Question on 1990 ish 460 Ford motor - Diesel Forum - TheDieselStop.com
Old 01-05-2008, 11:34 PM   #1 (permalink)
KINGTUT's Avatar
My Photos: (19)
Anybody got any HP and torque numbers on this. Was this a good year, good engine. My memory serves me that this was a very good strong engine. Any input appreciated.
KINGTUT is offline
Old 01-06-2008, 12:34 AM   #2 (permalink)
Dave Haven's Avatar
My Photos: (16)
Re: Question on 1990 ish 460 Ford motor
240 HP @ 4400 RPM, 360 lb-ft @ 2800 RPM.
Dave Haven is offline
Old 01-06-2008, 02:16 PM   #3 (permalink)
MarkEkberg's Avatar
My Photos: (13)
They rarely die, run for ever, but are very hard on fuel.
UPDATED 1/1/09 Replace so far. 1 LUK flywheel+clutch, 2 thermostats, 2 set of brakes, 1 set of calipers, 5 CPS, 3 sets of tires, 2 Transfer pumps, 1 Injector modual, 1 Computer, 2 Alt, 2 sets of batteries, 1 Water pump, 6 Belts, 1 PS hose, 2 Sets ball joints, 2 set u-joints, 2 carrier bearing, 2 Speed sensors, 1 oil pres sender, 1 temp sender, 4 sets of e-break cables, 1 front fuel tank, 2 rear fuel tanks, 2 set of glow plugs, 7 Glow plug relays, Oil galley o-rings, Turbo pedistal o-rings, EBPV o-rings, 3 sets of Injector O-rings, 1 Vac-pump, 1 new carpet, 1 total paint job.Total $$$ in repairs v/s miles driven = 4.6 cents per mile. Add fuel to that it jumps to 16.5 cents per mile over the life of the truck.
MarkEkberg is offline
Old 01-06-2008, 05:36 PM   #4 (permalink)
"Good" is relative. The 460 was originally built as the 429 as a high performance car engine. It was not designed for truck use and is not as durable as some of the older engines (FE series for instance).
Really the only thing it has going for it is cubic inches. It is no better or worse than the other V8 gas engines available at the time. Personally I prefer the 300 I6 or diesel (both of which are purpose built truck engines).
*ASE Master Certified, Medium & Heavy Trucks*
Mr_Roboto is offline
Old 01-06-2008, 05:39 PM   #5 (permalink)
dondiesel444's Avatar
I had a 1990 F-Superduty dump truck with a 460 EFI, 5-speed and 5.13 gears. the GVWR was 14,500 but I would haul 20,000 lbs with it daily, np problem. the truck had tons of power, but it would only get ~5 mpg, loaded or empty it didn't matter!! the 460 was a torque monster, but didn't like to rev high, I had an employee bend 2 pushrods in the truck trying to hot-rod it. I also put a 2-chamber Flowmaster on it and boy did it sound badass!!
2001 F-250 PSD Crew Cab short bed, 4x4 Lariet, only 97k miles bone stock for now
previous trucks:
2001 F-250 PSD CC SWB 4" lift, 315's, DP Tuner..
late '99 F-350 PSD CC LWB 4" lift, 315's, DP......
early '99 F-250 PSD SC SWB short shifted 6-speed, 5" stacks, 5.5" lift, 4.30 gears, DP Tuner, etc....
1997 F-350 PSD 4x4, 4" lift, 35's, Superchips tuner
TRUCK PICS
dondiesel444 is offline
Old 01-06-2008, 07:46 PM   #6 (permalink)
My Photos: (27)
Yessir, they are double-tough. A very heavy duty engine. One of our mechanics quit our shop and was working at home and I gave him a hand and we did a complete overhaul on a 460 from an F-250, '81-'87 era. I was impressed with the size of the con rods, crank, big valves, bearing sizes, etc. In fact the internals reminded me to an extent of the 534 (543)? huge Ford heavy duty truck engines that were used in some 10 wheelers. But like Mark says, they're mucho thirsty. A guy I drove truck for after retirement had one in his '91 F-250, and he had a fit when he asked about my '91 diesel fuel mileage compared to his wonderful 460's 9MPG.
