Go Back   Diesel Forum - The Diesel Stop.com > Other Topics > Other Technical Questions
Other Technical Questions Discussion of other technical topics. Please see the sticky post at the top of the thread listing for specific rules. The rules for this forum are more restrictive than they have been in the past. Topics will expire automatically in 60 days.
Old 11-24-2008, 04:48 PM   #1 (permalink)
Low-Speed Cruise Control?
I've got a FL-112 Freightliner with an M11 Cummins that's being converted to a sprayer. I'd like to be able to run a steady speed down around 10-15 mph, but the cruise control won't activate under 30mph. Is there any way to hotwire it to work at slower speeds? The truck itself is REALLY low-geared, so it's 1500+ RPM, it just locks out the cruise control. If not, has anyone adapted the do-it-yourself AIC to work on one of these?
Copper is offline
Old 11-24-2008, 06:06 PM   #2 (permalink)
MarkEkberg's Avatar
My Photos: (13)
Can't you crank up the idle manually (or with a switch)?
If so just do that.
UPDATED 1/1/09 Replace so far. 1 LUK flywheel+clutch, 2 thermostats, 2 set of brakes, 1 set of calipers, 5 CPS, 3 sets of tires, 2 Transfer pumps, 1 Injector modual, 1 Computer, 2 Alt, 2 sets of batteries, 1 Water pump, 6 Belts, 1 PS hose, 2 Sets ball joints, 2 set u-joints, 2 carrier bearing, 2 Speed sensors, 1 oil pres sender, 1 temp sender, 4 sets of e-break cables, 1 front fuel tank, 2 rear fuel tanks, 2 set of glow plugs, 7 Glow plug relays, Oil galley o-rings, Turbo pedistal o-rings, EBPV o-rings, 3 sets of Injector O-rings, 1 Vac-pump, 1 new carpet, 1 total paint job.Total $$$ in repairs v/s miles driven = 4.6 cents per mile. Add fuel to that it jumps to 16.5 cents per mile over the life of the truck.
MarkEkberg is offline
Old 11-25-2008, 10:49 AM   #3 (permalink)
It does have an idle control, but it only goes to about 11-1200. I'm thinking I can replace the linear controller it's wired to with a dial rheostat with more range, and get what I'm after.
Copper is offline
