Other Technical QuestionsDiscussion of other technical topics. Please see the sticky post at the top of the thread listing for specific rules. The rules for this forum are more restrictive than they have been in the past.
My son has an opportunity to get a metal lathe for free - but we're not sure how to move it. Getting it into my truck is no problem because he can use the fork lift at work (where the lathe is located) but once we get it to his house we're stumped. We need to figure out how to lift about 1500 lbs of lathe out of my truck, and then move it into his garage. There is a slight step (about an inch) where the driveway meets the garage floor so we'd have to get it over that as well.
Any ideas? Anybody in the San Jose/Campbell area have a fork lift we that would fit in a standard garage door that we could rent?
Alan Hepburn - F450 CC PSD 2WD 4R100 XLT+ RAM KILLER
Proud to be a Blue Star Family...Support our troops by supporting their mission.
- http://www.Alan.Hepburn.com
Steel pipes. Or about ten big friends. How about a chain hoist. Back up into the garage, lift it on the hoist. Lower it onto black steel pipe, roll it into position. Use pry bars to lift it off the pipes.
Andy
Early 99 5-98, F350 extended cab, DRW LB 245,000 miles and counting, Hood insulation delete (Soaked with fuel), Hutch mod, Harpoon mod. Otherwise, pure stock (for now)
You only need two tools: WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
Rolling engine hoist.
2004 F350 Crew XLT 4x4 long box, SRW, 3.73 Gears
Bone Stock
And three or four guys.
Andy
UPDATED 1/1/09 Replace so far. 1 LUK flywheel+clutch, 2 thermostats, 2 set of brakes, 1 set of calipers, 5 CPS, 3 sets of tires, 2 Transfer pumps, 1 Injector modual, 1 Computer, 2 Alt, 2 sets of batteries, 1 Water pump, 6 Belts, 1 PS hose, 2 Sets ball joints, 2 set u-joints, 2 carrier bearing, 2 Speed sensors, 1 oil pres sender, 1 temp sender, 4 sets of e-break cables, 1 front fuel tank, 2 rear fuel tanks, 2 set of glow plugs, 7 Glow plug relays, Oil galley o-rings, Turbo pedistal o-rings, EBPV o-rings, 3 sets of Injector O-rings, 1 Vac-pump, 1 new carpet, 1 total paint job.Total $$$ in repairs v/s miles driven = 4.6 cents per mile. Add fuel to that it jumps to 16.5 cents per mile over the life of the truck.
We unloaded our metal lathe (~3k lbs I think) using a homemade crane. Several native oak 2X8s nailed together to make 4X8 as legs, 3 2x8s as a 6X8 for a crossmember. Come-along and chain for the hoist. Pipes under the lathe to roll it, crane to lift up 2 ft onto the platform. It worked quite well. We never were unsupported more than 2" verticaly to reduce the dropping risk. Once it was where we wanted it, we rolled it off the pipes. IIRC, it took about 4 hours to unload it. Yours should be easier since you're going down instead of up.
A bobcat would probably work for the headstock, pipes for the tail.
Definately use a trailer. I wouldn't even think of moving a lathe larger than bench size unless it was in a trailer.
'96 F250 XLT, PSD, 4x4, ExtCab, LB, Auto, 3.55.
11-06: DIY Open Element, EBPV & TC exhaust brake.
02-07: 40 gal '05 F550 aft-axle tank = ~60 gal total.
03-07BTS downpipe & 6pos chip.
04-07: ]226,000mi 277HP, 543TQ, Graph
05-07: EGT, Boost, Trans from Tymar
06-07: 4" exhaust, 31 row 6.0L trans cooler
08-07: BTS Transmission.[/url]
09-07: 80.76 @ 16.527
Thanks for the replies all - I'm going to have my son investigate renting a bobcat or a short fork lift. According to him the lathe is fairly small - it weighs about 1300 lbs according to the fork lift he uses at work and it will fit in my truck with no problems - the F450 has plenty of capacity! Getting it out is the issue - it has to fit into a regular garage with the old-fashioned "swing-up" garage door, then we have to position it where he decides he wants it in the garage. A short bobcat with forks or a fork lift sounds like the best solution.