Years ago our shop foreman also had an early one and he said word for work what dondiesel444 posted, empty or towing, same bad mileage. [img]/forums/images/%%GRAEMLIN_URL%%/grin.gif[/img]
'91 F-250 SC 4X4, 5spd. ATS Turbo http://sports.webshots.com/album/180135797kNEIOu
LMJD is offline
Old 01-06-2008, 08:32 PM   #7 (permalink)
well, I have sort of a different experience than some with the 429/460 engine.
I had a 1972 F350 DRW, with a 360/4spd. Typical problem: wrist pin came loose and got into the cylinder wall.
Truck was still good, so I went to a guy who parts out cars. He had a 69-70 Lincoln Continental. It had a 429(he said... I was told later it was a 460). I still believe it was a 429; open to persuasion with facts, though.
The manual listed the HP as 365. I seem to recall the torque was around/little over 440 ftlbs. It also was auto equipt.
I put that combination in that 350.
POOOWERRRR!!! compared to the 360. It also got much better fuel mileage. I recall it was around 10 empty...7-8 with a load.
I really liked it and would do the same again.
NRA member...GUN(s) Owner...Bluegrass performer and festival promoter. Now have an International 9400 Eagle, Cummins N14, 10 speed, 72" mid-rise sleeper. Pulling a 45' Teton 4 axle, triple slide.
http://www.youtube.com/watch?v=GqI14CfACjU (I'm the old guy singing lead, w/beard)
http://www.myspace.com/trustingheartaz featuring
4 more original songs...one traditional standard (Fields Have Turned Brown).
Now fighting the big Kidney Cancer, Stage IV.
Prayers, attitude and the Mayo Clinic!
bilbo is offline
Old 01-06-2008, 09:00 PM   #8 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: MarkEkberg</div><div class="ubbcode-body">They rarely die, run for ever, but are very hard on fuel. </div></div>
Don't exaggerate, they are great on fuel.......10 mpg highway 8 city. [img]/forums/images/%%GRAEMLIN_URL%%/grin.gif[/img]
They do actually run good.
Too much junk/toys to mention, ever changing due to too getting bored too quickly. I need a 10 step program!
Want to call? I'm in the book. Want to argue....First explain the square root of negative one....lol
roofeditor is offline
Old 01-06-2008, 09:59 PM   #9 (permalink)
My Photos: (27)
<div class="ubbcode-block"><div class="ubbcode-header">Quote:</div><div class="ubbcode-body"> Typical problem: wrist pin came loose and got into the cylinder wall.
</div></div>
I've seen that a few times, but IMO you really can't fault the engine. Usually someone didn't expand the keeper enough when required, or didn't properly seat it in the groove. If installed properly, it's about impossible for it to come out.
LMJD is offline
Old 01-06-2008, 10:11 PM   #10 (permalink)
I know these large block Fords are great engines...but I have heard of this several times (of course, there are MILLIONS of these large blocks manufactured).
I have ran the 390 AND the 406 in the mid-60s.
Strong, but still not a HR427!
The 'cross-bolt' 4 bolt main in the 427 made it a completely different version of the Ford.
I even got a ride on MR ED, the drag boat, with the SOHC 427 on the Kings River in Central California area....great days!
bilbo is offline
Old 01-07-2008, 04:26 AM   #11 (permalink)
1987:
300--150hp/260ftlbs torque
302--185hp/270ft/lbs of torque
351 HO 200hp/300ft/lbs of torque
460 HO 220hp/380ft/lbs of torque
1988-1991:
351--210hp/315ft/lbs of torque
460--230hp/390ft/lbs of torque
1992-1993:
302--195hp/270ft/lbs of torque
460--235hp/395ft/lbs of torque
1994-1995:
302--205hp/275ft/lbs of torque*
351--210hp/325ft/lbs of torque
460--235hp/405ft/lbs of torque
92 F 250 Ext Cab Long Bed 2WD 5-Sd , All stock "for now" 60 Gal tank in bed for burning used cooking oil , If you smell frys you might be behind me.
