Moving a real heavy weight into a garage - Page 2 - Diesel Forum - TheDieselStop.com
Old 06-12-2007, 09:19 AM   #16 (permalink)
My Photos: (27)
Re: Moving a real heavy weight into a garage
True, those babies are real top-heavy. Something to bear in mind if you move it around by the bottom pedestal.
'91 F-250 SC 4X4, 5spd. ATS Turbo http://sports.webshots.com/album/180135797kNEIOu
LMJD is offline
Old 06-12-2007, 10:17 AM   #17 (permalink)
RightWingNutJob's Avatar
I had to move an ancient huge 1500 lb gun safe out of a basement a couple years back - ony way out was the basement hatch. Ended up hiring a rigger to do it. It cost $400, but it was out on a special pallet and done in a little over an hour.
RightWingNutJob is offline
Old 06-12-2007, 11:14 AM   #18 (permalink)
My Photos: (5)
Rent a truck with a power liftgate for the day.
Douglas Campbell, P.E.
1986 Isuzu P'up, 177,673.8 miles.
- Hella headlights (highly recommended)
- DOT C-2 back end (also recommended)
- R-12 air conditioner converted to R-406a. Saved ozone and money
- 4.1:1 final drive converted to 3.4:1. Quieter, better mileage but it's a good thing I live in the flat Midwest.
- 9/22/2007, age 21: Still running well when reluctantly sent away for reincarnation, due to body & frame rust.
drcampbell is offline
Old 06-12-2007, 11:37 AM   #19 (permalink)
lone_star_dsl's Avatar
1500 lbs on a skid steer that high up in the air? Be careful, you will end up going over onto your face! I would try to put it on a trailer.
2002 F-350 SRW
Lariat, Crew Cab
Long Bed, 4X4
Auto Trans, Tymar Intake
Wicked Wheel, Zoodad Mod
Intercooler Wrap Removal
4" Straight Pipe Exhaust
Recon Smoked Cab Lights
05+ Harley Headlights
6" Upper and Lower Windshield Brows
ISSPRO Gauges, Edge Insight CTS
Acetone Badges
XM Radio, Cobra CB
315 Pro Comp AT's
2010 Elite 20' Dovetail Gooseneck GVW 14,000 lbs
2001 Thor Wanderer 24RK Fifth Wheel
180,000 mostly trouble free miles and counting!
lone_star_dsl is offline
Old 06-12-2007, 01:24 PM   #20 (permalink)
My Photos: (14)
You just have to have enough skid steer.
We regularly lift 2,000# of alfalfa off of a semi trailer with a skid steer. Granted we have rubber tracks, and that might help.
If I was doing the hauling, I would look for a lowboy trailer. Preferably a fork lift trailer( steel deck, low to ground), then lift it off with the skid steer, then put it into the garage.
I know the skid steer fits into a standard roll up garage door. not sure about a hinged door.
Chris
CCOUGHRAN is offline
Old 06-12-2007, 02:16 PM   #21 (permalink)
Kanman's Avatar
After reviewing the pics of your 450's bed setup i wouldn't even attempt to transport a lathe in the bed. lathes are top heavy as they come and your truck doesn't have the proper provisions to secure a lathe in the bed. Capacity isn't a question securement is. I have seen MANY MANY lathes and Bridgeport type mills RUINED, Destroyed and Thrown from pickups, van trailers flat beds without adequate securement.
Could not agree more. Top heavy as hell. Watched one flop out onto the Interstate a couple years back, and the guy was going dead slow around the clover leaf.
Kanman is offline
Old 06-12-2007, 02:54 PM   #22 (permalink)
My Photos: (5)
I like this idea the best. I've used this method with several large gun safes.
2002 Super Duty CC Lariat 4x4 4.5" Donahoe Racing lift
HoustonPSD is offline
Old 06-12-2007, 03:19 PM   #23 (permalink)
United rents JLG Triple-L (click me) Kneeling trailers. The trailer sits right on the ground. and you could back it pretty much into the garage where you want the lathe and roll it right out onto the ground.
I have a close personal friend that i do a lot of business with selling used machines with that moves 5-10 lathes, and Bridgeport type milling machines with a Triple-L trailer. You can load it on dolly's leave them on the dolly's just be sure to Secure the living heck out of it then roll it right off when you get to the garage.
Or i can give you the number of a guy that specializes in moving small lathes and equipment that has a forklift and his own rollback KW that would do it for around couple of hundred bucks depending on how far you wanted it to go.
IF all else fails i have a boom truck in Oakland and would be willing to help you out for my going rate PM for details.
Also most lathes that look to be about 1500 lbs. are usually more like 2,000 Lbs.
