Other Technical QuestionsDiscussion of other technical topics. Please see the sticky post at the top of the thread listing for specific rules. The rules for this forum are more restrictive than they have been in the past.
Please assist. I have been doing this for years, but want to make sure I am doing it right.
I know the results from doing it wrong.
I have a 16' utility trailer, double axle with electric brakes on both axles. I have a Kubota B2150 tractor with front end loader and a Kubota ZD28 Zero Turn Mower.
Using chain or starps, what is the correct tie down procedure? Number of anchor points? If I secure the tractor do I also need to secure the front end loader?
What is the applicable DOT requirements?
I have searched the internet and found 49 CFR 392 and 393, Standard for Protetion Against Shifting and Falling Cargo. I have read this several times but still not clear. Nothing I transport with be over 4,000 pounds.
Any help and references will be appreciated.
Thanks,
John [img]/forums/images/%%GRAEMLIN_URL%%/smile.gif[/img]
2000 Excursion Limited PSD 4X4 Dark Satin Green/Medium Parchmant Born 7/00 In-Service 10/00 All Factory Options except Transfer Skid Plate
Basically you need two straps, chains, whatever over each piece of equipment and attached to the trailer at either end. As long as the front loader is attached to the tractor there is no need to bind it seperately.
The two minimum chains / straps are necessary for a redundant tie down in case one fails, regardless of weight. (Not sure if this is how the law puts it but it IS common sense).
I believe once you get over 10K you need more tiedowns but obviously you are far from that point.
I even use a 4-point tiedown on my riding lawnmower on my rollback. "Just in case" someone sees me.
Cant really improve on that reply, but I can add to it.
Make sure your chains pull against each other. Chains should never pull the same direction.
/ \ or \ / good.
/ / or \ \ bad.
I always safety tie my boomers. It never ceases to amaze me how many skid steer owners out there transporting their machine with only one chain thrown around the rear.
Here in Sc they( State Transport police) which are our DOT Comm. vechile enforcement are starting to enforce how equiptment is secured on both Commerical and private . we use to use 2 chains, 1 at the frt. 1 at the rear. Now They require that each corner have a control device.
Just what I was told about a year ago, and I've tslked to other drivers and they confirmed it.
Ya'll buckle up and pull them belts tight, its gonna get rough..
Mine :01 F-350 CrewCab Lariat 4x4, 7.3 PowerStroke, auto, ShortBox. Mods: 3-Gauage A-pillar W/ Autometer Lunar Guages: boost,pyro,trans; DIY Tymar, Muffler Delete, Galaxy DX-33 Radio W/ Wilson 1000, and Optima RED TOP's, Centramatics, Lund Soft Tonneau
Play:
'82 Ford Bronco 302, auto, Galaxy 33v, Wilson 1000
04 Yamaha G22 E , Jake's Long travel lift kit, Fairway Alloy "Hazard " wheels , 23" EFX Blade tires, Jake's SST Safari Bar and Rear Tube bumper.
Color : PPG Orange Crush Pearl w/ Hi- Gloss Black trim ....
Hers: 00 Pontiac Trans Am, (stock)LS1, auto, T-tops.
best bet goto a construction site and see how they tie down one of the backhoes it willl show you best most secure way
abd the mower i think you can but a special sling type deal for it idr though
88 F-250 body,550 rear frame setup, 7.3 idi, back up camera, class 5 bumper hitch welded to frame and gusseted, front mount hitch and off road lights,93 front clip, headache rack, 37" humvee tires, ac power converter,factory buckets from quadcab, power windows and locks,cobra 29 cb w/ 102" whip, high lift jack behind seat, toolbox for the junk, visor, running lights, huge front bumper, oba,
in progress western style mirrors, holset turbo, airhorns, and some other goodies
2002 F-350 SC SRW long bed 4X4 7.3 PSD Auto, Island blue,
38 Chev sedan delivery all steel, 350, TH400,A-C PW PS PDB, Yellow,
2000 Kenworth W900 600Hp Cat 18 spd 3:70 green
What I've always done is to imagine taking the trailer, turning it upside down and shaking it. Will the load and its attachments stay in place?
I think there are a lot of ways to tie down a load, depending on what it is. Just make sure you have lots of chain and binders before you start. [img]/forums/images/%%GRAEMLIN_URL%%/grin.gif[/img]
2008 F350 SRW SB KR almost all options including moonroof, nav, etc. Ordered May 14, received July 4, 2007.
F350 4x4 CC SWB SRW 2003.25 6.0/Auto, FX4, Lariat, Toreador Red/Arizona Tan, Bench Seats, Moonroof, etc. Ordered Nov.6, 2002. Received Jan 30, 2003. Pulling 1992 Alfa 34' 12200GVWR with Pulliam SuperGlide. Retrax. 86000 miles and counting. Traded, July 4, 2007
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: kalalp</div><div class="ubbcode-body">What I've always done is to imagine taking the trailer, turning it upside down and shaking it. Will the load and its attachments stay in place?
</div></div>
I like that, that's an excellant way to think about it. People who think gravity will hold their load in place are just playing fast and loose with public safety.
And it sure does suck to be in the road picking up the pallet of thousands of widgets that removed themselves from your truck. Identity with-held to protect the guilty.
Funny how an enclosed vehicle will give you a false sense of security.
Back in the old days I swapped out a pallet / triwall of PCV pellets from a van that had been in a wreck. The pallet slid forward and bent the drivers' seat up towards the steering wheel. 6 inches more and they would have removed him with a spatula and sponge.
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: kalalp</div><div class="ubbcode-body">What I've always done is to imagine taking the trailer, turning it upside down and shaking it. ... [img]/forums/images/%%GRAEMLIN_URL%%/grin.gif[/img] </div></div>
That's only one third of it. Also visualize turning it 90 degrees onto each side and up onto its nose.
Douglas Campbell, P.E.
1986 Isuzu P'up, 177,673.8 miles.
- Hella headlights (highly recommended)
- DOT C-2 back end (also recommended)
- R-12 air conditioner converted to R-406a. Saved ozone and money
- 4.1:1 final drive converted to 3.4:1. Quieter, better mileage but it's a good thing I live in the flat Midwest.
- 9/22/2007, age 21: Still running well when reluctantly sent away for reincarnation, due to body & frame rust.
Proper way Is 5 chains and binders one chain over bucket Instant ticket with out it. 4 chains Pulling opposite directions, 2 chains and binders pullin front and rear at an angle to keep the Item from moving forward or aft or laterely with out the chains touching each other. \/ !! /\ Kinda like this but with a bucket chain
2000 CC 4x4 LB Auto,Deepwedge wood blue. Amsoil airfilter,Amsoil 15w40 Engine oil, 285 BFG, Tires, Astro Start,Triple A piller And WD Gauges, Rancho RS 9000 X shocks, Predator tuner, Superliner Metalic Black Bed liner and Sprayed rockers. Walker BTM muffler And a whopping 17 Mpg, Pump mod done, Tank mod Done . Superfly
Have you ever seen a piece of equipment with a moveable accessory arm/loader/back hoe/etc get caught going under an underpass and that arm/etc either crashes into the side of the overpass structure or gets caught underneath and shoots up through the structure or street overhead? I wonder if that's the main concern?
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Mr_Roboto</div><div class="ubbcode-body">Why does the bucket need to be secured seperately? I'm assuming this is a integral part of the tractor..... </div></div>
Any type of movable attatchment needs to be secured. Bucket, backhoe, trencher, boom.
