Go Back   Diesel Forum - The Diesel Stop.com > Other Topics > Other Technical Questions
Other Technical Questions Discussion of other technical topics. Please see the sticky post at the top of the thread listing for specific rules. The rules for this forum are more restrictive than they have been in the past. Topics will expire automatically in 60 days.
Old 08-27-2008, 12:29 PM   #1 (permalink)
muriatic acid to clean aluminum
A few years ago I cleaned my trailer with acid bought at a truck wash. Just brushed it on and rinsed . I now have a gallon of muriatic acid that was given to me. It is much stronger than what I had, it fumes and when it touches something. I assume it can be diluted. Can I clean my trailer with it and what ratio should I dilute it with water.
fieldtrialer is offline
Old 08-27-2008, 01:07 PM   #2 (permalink)
Supporting Member
bugman's Avatar
My Photos: (15)
I don't know about cleaning aluminum but it works great on masonry. You can dilute it with water and try a small part and see what it does and see if it has any harmful effects on the aluminum and go from there. You can also
Google it and get some answers.
Jim
96 F250 PS XLT 4X4 long box, 5sp,4.10, manual hubs,pyro+boost guages,Dark Toumaline, add a leaf,Dale's TYMAR,and HX hose, downpipe, coolant filter with coolant eye
bugman is online now
Old 08-27-2008, 03:44 PM   #3 (permalink)
muriatic acid is as close to hydrocloric acid as you can get,,,,sulfuric acid eats aluminum!,,all the way,,nothing left....i wouldn't do it
2001 7.3. Lariat...
muffler delete,Isspro guages,AIS,SCMT 1705,CCV Mod,Zoodad Mod
Lone20 is offline
Old 08-27-2008, 04:00 PM   #4 (permalink)
I just spoke with someone that totally agrees with you he said it can also turn the alum. black.
Old 08-28-2008, 02:53 AM   #5 (permalink)
My Photos: (33)
IT wont turn the aluminum black it will turn it white with black streaks. This is a process best left to a pro. I have 5 gall of aluminum acid was that i have had for several years now. I wont dare open the barrel.
Citric brightener works so much better and does much less damage.
If you must use either product it has to be done on a cool day less than 70 Deg. hose the trailer top top bottom don't be shy flood it.
Dilute whatever cleaner your going to use to its least potent form and Apply as recommended. DO NOT LET IT STAND AND DRY.
RINCE RINSE and Rinse some more.
1994 7.3 I.D.I. Navistar 444 CI
ATS Factory TURBO E4OD Red On white Crew Cab DRW 4:10 w/ AUBURN LIMITED SLIP
3" ATS Exhaust and turbo housing, Banks Trans Command, calibrated pump, K&N filter, Gruss style coolant filter, 203K+MI not a lick of trouble with the motor. now on 16th trans. 10 under factory 100K mile warranty
Alpine CVA-7878 XM radio 6cd changer 3 8" phoenix gold subs 75x4 Sony mobile ES gold 4ch amp, Sony 500W 1ch amp MB quart components in Q forms kick panels. 1 farad cap.
Pro car parts jewel cut headlamps and turn signals
APC clear cab markers, suvlights.com harness silverstar bulbs and L.E.D.'s in the fenders. IT's paid for and its MINE!
Family Toys and tools,
00'F350 psd CC Drw 2wd Bright Amber Western Hauler
SOLD 01' Peterbilt 330 4Dr. Texas trucks conversion cAt 350hp
02' Psd Excursion Limited ultimate Estate Green helliwig swaybar 101K miles
1996 fetherlite 4 horse GN, 2003 sooner 6 horse GN with midtack
Dualie is offline
Old 09-03-2008, 01:19 PM   #6 (permalink)
Do not, under any circumstances use muriatic or hydrochloric acid for aluminum. As others have said, you'll end up with black or black steaks (depending on the alloy) and the structural integrity of the aluminum may be compromised as well. I'd recommend a cleaner designed for alloy rims- they're usually like you described, brush on and spray off. Use the muriatic on your concrete but keep it away from your vehicles (31 years in the surface finishing/plating arena).
Keith
93 F350 CC Dually 7.3 Hypermax turbo 4:10 gears, ZF rower, K&N filter, home made ram-air, Hypermax 3.5" exhaust, LUK clutch, 150,000 mi.
Weezer is offline
Old 09-04-2008, 07:28 PM   #7 (permalink)
thanks to everone I dodged the bullet on this one. I bought some acid from a local truck wash, followed his directions and the trailer looks real good. I have one small section that sort of has a runny shadow. I thought I will do it again just in that spot.