I like this option best. I betcha Dualie could take good care of you.
Andy
Early 99 5-98, F350 extended cab, DRW LB 245,000 miles and counting, Hood insulation delete (Soaked with fuel), Hutch mod, Harpoon mod. Otherwise, pure stock (for now)
You only need two tools: WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
arisley is offline
Old 06-14-2007, 02:51 AM   #24 (permalink)
My Photos: (33)
Please let us know how you make out on this when all is said and done.
00'F350 psd CC Drw 2wd Bright Amber Western Hauler, exhaust brake transfer flow 50 gal tank tool, 30K Cody goose neck hitch, hawk pads, cryo'ed rotors, stainless lines, 380,000 miles
02' Psd Excursion Limited ultimate Estate Green 7.3L Auto 2x4 hellwig swaybars and rancho 9000's. 381,000 miles.
1993 F-superduty (F-450) 7.3L Gutless non turbo 2x4 Auto, Tire eating S.O.B. 12,750lbs 80,000miles lincoln Vantage 500 Duetz bolted in the back.
1994 7.3 I.D.I.T. factory turbo, auto 2x4 DRW with lots of upgrades, 11 transmissions under 100K factory warranty. 280,000 miles Currently Cavitated and parked.
96 F-800 24'flat 5.9L cummins, 4spd allison juice brakes.
89 F-800 6.6L 5+2 27,00lbs light weight with National 556A crane behind the cab.
2006 T800 KW 550 C-15 18spd 22K front, 52K rears murray ramps, 195" W.B. CA spec heavy haul SOLD
2006 Murray 16 tire professional lowbed SOLD
1996 fetherlite 4 horse GN, Walton 18' 14K tag tilt equipment trailer.
Dualie is offline
Old 06-14-2007, 06:45 PM   #25 (permalink)
the final decision will be up to my son - if he wants to go to the expense of renting the equipment or not.
Alan Hepburn - F450 CC PSD 2WD 4R100 XLT+ RAM KILLER
Proud to be a Blue Star Family...Support our troops by supporting their mission.
- http://www.Alan.Hepburn.com
Alan_Hepburn is offline
Old 06-14-2007, 10:49 PM   #26 (permalink)
My Photos: (33)
My buddy with the Triple L/JLG trailer came by today loaded with a Bridgeport mill. After seeing that today i don't think there's a better way to even think about moving something like this without the use of heavy equipment. PERIOD.
Your best bet
Dualie is offline
Old 06-15-2007, 01:22 AM   #27 (permalink)
Dualie, that's an interesting piece of equipment. I've never seen one before but it looks to be very useful for moving heavy items. Thanks for posting the link.
If it's worth doing it's worth doing right!!
2002 F-250 PSD CC Lariat AIC, AIS filter, Cat delete, Coolant filter.
amb2958 is offline
Old 06-15-2007, 01:25 PM   #28 (permalink)
Thanks, Dualie,
He's still thinking it over - right now his money is pretty tight since he's getting ready to get married in the next 6 months or so, moving into a new house, and building up his 1950 Plymouth rod...
But he's still talking about wanting that lathe - it's just sitting in a corner of the warehouse where he works not being used. It was replaced with a newer one several years ago and this one is just gathering dust. He's hoping it will stay there until he can get it home...
Old 06-16-2007, 02:30 PM   #29 (permalink)
Get the lathe before someone else does. The wife will wait, and if she doesn't, there are many more of them out there than there are free lathes. [img]/ubbthreads/images/graemlins/laugh.gif[/img]
2007 F350 Lariat CC, Power Stroke, A/T, SRW 172", Scarlet & Gray, Captain's Chairs, Power Moonroof and Sliding Rear Window, Tow Command, Upfitters, Roof Clearance Lights, Sirius Satellite Radio, Line-X Spray Liner, B&W Turnover Ball Gooseneck
MX727 is offline
Old 06-16-2007, 06:48 PM   #30 (permalink)
But in the doghouse/on the couch is not a very comfortable way to spend a honeymoon, even if she will wait. She will have her revenge.
'96 F250 XLT, PSD, 4x4, ExtCab, LB, Auto, 3.55.
11-06: DIY Open Element, EBPV & TC exhaust brake.
02-07: 40 gal '05 F550 aft-axle tank = ~60 gal total.
03-07BTS downpipe & 6pos chip.
04-07: ]226,000mi 277HP, 543TQ, Graph
05-07: EGT, Boost, Trans from Tymar
06-07: 4" exhaust, 31 row 6.0L trans cooler
08-07: BTS Transmission.[/url]
09-07: 80.76 @ 16.527
My picture & diagrams
danjreed is offline
