Other Technical QuestionsDiscussion of other technical topics. Please see the sticky post at the top of the thread listing for specific rules. The rules for this forum are more restrictive than they have been in the past.
Someone, somewhere, on this site, mentioned a NAPA part #, (heck, even had the picture) of a chemical to put on door seals/rubber. This was to keep them from sticking and freezing shut during freezing weather.
What was that stuff? I have been looking and searching for an hour, (my wife brought that up) with no luck!
03 F-250xlt 6.0, SOLD April 2010! Replaced by an 07 GMC Yukon XL, and a 99 F350 crew cab, long bed 4x4, 6 speed. 69 Shelby GT500, 428 Cobra Jet, 4 speed toploader.
67 Fairlane 500, 347 Stroker, AOD trans, 3.25 rear end... work in progress. I am looking for parts that I thought I had so carefully put away...............
Work "Truck" 110 foot, 1999 Spartan/ LTI quint, Detroit Series 60, Allison auto. Work "Engine" 06 Pierce Arrow, Detroit Series 60, 475 horse, Allison Auto. Work Medic unit, 08 E450 6.0 by Northstar.
Re: NAPA goo for door seals during freezing weather
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: shelbyandadiesel</div><div class="ubbcode-body">Someone, somewhere, on this site, mentioned a NAPA part #, (heck, even had the picture) of a chemical to put on door seals/rubber. This was to keep them from sticking and freezing shut during freezing weather.
What was that stuff? I have been looking and searching for an hour, (my wife brought that up) with no luck! </div></div>
It's called silglyde. It's a silicone paste that comes in a tube. I think it will be in their Balkamp catalog. I don't know the part mumber.
That Silglyde really works,but it is a mess to use. The silicone spray works justs as well if you use it yearly. Spray down all of your weatherstripping At least that was my experince when I lived in the cold country.
Leo
1994 F-250 4X4 Std. cab XL stock 5 speed 4.10 gears. Tymar Air Cleaner, Poly spring and pivot bushings.Luk SMF & Clutch. DIY Exhaust Brake,DIY Coolant Filiter & Heater Shutoff,DIY GPR ByPass, Lassen and Tehama Counties Calif.
I second that. My drivers window is real slow in the winter. I used the Silglyde in the channels, and it does work, but like said above, it smears all over the edge of the window and is hard to clean up. Used some spray silicone in the early fall and it works better and longer. Maybe the wrong application, but that is my experience with both.
Marc
2000 Excursion Ltd 2WD, Build Date 9/30/99, Oxford White, Medium Parchment Leather, 6 disk CD Changer, 3.73 LS, Magnum Deflecta-Shield, Vent Shades Ford Rear Air Deflector, AC Mod, Home Made Tymar, More to come sooner or later!
Let us put an end, once and for all, to this discussion of what a good man should be - and be one. -Marcus Aurelius-
Politics is the art of looking for trouble, finding it, misdiagnosing it, and then misapplying the wrong remedies. -Groucho Marx-
Looks like they have changed the package. Here is the new package. The difference between this and spray silicone for door seal application is night and day.
For some reason the NAPA system will not let me view your link. In what ways do you mean the difference is night and day? This is better than the spray, the spray is better, just curious?
GOD BLESS OUR TROOPS!! - GOD BLESS AMERICA!!
The link works for me. The part number is 7651346. You can probably go to NAPA online chemical catalog and find it with that number. It's a lot more time consuming to apply the paste because you have to rub it in. The end result is a better job because of a better application and it forces you to clean the rubber while rubbing it in. I rub it on liberally then wipe off as much as I can.
