I have a 2002 F-150 4x4 automatic with the 5.4 engine that i dang near stole. Only problem is the rear axle has had it. its leaking from the pinion and driver side axle seal, the pinion has wobble and the carrier assembly has more play in it than recess(not to mention what i find when i start pulling it apart. At this point it is cheaper to get a certified used axle than to rebuild it. This is a 9.75 axle with 3.55 gears, ABS with disk brakes, Tag ID V919A.
Through this process i have found a number of interchangeable axle tag IDs from similar trucks of that year range(listed below).
My questions are:
1. What is the difference between these individual Tag IDs? I am guessing manufacturing plant and maybe production run dates.
2. What would it take to make one of the listed non-interchangeable axles fit my truck? maybe a different yoke if the spline is different? or is it completely different suspension dimensions?
These are listed to interchange with my truck.
FORD F150 PICKUP 01-03 (rear disc brakes), 9.75" ring gear, 3.55 ratio, ID V919A
FORD F150 PICKUP 00 9.75" ring gear, 3.55 ratio, ID V919B, (rear disc brakes)
FORD F150 PICKUP 01-03 (rear disc brakes), 9.75" ring gear, 3.55 ratio, ID S918F
FORD F150 PICKUP 00 9.75" ring gear, 3.55 ratio, ID V918B, (rear disc brakes)
FORD F150 PICKUP 01-03 (rear disc brakes), 9.75" ring gear, 3.55 ratio, ID V919B
FORD F150 PICKUP 01-03 (rear disc brakes), 9.75" ring gear, 3.55 ratio, ID V918A
FORD F150 PICKUP 01-03 (rear disc brakes), 9.75" ring gear, 3.55 ratio, ID V918B
FORD F150 PICKUP 00 9.75" ring gear, 3.55 ratio, ID S919F, rear disc brakes
FORD F150 PICKUP 00 9.75" ring gear, 3.55 ratio, ID V919A, (rear disc brakes)
FORD F150 PICKUP 04 (rear disc brakes), Heritage, 9.75" ring gear, 3.55 ratio
FORD F150 PICKUP 01-03 (rear disc brakes), 9.75" ring gear, 3.55 ratio, ID S919F
FORD F150 PICKUP 00 9.75" ring gear, 3.55 ratio, ID S918F, rear disc brakes
FORD F150 PICKUP 00 9.75" ring gear, 3.55 ratio, ID V918A, (rear disc brakes)
These do not interchange with my axle but are also for the same year F150s with same type rear end.
FORD F150 PICKUP 01-03 (rear disc brakes), 9.75" ring gear, 3.55 ratio, ID V941A
FORD F150 PICKUP 00 9.75" ring gear, 3.55 ratio, ID S942A, rear disc brakes
FORD F150 PICKUP 01-03 (rear disc brakes), 9.75" ring gear, 3.55 ratio, ID S942A
FORD F150 PICKUP 01-03 (rear disc brakes), 9.75" ring gear, 3.55 ratio, ID S941A
FORD F150 PICKUP 01-03 (rear disc brakes), 9.75" ring gear, 3.55 ratio, ID V942B
FORD F150 PICKUP 00 9.75" ring gear, 3.55 ratio, ID S941A, rear disc brakes
My questions are:
