Need to be able to charge Boat battery from truck...... How? - Diesel Forum - TheDieselStop.com
Old 06-22-2007, 12:09 PM   #1 (permalink)
Hey Guys
I am sure someone has done this or figured away.
Before my brother bought his PSD he would just put the battery in the truck and it would charge while driving to the water.
Now he wants to rig up some kind of system that will charge the boat battery. There is no power where the boat is stored so a trickle charger is out. What would you need to run a wire or wires to the back of the truck and charge it there or .....in the boat even ?????
Can it be done? What would it take? It needs to be safe, of coarse.
[img]/ubbthreads/images/graemlins/confused.gif[/img]
[img]/ubbthreads/images/graemlins/cool.gif[/img]
'00 EB EXPEDITION SOLD
'02 F-250 CC SB XLT SOLD
'05 Taurus
'02 Navigator SOLD
'06 F-150 SCREW XLT Sold
'03 F-350 CC LB Dually 7.3 PSD
coolfords is offline
Old 06-22-2007, 03:30 PM   #2 (permalink)
Re: Need to be able to charge Boat battery from truck...... How?
If you have the factory 7 way trailer light plug, you can charge off that. I can't tell you right off hand which one is the hot wire, but it's labeled on the outlet and in the owners manual. This is set up charge the battries of a travel trailer. It charges slowly, so it'll tale a long while to charge an really depleted battery. You just have to make the connections from hot spot in the truck plug to the positive side of the battery with a ground to the negative side.
Another method would be to wire in some sort of DC to AC inverter. This is commonly done to run TV's, VCR's, etc. The problem with doing this for a battery charger would be having enough watts to do the job. The more watts the invertor puts out, the more amps of 12 volt you have to put in. This requires adquate alternator output, heavy wiring, etc.
2001 F 250 Platinum Edition
7.3 PSD CC SWB 4x4 3.73 LS 4 spd auto
Mods- Autometer Tranny Temp Gauge, Hard Tonneau Cover
wandrews is offline
Old 06-22-2007, 04:38 PM   #3 (permalink)
I did wonder about your first idea. I'll check into that.
Your second ideal was another. Like you said, I have no idea of what size wire would be acceptable. Would a larger alt be in order.
I hope some more smarter people than I will chime in. [img]/ubbthreads/images/graemlins/grin.gif[/img]
'05 Taurus
'02 Navigator SOLD
Old 06-22-2007, 06:23 PM   #4 (permalink)
Using and inverter would be silly, since you already have a 12 volt source. The inverter is if you need to run an AC appliance. Sure a battery charger is AC, but it takes that AC and either by switching or transforming it turns it into guess what.. 13.6v DC. So, I would say run off the trailer connector, or just run a fused hot right from the truck batteries to another connector at the bumper.
If you run a 4 gauge cable you won't even need to regulate the current.
Now, don't forget thats the completely wrong way to go about having good battery life. You really should pull the battery from the boat and leave it at your house on a trickle charger, then bring it w/you to the boat.
Joe
Joe92GT is offline
Old 06-22-2007, 10:09 PM   #5 (permalink)
DIESELDUTTON's Avatar
Why does he have to charge it all the time, is it for a trolling motor? You can do like the others have said and use the charge wire in the 7 prong rv plug or another idea, at work we have small solar chargers on our hydraulic trailers that sit out in the yard all year and they work great that is if the boat is outside [img]/ubbthreads/images/graemlins/grin.gif[/img] Good Luck
http://community.webshots.com/user/dieseldutton
2004 Pitbull Motorsports rigid chopper
121 TP 130rwh 250 avon
04 CRF250 mine
02 CR80 sons
03 XR100 daughters
425 Polaris magnum
500 Polaris sportsman and 300 lakota everyones
1998 27.5 Wilderness 5th wheel
DIESELDUTTON is offline
Old 06-23-2007, 02:05 AM   #6 (permalink)
StayNCharge system will do what you want I believe.
Here is the link: www.stayncharge.com
06 F350 SuperCrew, 4wd, shortbed, 6.0
08 F250 FX4, SuperCab, shortbed, 6.4 - sold
01 F250 SuperCrew, 2wd, 7.3 - sold
Judd is offline
Old 06-23-2007, 10:13 AM   #7 (permalink)
My Photos: (10)
It's been some tears now sinceI worked at an RV Shop, but the Idea of 12V off the 7-way plug in the rear of the truck is what we used to keep trailer and 5th wheel batterys charged, although it is not the fastest chargin method. we also would install a "Battery Isolator" so that the truck could charge what was being towed but the towed vehicle could not drain the truck batteries.I hope this helps a little. Ted
Early 99, 6/98 F250 CC Shorty, 4" lift, AFE stage 1, SCT chip(not sure of the burn),triple pillar ISSPRO Guages, Toyo 285/75-16's (bought it this way) CCV Mod, new carrier bearing shimmed 3/4"SOLD!!!! F150 now.
"give yourself every opportunity to do it right the first time"
Tedzz is offline
Old 06-23-2007, 07:22 PM   #8 (permalink)
I've seen a few different solar chargers at Harbor Freight and other places, why not just run one of those when its stored. That way its ready to go whenever you need it and doesn't require a particular setup on any one vehicle.
Even if its stored inside of a building, you could run a solar charger outside the building and extend the wires some.
2002 F250 Crew Cab Long Bed 4x4. 3" Edge leveling kit. 35x12.50R18 Toyo Open Country MT on 18 x 9 Helo Maxx8's. ISSPro Pillar Guages. DB Electric Starter. MBRP Turbo Back Exhaust. AIS Severe Duty Airbox. Zoodad Mod. DP Tuner 40T/60T/80e/120/140/Drive Thru. John Wood Valve Body. 6.0 Trans Cooler. Overboost Annihilator.
big_poppa_pump is offline
Old 06-23-2007, 07:37 PM   #9 (permalink)
either the solar charger in storage or a little 1000 watt Honda generator with the 12v output while you are driving to the water, would charge the batteries faster and be much simpler to deal with at the boat ramp.
