oldsmobile oil pressure question - Diesel Forum - TheDieselStop.com
Old 09-16-2009, 06:38 PM   #1 (permalink)
since i didnt see a off brand section i thought this was the best place to post the question.
a long time friend of mine is selling a oldsmobile aurora 2001 model for a dirt cheap price, it is a beautiful car but he says every once in a while a low oil pressure light will come on and the next bump you hit it goes back off.... so my first thought was a bad sending unit for the o.p. the motor does not nock, tick or nothing-runs just fine, its a daily driver for his wife and she is still driviing it. is there something else i should look for or just stay away???
2000 lariat le- 6in superlift, gt38r turbo, afe intake, mbrp 5", 22.5 semi wheels, custom paint.
2000crew cab dually k&n intake, ts 6pos.chip, guages, straight pipe, zoodad(sold)
early 99, standard cab long bed, 4x4, 4in. lift, 5in. exhaust, tymar, 315's, autometer guages.
nitrousneil is offline
Old 09-16-2009, 09:24 PM   #2 (permalink)
It may be as simple as the connection on the oil sending unit on the side of the block, they are prone to swelling from the heat of the exaust manifolds. Or could just be oily and not making a good connection. Does he have any service records (oil change intervals) for the vehicle or does he do the work himself? You can pull the oil fill cap on the valve cover and take a small light to look down into the cover at the rocker arms and see if they are gummed up with sludge, pull the dip stick and check the condition of the oil or to see if it has any bluing from being hot. Just overall maintenance check to see if it has been maintained. Best bet may be to take it to a local mechanic shop and give it the once over.
2001 Ford F-350 drw 4x2 auto,4.10 gears,Turbonetics ball bearing turbo, Turbo Master Wastegate controller, Dieselsite Boots, ceramic coated up-pipes and exaust manifolds, DIY Tymar, 4 inch exaust turbo to tip, Isspro guages EGT,Boost, Trans temp from DieselManor, 6.0 trans cooler, AIH delete with boost attachment, ITP Regulated Fuel Return kit,hutch and harpoon mod done, ITP in tank and prepump mod kit, Rotella ELC, 203 Stat. Oil Guard by-pass filter system
DP Tuner-no start, stock,40,60,80E,120
BTS Transmission,(BTS-BUBBA)
105,000 miles, built to tow
Toys: 03 Screaming Eagle Duece Harley
37ft Cyclone by Heartland 5th wheel toy hauler
ford4me2 is offline
Old 09-16-2009, 09:33 PM   #3 (permalink)
chuckster57's Avatar
Since both the V6 and the V8 use the same type of oil pump driven by the crankshaft ( like the PSD) then I would lean more towards the sensor or wiring being the problem
1997 Jayco 323RKS fifth wheel w/2 slides, Air Lift 5000 bags
Train Horns: Pictures here
PM please not visitor message
chuckster57 is online now
