Nissan Versa AC Quit - Diesel Forum - TheDieselStop.com
Old 06-16-2009, 11:43 PM   #1 (permalink)
I have an 07 Versa and the AC stoped today. My wife said that it started working again but stoped and has not come back on. I have checked the fuses but they are good. Any ideas?
TIA
JC
'06 F250 CC King Ranch Shortbed SRW, 6.0PSD, TorqShift, FX4, ESOF, 3.73LS
Totaled '05 F250 CC Lariat shortbed SRW, 6.0PSD, TorqShift, FX4, ESOF, 3.73LS RIP
tu3712 is offline
Old 06-17-2009, 07:36 AM   #2 (permalink)
MarkEkberg's Avatar
My Photos: (13)
Most likely it the R13aXXXXX has leaked out causing the compressor to stop turning on. For $20 you can buy a recharge can with a gauge on it, but that will not fix the leak.
Is it something the dealership should cover? 3/36K coverage?
UPDATED 1/1/09 Replace so far. 1 LUK flywheel+clutch, 2 thermostats, 2 set of brakes, 1 set of calipers, 5 CPS, 3 sets of tires, 2 Transfer pumps, 1 Injector modual, 1 Computer, 2 Alt, 2 sets of batteries, 1 Water pump, 6 Belts, 1 PS hose, 2 Sets ball joints, 2 set u-joints, 2 carrier bearing, 2 Speed sensors, 1 oil pres sender, 1 temp sender, 4 sets of e-break cables, 1 front fuel tank, 2 rear fuel tanks, 2 set of glow plugs, 7 Glow plug relays, Oil galley o-rings, Turbo pedistal o-rings, EBPV o-rings, 3 sets of Injector O-rings, 1 Vac-pump, 1 new carpet, 1 total paint job.Total $$$ in repairs v/s miles driven = 4.6 cents per mile. Add fuel to that it jumps to 16.5 cents per mile over the life of the truck.
MarkEkberg is offline
Old 06-17-2009, 09:27 AM   #3 (permalink)
I don't think that is it cause the compressor is kicking on when I turn the AC fan on. The heater does not work either. I am guessing its the blower motor. but wanted some other ideas before i start tearing it apart.
tu3712 is offline
