Other Technical QuestionsDiscussion of other technical topics. Please see the sticky post at the top of the thread listing for specific rules. The rules for this forum are more restrictive than they have been in the past.
I'm having problems logging into my Yahoo home page and loging into My Ebay. When I try to login to both the computer says "waiting for reply". I'm running windows xp. Both problems started at same time and I haven't installed anything new. This is on my laptop running Sprint with a Sierra S590 wireless card.
I have full signal and am not having problems with any other sites where I have to login. I tried turning off my Norton to see if that would help but it didn't. Any help would be MUCH appreciated. THANKS
2003 X Limited 4WD 6.0,auto,55k mi. I'd buy another if FORD still made them.
1993 F150 4WD,5.8,auto,33s,315k mi.Never been stuck.YET!
New ride 1995 FRTLNR FLD120 Reman DD12.7 470hp,13spd,3.08 rears.Yeah I know,all the DD bashing I've done and I go and buy one.With the reman in it for $14,750 my mechanic said if I didn't buyit he would.
4 SALE 1993 FRTLNR coe N14 460hp,13spd,single axle,all aluminum wheels.
On your internet browser, try going to the 'tools' menu, and then 'delete browsing history', and then delete 'temporary internet files'. Sometimes it will solve a situation that you described.
2008 F-250 Lariat, Supercab, Long bed, 4x4, 5.4L non-diesel
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Bassman349</div><div class="ubbcode-body">On your internet browser, try going to the 'tools' menu, and then 'delete browsing history', and then delete 'temporary internet files'. Sometimes it will solve a situation that you described. </div></div>
If that doesn't work, your next step would be to run a scan for spyware. If you don't have one, download Ad-Aware.
Next step would be to run your anti-virus program.
Marc
2000 Excursion Ltd 2WD, Build Date 9/30/99, Oxford White, Medium Parchment Leather, 6 disk CD Changer, 3.73 LS, Magnum Deflecta-Shield, Vent Shades Ford Rear Air Deflector, AC Mod, Home Made Tymar, More to come sooner or later!
Let us put an end, once and for all, to this discussion of what a good man should be - and be one. -Marcus Aurelius-
Politics is the art of looking for trouble, finding it, misdiagnosing it, and then misapplying the wrong remedies. -Groucho Marx-
I would do a system restore back to a date before the problem appeared but first do a disk cleanup by opening my computer/right click your harddrive/click on properties and run the disk cleanup utility that you will see under the blue and pink graphical image of your harddrive.
If you still are having problems after the disk cleanup then do the restore to an earlier time before the problem appeared.Ron G
Sounds like just a connection problem. I will usually go in to the start menu, go to accessories, then to the command prompt. When is says c: type in "ping yahoo.com" if it comes back it will tell you. If it cant ping yahoo it will tell you there is a problem. That is how I tell wether its the computer side or the connection side.
I had problems with my Verizon wireless card...
Talked to the tech rep, and we "Uninstalled"" it, and something else...
We then re-installed it....
It seemed to work a little better...but, finally just said the H**L with it, and we've got a home based DSL now...
Verizon was $60/mo, and the ATT dsl is part of package for ...$15/mo [?]
Sorry it took so long to get back.I had to pick up a trl in New Orleans Tues afternoon and just arrived in Albany,NY so I haven't had time till now to respond. The problem turned out to be the tower I was getting my signal from. Once I moved to a different area I was able to access both sites. Since this computer is used exclusively for the truck I have to use a data card. I appreciate all the help with this problem.THANKS.
