a cell-by-cell basis. You can't do the entire battery pack at once.
When a dormant cell won't hold a charge overnight, it's all but certain that it's suffering from dendrite growth.
(see Can you shock a cell phone battery? )
Douglas Campbell
November 5, 2008: The fat lady sang. Back to actually working for a living.
1986 Isuzu P'up, 177,673.8 miles. Hella headlights, (highly recommended) DOT C-2 back end. (also recommended) R-12 air conditioner converted to R-406a. 4.1:1 rear axle converted to 3.4:1.
9/22/2007, age 21: Still running well when reluctantly sent away for reincarnation due to rust.
Not affiliated with the Campbell Soup Company.
drcampbell is offline
Old 02-04-2008, 12:14 PM   #6 (permalink)
RightWingNutJob's Avatar
Not trying to be overly picky - but I thought that the branched growths that occur in batteries were called "Dendrites" from the from Greek word "dendron," which means "tree.."
'01 F350 XLT, CC, 4x4, V10, SRW, LWB, Auto, 3.73LS, Island Blue, Off Road Package,
Auto Hubs & Cab Clearance Lights. Autometer water temp, tranny temp, & vaccuum
gauges. Line-X Bedliner, & the "incredible self-locking tailgate." White Night Backup
Lights & Volvo-eating Class V Hitch. Reverse Sensors.
RightWingNutJob is offline
Old 02-05-2008, 08:31 AM   #7 (permalink)
Originally Posted by RightWingNutJob View Post
... I thought that the branched growths that occur in batteries were called "Dendrites" ...
Right you are. I have corrected my posts on the topic.
Douglas Campbell
Old 02-05-2008, 08:41 AM   #8 (permalink)
Batteries Plus rebuilt my Milwaukee 18 volt packs. At the time, 1 yr ago, they could only rebuild the packs if they had removable tops with screws. If its sealed, they would not attempt the rebuild.
ENZO1 is offline
Old 02-05-2008, 01:58 PM   #9 (permalink)
Some may, we've had one guy carefully cut it open with a razor blade and repair them before.
The Rigid stuff at home depot though warantees the batteries forever though...
Eric
Ford 1992 E-350, 6,900 lbs.
Dodge 1997 Ram 3500
Ford 2005 F-350
yaric008 is offline
Old 02-20-2008, 02:59 PM   #10 (permalink)
Send them here for a rebuild, good quick service.
NiCad Lady - Radio Battery - Rebuilt Radio Batteries - Laptop Batteries - Cellphone Batteries - Camcorder Batteries - Flashlight Batteries
capt205 is offline
