Moving a real heavy weight into a garage - Page 3 - Diesel Forum - TheDieselStop.com
Old 06-18-2007, 01:54 PM   #31 (permalink)
Re: Moving a real heavy weight into a garage
But in the doghouse/on the couch is not a very comfortable way to spend a honeymoon, even if she will wait. She will have her revenge.
But he will have a lathe! [img]/ubbthreads/images/graemlins/grin.gif[/img]
2007 F350 Lariat CC, Power Stroke, A/T, SRW 172", Scarlet & Gray, Captain's Chairs, Power Moonroof and Sliding Rear Window, Tow Command, Upfitters, Roof Clearance Lights, Sirius Satellite Radio, Line-X Spray Liner, B&W Turnover Ball Gooseneck
MX727 is offline
Old 06-24-2007, 12:22 PM   #32 (permalink)
rmyers2051's Avatar
kneeling trailer, and a set of the car dollies that Harbor Freight sells, roll it any where you want it, use a floor jack and cribbing to remove the dollies. Done in an hour. We build conveyors for Toyota that are 8 foot wide and 30 feet long, and weigh around 5k pounds, move them all over the shop and their plant with these. Never lost a wheel off of one yet.
F250Ext. 4x4 5spd. GV overdrive,4.10s,23+mpg
Bronco
Some people are like slinkies, Not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs!
rmyers2051 is offline
Old 06-25-2007, 12:59 PM   #33 (permalink)
Invite Bob Sapp over.
Roland_Jenkins is offline
Old 06-26-2007, 01:37 AM   #34 (permalink)
Bill1013's Avatar
Loan him the money Alan, what are father's for anyhow, just think of all the things you can make on that lathe. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
OLDBULL [img]/ubbthreads/images/graemlins/smokin.gif[/img] [img]/ubbthreads/images/graemlins/smokin.gif[/img] [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
99.5 F350 XLT Lariat 4X4 AT 4.10 DW CC LB Centurion conversion Garret Turbo, Radio SD &Tape, SP Performance 40-60-80 chip, 100 Gal.Transfer Flow W/Trimax Control Aux. fuel tank. ScanGaugeII, Boost, EGT, Trans. Temp. Oil Temp. Build date 03/99
92 F350 7.3 IDIT E4OD CC LB dually Banks turbo US Gear O/U
1990 F350 XLT Lariat 7.3L IDI E4OD Dually 280K+ 2WD
Reman Promar Long Block 11/07
http://community.webshots.com/user/oldbull8?
Have AutoEnginuity W/Ford enhanced. Lima OH area.
My mind works lightening fast.
One Flash and it's gone forever.
Bill1013 is offline
Old 06-29-2007, 12:11 PM   #35 (permalink)
We moved a Bridgeport mill by hiring a flatbed wrecker. He used the winch to pull it up on the flatbed and strapped it down. When we got to the shop, he angled the flatbed into the shop and slid it off (using the winch of course). The we used a small farm tractor to push it across the concrete and the manhandled it into final possition. Used pry bars to lift and level it. No too bad. Pretty inexpensive too.
2005 E-350 XLT Extended 6.0
1984 Mustang SVO x3
SVONick is offline
Old 06-29-2007, 03:08 PM   #36 (permalink)
whitjo's Avatar
I own a machine shop and for lifting and setting small machines (less than 2500 lbs) I call a local wrecker service to unload from truck or trailer. First move the tailstock and carriage as far back as you can to help balance the weight, then get some lift straps and wrap them around the ways of the lathe. hook the winch cable from the wrecker to the straps and lift just enough to drive out from under it. Then set it on some steel pipes and roll into place. JUST REMEMBER, EASY DOES IT!!!
Early '99 F250 SD, 4X4, SuperCab, Long Bed, 7.3L "PowerStroke" Diesel, Auto, PMT1 PCM w/DPTuner 80 tow, 190K miles,
Volant intake, ISSPRO gauges, BDS front leveling kit, 4" straight piped, Dick Cepek 18x9 DC1-Chrome, Nitto Terra Grappler 325/65R18,
Pro GOD, Pro Guns, Pro Life Important Notice, Pro Life changes when someone breaks in.
whitjo is offline
