Go Back   Diesel Forum - The Diesel Stop.com > Other Topics > Other Technical Questions
Other Technical Questions Discussion of other technical topics. Please see the sticky post at the top of the thread listing for specific rules. The rules for this forum are more restrictive than they have been in the past. Topics will expire automatically in 60 days.
Old 08-27-2008, 01:37 AM   #1 (permalink)
Hydraulic Press design
Since I know this is the place to find experts on everything, here goes. Smokey will probably know this
Why do hydraulic presses always seem to have the cylinder on the top, pressing down. Why would you not make a press with the cylinder on the bottom that presses upwards ? I am sure there is some fluid dynamics here or something obvious, so please edumacate me !
The discussion came up elsewhere and I figured I could find the answer here since Mr Google failed me.
2002 F-350 Lariat PSD 4x4 Crew Cab DRW LB SOTF
Vortex Liner, 3M Paint Protectant Film
Mor Powa !!!!
Check out - NOVAPS - Northern Virginia Power Strokes in the TDS Events forum
RocketRacing is offline
Old 08-27-2008, 01:50 AM   #2 (permalink)
klhansen's Avatar
My Photos: (92)
You could do it either way as far as the hydraulics are concerned. Force is Force.
Probably the reason most presses are built that way is because it gives a stable platform (not moving) on the bottom to set the workpiece on. Then you lower the ram onto the top where you can see it. You could design something with a movable lower frame, but it probably wouldn't be as stable, which when pressing with lots of force is very important. You sure as heck don't want the workpiece kicking out and hitting you in the gut.
99.5 F250 PSD Supercab LB 4x4, 6spd, 3.73LS, Boost & pyro gauges, Swamps S175/146 injectors, Jody's 80 HP Econo PCM (classic version), AIS, coolant filter w/"hokum" bracket, regulated return, heated mirror mod, lighted cupholder, Marinco heater plug-in.
Hard or no-start? Check here
klhansen is offline
Old 09-01-2008, 12:55 AM   #3 (permalink)
SteveRacer's Avatar
Location: Rockland Co. NY KC2JLJ on 147.165 MHz Design Engineering Machine Shop Owner
I think it's just easier to make and use. For smaller things you'd be constantly bending down to work around the floor level. Also, the "work" platform on mine just sits on large rods that fit into an array of holes on the sides. Gravity keeps it in place. It would be harder to "hang" this arrangement if you wanted to "press up". The hydraulic bits would have to be on the floor if you wanted a reasonable working height range.
And lastly, it's probably better to shoot things toward the floor when you're pressing out old bearings or races or shafts out of gears. Sometimes when they finally let go, they really pop hard -- and it's probably better to shoot it down at the floor than have a projectile rocketing toward the ceiling.
Perhaps it's just the way it is and nobody has challenged the paradigm. Why do motorcycles all pretty much have the same layout, with the gas tank between your knees and on top of the engine? (Although the Harley V-rod "tank" is actually air filters and intake, but it's still made to LOOK like a fuel tank.)
I suppose people expect things to look and act a certain way, and if they don't -- they better be much superior than the status quo or they won't sell no matter what. It's a novel idea, but I can't see an advantage of an upward-pressing hydraulic press.
S.A McChesney
'72 BMW 2002tii Fprod Race Car --- '82 Bitter SC 5-spd
'01 Volvo V70 T5 5spd, The Official SCCA Volvo Historic Racing Series Pace Car
'95 EB 351 Bronco --- '69 Lotus Europa --- '87 Merkur XR4ti --- '85 Bitter SC 3.9</font>
'02 F350 Lariat CC Dually Longbed PSD 4x4 6spd
Tekonsha Prodigy -- Icom 2100H -- Retrax -- B&W Turnover 5er Kingpin -- Letter to Santa "US Gear" . . .
32' invert 5er Britton/Transport Sys 12K GVWR Toybox,Honda 3kw Gen,Fridge,Micro,5kw Inverter,ColemanPolarCub
__________________________________________________ _______________________
Foglights on with High Beams '02-'08 Superdutys
SteveRacer is offline
