Other Technical QuestionsDiscussion of other technical topics. Please see the sticky post at the top of the thread listing for specific rules. The rules for this forum are more restrictive than they have been in the past. Topics will expire automatically in 60 days.
So, it won't light up. It is a 12V 20 Amp and has the three prongs, Power, Acc, and ground. The switch itself powers a 12V solenoid off a 12V battery but it won't light up.
Is there not enough resistance? Does the actual LED need less voltage (2 or 3 volts?).
I don't see a wiring diagram on it but if someone could provide one with the necessary connections and extra parts that would be nice!
nope it should be fine with 12v just check grounds sometimes the ground in no good and it wont light
other times its no power to the switch does the thing its hooked up to work? if so its a bad ground
88 F-250 body,550 rear frame setup, 7.3 idi, 3:73 dana 80 rear, srw, dana 50 front, heavy duty leaf springs, back up camera, 20$ wallyworld fog lamps, class 5 bumper hitch welded to frame and gusseted, 32" steering tires all around, ac power converter,jeep bucket seats, deezee runningboards (cab only),cobra 29 cb w/ 102" whip, 2 trucklight worklights on front stake pocket each side,high lift jack behind seat, toolbox for the junk, visor, running lights, 6600 lbs with all my junk
