Power Service in the cold? - Diesel Forum - TheDieselStop.com
Old 12-08-2007, 10:35 AM   #1 (permalink)
It's 15 out, not sure if the last tank my wife got was blended or not. I have heard that Power Service will not mix with diesel when it's cold out. Any truth to that, or will I be ok if I pour some in this morning and run it?
Aaron SEIA
My Truck:
97 F350 4 door dually, E4OD, DIY intake
only exhaust is stock DP
flatbed
gutless wonder, I want my 94 back!!!
AaronSEIA is offline
Old 12-08-2007, 10:54 AM   #2 (permalink)
My Photos: (27)
Re: Power Service in the cold?
<div class="ubbcode-block"><div class="ubbcode-header">Quote:</div><div class="ubbcode-body"> Any truth to that, </div></div>
As many times as I've done it (and no doubt many others), I'd say none whatsoever.
'91 F-250 SC 4X4, 5spd. ATS Turbo http://sports.webshots.com/album/180135797kNEIOu
LMJD is offline
Old 12-08-2007, 01:32 PM   #3 (permalink)
maniac's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Quote:</div><div class="ubbcode-body">As many times as I've done it (and no doubt many others), I'd say none whatsoever. </div></div>
I'll agree.
2002 F-350 SC SRW long bed 4X4 7.3 PSD Auto, Island blue,
38 Chev sedan delivery all steel, 350, TH400,A-C PW PS PDB, Yellow,
2000 Kenworth W900 600Hp Cat 18 spd 3:70 green
maniac is offline
Old 12-08-2007, 05:25 PM   #4 (permalink)
Powerstrokedogg's Avatar
Send a message via ICQ to Powerstrokedogg
never had a problem
2001 F-350 7.3L 4X4(ESOF) CC LWB 4R100 4X4, WIX 46637 open element air filter, Wicked Wheel, walker BTM, 203* Tstat, IC tube foil removed, coolant filter, AIH removed, 08 aluminum finned rear end cover, DP tuner 80econ 140smoke high idle,Phantom gauges, ATS transmission,ATS deep trans pan, 5 star torque converter, V10 trans cooler, 4" MRBP SS downpipe, twin 4" stacks
1989 F-250 6.9L IDI E4OD 500,000+ miles(sold)
1982 VW rabbit 1.6L diesel
2007 Arctic cat 700 diesel ATV
1975 W900 Kenworth 500 Cummins
1997 Ford school bus 5.9 cummins
Powerstrokedogg is offline
Old 12-08-2007, 05:35 PM   #5 (permalink)
I have used it when truck was just starting to gel , Power Service smoothed it right out.That is the brand we used it all of our trucks.
fieldtrialer is offline
Old 12-08-2007, 06:35 PM   #6 (permalink)
Texrob1's Avatar
Send a message via Yahoo to Texrob1
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: AaronSEIA</div><div class="ubbcode-body">It's 15 out, not sure if the last tank my wife got was blended or not. I have heard that Power Service will not mix with diesel when it's cold out. Any truth to that, or will I be ok if I pour some in this morning and run it?
Aaron SEIA </div></div>Use the White bottle,it is the Anti-Gel formula,if you already have the gray bottle though, I am sure it will not hurt anything.
2005 F250 XLT wedgewood blue 4x4 C/C SWB,6.0L PSD, Auto.(Member of 05 STC Failure Club ) 2006 Expedition Eddie Bauer,5.4L (Wife's) NRA Life Member. TSRA Life member.
Texrob1 is offline
Old 12-09-2007, 12:53 AM   #7 (permalink)
use the red bottle it is diesel 911 will clear up water. and help to blend fuel
96 f250 cc sb auto 4x4, 410 rear, banks intercooler, banks chip ottomind, 200,000 miles
dieseldave712 is offline
Old 12-10-2007, 09:55 PM   #8 (permalink)
As JMJD, and maniac have posted, you likely won't have any problem adding after fill up. It is recommended prior to fill up to "ensure proper mixing". Add it, drive down a bumpy road, hit the brakes a few times, and you're probably mixed. Done it myself in Wyoming and Colorado Springs, no ill effects, just memory deficiency....
Bret
Bret_B is offline
Old 12-13-2007, 05:45 AM   #9 (permalink)
Your fuel is winter blend and doesn't need any additives.
I live in Michigan & have never used any additives in my truck & never had a problem. With over 379,000 miles on it I would think I would have by now if it was going to happen.
97 F250 SC LB 4X4 PSD TDE0, E4OD,3.55's, 285/70/16"s ,Modified fuel tank vents, 375+k headed for 500k
Leader is offline
