Obsolete '84 Ford Ranger 2.2L Diesel Parts - Diesel Forum - TheDieselStop.com
Old 05-07-2008, 05:18 PM   #1 (permalink)
DaveBey's Avatar
My Photos: (203)
Does anyone know of any good resources for finding engine parts for a 1984 Ford Ranger with the 2.2L diesel engine? The end of the rocker shaft snapped off in addition to the front shaft mount. I went to the Ford dealership here in Claremore and got a parts diagram but they said both parts are obsolete.
Cheers from Claremore, OK!
Dave
DaveBey is offline
Old 05-08-2008, 08:36 AM   #2 (permalink)
MarkEkberg's Avatar
My Photos: (13)
Bone yards. I bet that is going to be a tough find. There may be some aftermarket options out there?
UPDATED 1/1/09 Replace so far. 1 LUK flywheel+clutch, 2 thermostats, 2 set of brakes, 1 set of calipers, 5 CPS, 3 sets of tires, 2 Transfer pumps, 1 Injector modual, 1 Computer, 2 Alt, 2 sets of batteries, 1 Water pump, 6 Belts, 1 PS hose, 2 Sets ball joints, 2 set u-joints, 2 carrier bearing, 2 Speed sensors, 1 oil pres sender, 1 temp sender, 4 sets of e-break cables, 1 front fuel tank, 2 rear fuel tanks, 2 set of glow plugs, 7 Glow plug relays, Oil galley o-rings, Turbo pedistal o-rings, EBPV o-rings, 3 sets of Injector O-rings, 1 Vac-pump, 1 new carpet, 1 total paint job.Total $$$ in repairs v/s miles driven = 4.6 cents per mile. Add fuel to that it jumps to 16.5 cents per mile over the life of the truck.
MarkEkberg is offline
Old 05-08-2008, 03:32 PM   #3 (permalink)
SmokeyWren's Avatar
My Photos: (44)
I found this with a search:
"Mitsubishi also brought in the Mighty Max diesel pickup in the early '80s. Dodge rebadged it as a D50 as well. The same engine was in the Ford Ranger diesel during the same time period both in a NA and Turbo version."
So if your engine was made by Mitsubishi, then maybe expand your search to the Mighty Max and D50 pickups?
I wore out a '79 Audi 5000S diesel, but I don't remember the diesel-powered little pickups around Denver back in the 1980s.
BTW, your old Ranger will be 25 years old next year. Then it will qualify for antique car tags in Texas.
SmokeyWren is online now
Old 05-08-2008, 04:07 PM   #4 (permalink)
Try these guys Auto Parts Fast at RockAuto
A 84 ranger with diesel just sold here at a farm auction for $1200. Ran like a top. I just did'nt need another truck that day. The guy has a diesel escort and loves it M
2001 PSD CC SCMT
2003 Rincon
2000 sp700
danocheese is offline
Old 05-09-2008, 01:00 PM   #5 (permalink)
I had a 1983 Mazda pick-up with a 2.2 diesel engine. Ford used to import the Mazda truck and rebadge it as a Ford Courier. I do not think the brought the diesel truck but maybe Ford used some Mazda components when they made the Ranger. Just a thought.
John
2000 Excursion Limited PSD 4X4 Dark Satin Green/Medium Parchmant Born 7/00 In-Service 10/00 All Factory Options except Transfer Skid Plate
JADFPE is offline
Old 05-12-2008, 09:24 AM   #6 (permalink)
kampinguru's Avatar
There were some Tempo's made that year with 2.2L diesel engines as well. You may want to check if they are the same engine.
2000 F250 Lariat S/C SB 4X4 Off-Road
7.3L PSD
2005 Cedar Creek 30RLBS
PullRite Superglide Hitch
Firestone Ride-Rite Airbags and Dual Commander II
LINE-X, Mag-Hytec Diff Cover, Autometer 3-gauge kit, AFE Stage 2 Intake, boot kit, coolant filter kit, A/C heater bypass.
DP Tuner F5 (40HP Tow, 80HP econ, 100HP Race)and ATS Housing
Magnaflow Performance 4 inch turbo back exhaust
BTS tranny
kampinguru is offline
Old 05-13-2008, 09:48 PM   #7 (permalink)
Also, the International Scout had a diesel version 4 cyl in the early 80's. A co-worker of mine had one. It couldn't get out of it's own way with a 100 foot lead, but he could get in the high 20's mpg running around in 4 wd. just my .02 cents worth
short_stuff
Y2K F250 CC PSD Auto, Short-bed Lariat, Woodland Green/Gold, ordered 07/10/99, born 09/12/99, delivered 10/08/99, Access bed cover, Bed Rug, Zoodad mod, Viper Remote Start Alarm, Fumoto valve, 103K somewhat error-free miles (so far) [never back to dealer for anything]
Repairs: CPS, Water Separator Valve assembly, rear axle bearings, VSS, batteries, brakes, alternator, serpentine belt (x2), driver door pwrlock actuator, water pump
2009 VW Tiguan 2.0 l turbo 200 hp gas engine (TDI engine not available for it yet)
short_stuff is offline
Old 05-16-2008, 11:20 AM   #8 (permalink)
I can help you out.
I am willing to buy your broken truck for a reasonable price if you want to sell.
swish is offline
Old 05-16-2008, 06:51 PM   #9 (permalink)
tempo, and escort engines were 2.0--and not the same. and izusu
94_turbo is offline
Old 05-19-2008, 08:51 AM   #10 (permalink)
You can get the part
Ok, since you didn't respond to sell me the truck I will help you out. :0) I just ordered that same part from the Mazda dealership in TUlsa last week for mine. You can also get parts through tractor dealerships and perkins diesel supply locations if you have the engine serial number. The engine was made under contract by Mazda for Perkins and is therefore just a Perkins engine. They were used in tractors and skid steer loaders also. Mazda said the support was absolete, but you should be able to locate it otherwise. If it is not completely broken just move it to the middle location and put a full support from there on the outside end. I hope this helps you out. But, I would still buy it if you are interested in selling.
swish is offline
Old 05-23-2009, 06:03 AM   #11 (permalink)
I have a 1983 Mazda 2.2 L (Perkins 4.135 Manf under Toyo Kogo). The top end was rebuilt recently before I bought the truck. The bottom end was weak. Sent to machine shop. Contacted the Perkins Dealer in Washington. But they wanted the serial number also for parts match. I found the number stamped on the block behind the fuel pump. Anyone know if this is the number location for this engine? It started with a "P" and so I am hopeful. But Perkins Pacific has not returned my call after I gave the serial number I found. Anyone know where else to find the rebuild parts for this if not Perkins?
David Hutchings is offline
Old 10-20-2009, 03:00 AM   #12 (permalink)
try these guys
hi guys if you are still looking for the good resources for your engine parts for Ford Ranger you can try to check out online.. there's a lot of ford parts that are available with low cost of shipping..
If you look to others for fulfillment, you will never be truly fulfilled.
pat63 is offline
