Other Technical QuestionsDiscussion of other technical topics. Please see the sticky post at the top of the thread listing for specific rules. The rules for this forum are more restrictive than they have been in the past.
I have borrowed my buddies Starcraft R/T to take to the lake. While loading and doing my checks, I flushed the fresh water system and then tried to use the sink. I turned the water pump on and it pushes water out of the freshwater hookup on the exterior instead of through the faucets. I have looked everywhere and turned every valve I have found with no success.
Antiquis temporibus, nati tibi similes in rupibus ventosissimis exponebantur ad necem. (In the good old days, children like you were left to perish on windswept crags.)
There is a check valve at the fresh water hookup that is stuck open. Mine does the same thing, I keep a plastic plug the same size as a garden hose end in mine after I fill it with fresh water. You might be able to free it up with a screwdriver, have someone inside the RV turn on the pump and then probe around inside the hose hookup outside the RV.
Good luck...
2003 7.3 PSD 2wd XLT super cab long box, drw, automatic trans. 410 gears, stock exhaust with muffler delete, PHP chip, John Wood valve body, T/C lockup switch, ISSPRO EV gauges, AIS air box w/foam sleeve. ATS compressor housing, Prodigy brake controller. Cat ELC HD coolant, 195 degree thermostat, coolant filter. Vehicle build date August-27-2002, put in service September-11-2002:
Yep, mine leaks too. Make sure you get a "garden hose" type plug, not a regular pipe plug. The threads are not the same, a pipe plug is tapered pipe thread.
Good luck...
Well, I'm back from the lake. We had a great time.
dklein was right for the most part. There is a small screen and gasket assembly for the hookup. I guess the owner cleaned it out and the installed it backwards. The screen was pointed in and pushing on the check valve, keeping things open.
I turned everything around and it sealed up perfectly.
Here are a few pics. They are not mine but they repersent the camper. It is a Starcraft 36 R/T. Pretty slick rig.
Thanks again for the help. It salvaged my Labor Day weekend 360 miles from home.