93whitetiger is offline
Old 01-09-2008, 11:08 PM   #12 (permalink)
OT
OT's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Quote:</div><div class="ubbcode-body">It was not designed for truck use </div></div> Don't know, but...
My 88 F250 (bought new) 460cid.EFI 5speed (o/d). Gave me over 100K mi. reliable svc. Hauled my 9.5ft Bigfoot (o/h slide in/heavy) camper many thousands miles. Was hard on gas, but was a great/strong runner. JMO!
Never blew anything, but my 03 6L sure did.
btw...I also got great svc. from my 300 cid (BIG) inline 6 in E150.
03 F250 XLT SC/SB 4X4 6L (stock) A/T. SRW 3.73's BD:02/11/03. 01 TL 23' SGII
OT is offline
Old 01-10-2008, 01:26 AM   #13 (permalink)
My Photos: (33)
Other than the little hose between the water pump and the block, and several alternators and a couple of pairs of exhaust manifolds.
my 85 F-250 460 C-6 has been a phenomenal truck. Its been totaled 4 times I keep putting it back tougher.
245,000 miles original motor. Replaced the timing chain at 175 K and had to put a new carb and intake manifold on last week.
Started life as a 2 x 4 regular cab long bed fleet side its now a 2 x 4 DRW with a 10T flatbed on it.
00'F350 psd CC Drw 2wd Bright Amber Western Hauler, exhaust brake transfer flow 50 gal tank tool, 30K Cody goose neck hitch, hawk pads, cryo'ed rotors, stainless lines, 380,000 miles
02' Psd Excursion Limited ultimate Estate Green 7.3L Auto 2x4 hellwig swaybars and rancho 9000's. 381,000 miles.
1993 F-superduty (F-450) 7.3L Gutless non turbo 2x4 Auto, Tire eating S.O.B. 12,750lbs 80,000miles lincoln Vantage 500 Duetz bolted in the back.
1994 7.3 I.D.I.T. factory turbo, auto 2x4 DRW with lots of upgrades, 11 transmissions under 100K factory warranty. 280,000 miles Currently Cavitated and parked.
96 F-800 24'flat 5.9L cummins, 4spd allison juice brakes.
89 F-800 6.6L 5+2 27,00lbs light weight with National 556A crane behind the cab.
2006 T800 KW 550 C-15 18spd 22K front, 52K rears murray ramps, 195" W.B. CA spec heavy haul SOLD
2006 Murray 16 tire professional lowbed SOLD
1996 fetherlite 4 horse GN, Walton 18' 14K tag tilt equipment trailer.
Dualie is offline
Old 01-10-2008, 11:01 AM   #14 (permalink)
My Photos: (27)
<div class="ubbcode-block"><div class="ubbcode-header">Quote:</div><div class="ubbcode-body"> Other than the little hose between the water pump and the block,</div></div>
Yea, if you were going to burst a hose, the water pump bypass hose would be the one. After getting the old one off, you can squish a new one end-ways almost double with needle nose pliers and install it without pulling anything. On some, the steel nipple is too long, but it can be shortened with a hacksaw blade first, then you can go the needle nose pliers route.
LMJD is offline
Old 01-10-2008, 01:24 PM   #15 (permalink)
I had a 1987 F250 with the 460 motor. The motor was probably the most reliable motor I have had in a truck. I bought it new and ran her for 10 years and 195k miles. In that time I replaced the carb and water pump. It would get around 6 mpg unloaded and 4 mpg towing or hauling a load. It was a real work horse. The only reason I sold her was she would not pass smog in cal. The motor was still running strong. The motor was designed to run on regular leaded gas and in California it was switched to unleaded a few years after I bought her.
2005 F350 6.0 PSD srw lb sc Zf6 speed
mods: BD exhaust brake- Dura flap mud flaps-Piaa back up lights-Wilson cell amp and antenna-Midwest short throw shifter--C-Betr mirrors-Burning B100
wdwkr is offline