2003 Expedition FX4, 5.4
2004 Honda Civic Si
verojeff is offline
Old 06-23-2007, 07:48 PM   #10 (permalink)
That is the best idea and also solves getting to theboat and finding thieves have made away with the battery.
You can also have it load tested periodically. Breaking down on the water as a storm approaches is not fun.
2OOO F-250 4WD Crew Cab, 248,000K miles,
Stock. Replaced #1 Injector/harness, Starter Relay,CPS(twice), GPR, VSS, S-Belt, Alternator H2O Pump. AIS Severe Duty Filter, Switched 10K MOD, Bilsteins, Heater shutoff valve, Rotella Syn, Nitto TG's 305/55 on Eagle 20x10's, Mobil 1 ATF,Walker BTM, Optima Redtops,Mesa, Arizona
PRDATR is offline
Old 06-25-2007, 01:01 AM   #11 (permalink)
88beast's Avatar
4 gauge cable jumper ends some heavy duty connectors and you can charge anything run the cable from your battery to the connectors you put by your trailer hitch then create a jumper that will reach the boat battery
88 F-250 body,550 rear frame setup, 7.3 idi, back up camera, class 5 bumper hitch welded to frame and gusseted, front mount hitch and off road lights,93 front clip, headache rack, 37" humvee tires, ac power converter,factory buckets from quadcab, power windows and locks,cobra 29 cb w/ 102" whip, high lift jack behind seat, toolbox for the junk, visor, running lights, huge front bumper, oba,
in progress western style mirrors, holset turbo, airhorns, and some other goodies
88beast is offline
Old 06-25-2007, 01:55 AM   #12 (permalink)
Bill1013's Avatar
The PSD must have a 7-way plug on the back, get a 7-way trailer end from an RV store and hook up a #10 2-conductor wire to the marked terminals-- Black (battery positive) and the White (battery negative) and put a couple of large clips on the end of the wire-- Black wire to Red clip and White wire to Black clip. That way you would know you have the correct polarity when clipping to the battery. Another way is take a long jumper cable (if it would reach the battery) and cut the clips off one end and hookup to the trailer end plug as above. This is a very safe way, if you fasten the cable to the boat so the wind don't blow it off when traveling. Also if he does'nt use the 7-way now you have to plug in the fuse (30 amp) and maybe relay at the fuse box.
OLDBULL [img]/ubbthreads/images/graemlins/smokin.gif[/img] [img]/ubbthreads/images/graemlins/smokin.gif[/img] [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
99.5 F350 XLT Lariat 4X4 AT 4.10 DW CC LB Centurion conversion Garret Turbo, Radio SD &Tape, SP Performance 40-60-80 chip, 100 Gal.Transfer Flow W/Trimax Control Aux. fuel tank. ScanGaugeII, Boost, EGT, Trans. Temp. Oil Temp. Build date 03/99
92 F350 7.3 IDIT E4OD CC LB dually Banks turbo US Gear O/U
1990 F350 XLT Lariat 7.3L IDI E4OD Dually 280K+ 2WD
Reman Promar Long Block 11/07
http://community.webshots.com/user/oldbull8?
Have AutoEnginuity W/Ford enhanced. Lima OH area.
My mind works lightening fast.
One Flash and it's gone forever.
Bill1013 is offline
Old 06-25-2007, 11:28 AM   #13 (permalink)
I have a little solar charger I use to keep my horse trailer battery up. It works great. If I recall correctly, it was about $30 from Orchard Supply Hardware. When we go camping with my brother's family, they bring a small boat with a trolling motor and we fish in the morning and evning. During the day I throw the solar charger on it while we take the horses out.
Joseph, San Francisco Bay Area
'06 F-350 CC, King Ranch, FX4, 6.0 PSD/TorqShift, Dually, 4.30 Gears, Tow Boss, Loaded, Ford Remote Start/Alarm, No Performance Mods
Proud to be a member:
The Calif. Rifle & Pistol Assoc. (Life Member)
The National Rifle Association
What part of "shall not be infringed" do you NOT understand?
joseph3724 is offline
Old 06-25-2007, 11:09 PM   #14 (permalink)
I have a couple of different trailers with batteries in them that I charge from my tow vehicles. One is a horse trailer with an on-board battery for the fans and lights, and the other is a large flat-bed that has a winch and hydraulic dovetail.
There is a pin on the 7 pin RV trailer connector on the back of the truck that is hot when the ignition is on. I think that it's the center pin, but double check the wiring schematic (it's usually engraved onto the dust cap).
Your biggest challenge with this system is that this is a relatively low fused lead (I think 30 amps), so if your boat battery is really drained you might pop the fuse or breaker on your truck. Most of the time I don't have problems with my trailers unless the batteries are really drained.
If you use it, be sure to add a circuit breaker in your trailer wiring. I concur with the recommendation regarding 10ga wiring.
The advice regarding using a solar charger is very sound - a better quality of charging and the batteries will always be hot. Northern Tool sells a good unit from Batteryminder - it has the added feature of having a "pulse" charger built in which will desulphanate the batteries - thus extending their usable service life.
scsmith42 is offline
Old 06-27-2007, 12:28 PM   #15 (permalink)
I was told a vehicle alternator is not designed to charge a battery from dead. If done too often (how often is too often), it will kill the alternator. True?
Sounds like the OP is looking to routinely charge a dead battery with truck alternator.
[img]/ubbthreads/images/graemlins/shrug.gif[/img]
Devo
DevoK12RS is offline