Some chain and a come along on the garage door beam a couple of 2x6 post to support it and an eye bolt less than $30 plus the beer we are gonna need pictures too [img]/ubbthreads/images/graemlins/cool.gif[/img]
2002 F350 Red PSD Auto SC/LB SRW 4x4 Tymar Intake 4"Dual Exhaust DI 6 position twisty knob BTS 4R100 Vegistroke V3
If you can get it out of the truck, a pallet jack might get it into the garage. [img]/ubbthreads/images/graemlins/grin.gif[/img]
2008 F350 SRW SB KR almost all options including moonroof, nav, etc. Ordered May 14, received July 4, 2007.
F350 4x4 CC SWB SRW 2003.25 6.0/Auto, FX4, Lariat, Toreador Red/Arizona Tan, Bench Seats, Moonroof, etc. Ordered Nov.6, 2002. Received Jan 30, 2003. Pulling 1992 Alfa 34' 12200GVWR with Pulliam SuperGlide. Retrax. 86000 miles and counting. Traded, July 4, 2007
Go rent a mini excavator for a couple of hours. You shouldn't even have to unload it from the trailer, just leave it strapped down and swing / lift with the boom and a chain. Set the lathe on the trailer towards the front and secure the bucket towards the rear... then just unload it the same way and use pipes or furniture rollers to position it in the garage.
If it's worth doing it's worth doing right!!
It aint the F450 capacity that is the problem. Either you'll be unloading in the driveway with a huge drop to the ground and a fairly long roll/carry into the garage, or you'll be in the garage with only about 6" of head room above the lifting point (which the lift operator can't judge because it is directly overhead).
The trailer is not just easier, it's safer.
United rents JLG Triple-L (click me) Kneeling trailers. The trailer sits right on the ground. and you could back it pretty much into the garage where you want the lathe and roll it right out onto the ground.
I have a close personal friend that i do a lot of business with selling used machines with that moves 5-10 lathes, and Bridgeport type milling machines with a Triple-L trailer. You can load it on dolly's leave them on the dolly's just be sure to Secure the living heck out of it then roll it right off when you get to the garage.
Or i can give you the number of a guy that specializes in moving small lathes and equipment that has a forklift and his own rollback KW that would do it for around couple of hundred bucks depending on how far you wanted it to go.
IF all else fails i have a boom truck in Oakland and would be willing to help you out for my going rate PM for details.
Also most lathes that look to be about 1500 lbs. are usually more like 2,000 Lbs.
After reviewing the pics of your 450's bed setup i wouldn't even attempt to transport a lathe in the bed. lathes are top heavy as they come and your truck doesn't have the proper provisions to secure a lathe in the bed. Capacity isn't a question securement is. I have seen MANY MANY lathes and Bridgeport type mills RUINED, Destroyed and Thrown from pickups, van trailers flat beds without adequate securement.
00'F350 psd CC Drw 2wd Bright Amber Western Hauler, exhaust brake transfer flow 50 gal tank tool, 30K Cody goose neck hitch, hawk pads, cryo'ed rotors, stainless lines, 380,000 miles
02' Psd Excursion Limited ultimate Estate Green 7.3L Auto 2x4 hellwig swaybars and rancho 9000's. 381,000 miles.
1993 F-superduty (F-450) 7.3L Gutless non turbo 2x4 Auto, Tire eating S.O.B. 12,750lbs 80,000miles lincoln Vantage 500 Duetz bolted in the back.
1994 7.3 I.D.I.T. factory turbo, auto 2x4 DRW with lots of upgrades, 11 transmissions under 100K factory warranty. 280,000 miles Currently Cavitated and parked.
96 F-800 24'flat 5.9L cummins, 4spd allison juice brakes.
89 F-800 6.6L 5+2 27,00lbs light weight with National 556A crane behind the cab.
2006 T800 KW 550 C-15 18spd 22K front, 52K rears murray ramps, 195" W.B. CA spec heavy haul SOLD
2006 Murray 16 tire professional lowbed SOLD
1996 fetherlite 4 horse GN, Walton 18' 14K tag tilt equipment trailer.
