Re: replacement of injectors Explorer 1999
im not quite sure on the vehicle your dealing with but usually you just pull the bolts out that secure the fuel rail to the intake manifold and the injectors and the fuel rail pull out as a unit.
the injectors just use a o-ring to seal in the manifold and a o-ring to seal to the fuel rail. not a whole lot to it
2001 F-350 7.3L 4X4(ESOF) CC LWB 4R100 4X4, WIX 46637 open element air filter, Wicked Wheel, walker BTM, 203* Tstat, IC tube foil removed, coolant filter, AIH removed, 08 aluminum finned rear end cover, DP tuner 80econ 140smoke high idle,Phantom gauges, ATS transmission,ATS deep trans pan, 5 star torque converter, V10 trans cooler, 4" MRBP SS downpipe, twin 4" stacks
1989 F-250 6.9L IDI E4OD 500,000+ miles(sold)
1982 VW rabbit 1.6L diesel
2007 Arctic cat 700 diesel ATV
1975 W900 Kenworth 500 Cummins
1997 Ford school bus 5.9 cummins
