Go Back   Diesel Forum - The Diesel Stop.com > Other Topics > Other Technical Questions
Other Technical Questions Discussion of other technical topics. Please see the sticky post at the top of the thread listing for specific rules. The rules for this forum are more restrictive than they have been in the past. Topics will expire automatically in 60 days.
Old 07-15-2009, 12:12 PM   #1 (permalink)
maniac's Avatar
Mis-matched tires
OK, when I bought my F-350 it had Firestone Steeltex AT tires on it, I took the spare and put it in the basement and bought 3 more just like it.
Fast forward to this past May, the original tires wore out and I put the 2nd set on, last week with around 3000 miles on them I had a steel spike go thru one of them, of course Firestone no longer makes the Steeltex tire that I have.
So my only choice is either replace all 4 of them, or replace one with a different tread pattern, I have done this lots of times on my OTR KW's and on OTR trailers, with no problems whatsoever, just never done it on any of my 4 wheel drive pickups, my thought is as long as they are sized the exact same,which they will be, it shouldn't really matter.
So what do you all think?
2002 F-350 SC SRW long bed 4X4 7.3 PSD Auto, Island blue,
38 Chev sedan delivery all steel, 350, TH400,A-C PW PS PDB, Yellow,
2000 Kenworth W900 600Hp Cat 18 spd 3:70 green
maniac is offline
Old 07-15-2009, 01:57 PM   #2 (permalink)
Tire manufacturers are now recommending that car and light truck tires should not be used if they are more than five years old (which could be a recipe for disaster with Firestone Steeltex's) and also when only replacing two that the newer tires be installed on the rear. If it were me, I would bite the bullet and buy two for the rear, then two more as soon as I could afford them. That way both tires on the rear axle will demonstrate equal traction characteristics until I could put on new fronts.
December, '02 build F-250 CC 4X4 Lariat 6.0/Torqshift,Toreador Red over Arizona Beige 4X4 FX4 w/ moon roof. Stull grill insert, chromed tow hooks/bed tie downs, painted door handles, King Ranch flares, '08 aluminum differential cover, Inyati bed liner, Edge 3" lift Bonspeed eight spoke wheels w/BFG AT KO 305/65R18s Pics http://community.webshots.com/user/going_going_gone
Going_Going_Gone is offline
Old 07-15-2009, 04:17 PM   #3 (permalink)
SmokeyWren's Avatar
My Photos: (42)
Originally Posted by maniac View Post
... my thought is as long as they are sized the exact same,which they will be, it shouldn't really matter.
Agree. And the tread pattern wouldn't have to match exactly, but they should at least be a similar design.
The old Steeltex AT is similar to the new Transforce AT, so I would probably buy one Firestone Transforce AT, and put it on the front. Put the matched pair on the rear axle.
Tire Specs for Firestone Transforce AT
But if you're anal about having matched pairs of tires on each axle, then buy a matched pair instead of only one tire, and put the third Steeltex AT in the spare.
My Sierra Blanca is a '99.5 PSD CrewCab hot-rod Towing Machine! BTS tranny; Ford Severe Duty Air Induction System (AIS); 4" stainless turbo-back exhaust; DP-Tuner tunes flashed into an Edge Evolution tuner; ISSPRO EV gauges and Turbo Temp Monitor (TTM); Auxiliary Idle Controller (AIC); SP-Diesel exhaust brake and torque converter controller. Top Job front end replacement. I special-ordered it new and plan to drive it until it quits.
SmokeyWren is online now
