Sirius Radio & Premium Amp - Diesel Forum - TheDieselStop.com
Old 09-06-2009, 01:51 PM   #1 (permalink)
I hope I'm in the right thread. 2009 f250 Lariat with premium sound and sirius satellite radio option. My question is, where is the Sirius radio located. Most times it's located in the car trunk, but in this case there is no trunk and I can't find it under the dash. Also, my premium radio sounds like a cheap tin can with full base and treble. Is there a separate sub amp that adds to the sound? My dealer says it's ok, but my previous 2003 f250 with premium sound had a much better sounding radio. Any comments will be appreciated.
bowser is offline
Old 09-10-2009, 12:24 AM   #2 (permalink)
My 08 lived under the dash, to the left of the steering wheel. I removed it when someone wanted it, a bit of a pain
1997 Crew Cab, Gear Venders, Transfer Flow, Garmin 2720 GPS
1997 F250 Supercab Transfer Flow tank
2008 F250 Crew
dbmaxwell is offline
Old 09-10-2009, 04:15 PM   #3 (permalink)
I've also seen the units under either the driver's seat or the passenger seat, if there is room. With regards to the radio sound, is it possible you're radio internal amp is blown, or one channel is grounding out? Have you listened to other 2009 F250 Lariats to compare the sound? Maybe you should take it to another dealer?
short_stuff
Y2K F250 CC PSD Auto, Short-bed Lariat, Woodland Green/Gold, ordered 07/10/99, born 09/12/99, delivered 10/08/99, Access bed cover, Bed Rug, Zoodad mod, Viper Remote Start Alarm, Fumoto valve, 103K somewhat error-free miles (so far) [never back to dealer for anything]
Repairs: CPS, Water Separator Valve assembly, rear axle bearings, VSS, batteries, brakes, alternator, serpentine belt (x2), driver door pwrlock actuator, water pump
2009 VW Tiguan 2.0 l turbo 200 hp gas engine (TDI engine not available for it yet)
short_stuff is offline
Old 09-18-2009, 05:53 PM   #4 (permalink)
Thanks for the comments. I still haven't found the Sirius. My dealer tells me that there is no separate amp, its all in the radio. Also he tells me that all radios in Ford trucks start with the base Premium sound radio and go up from there. Also, he told me that there is no subwoofer in my truck (hadn't thought about that), but a subwoofer could be added behind the back seat on the driver's side - Ford sells one. I wish I knew how to pull the radio and see if there is another box behind it.
bowser is offline
Old 01-10-2010, 11:42 AM   #5 (permalink)
On the same topic, does anyone know what is the output wattage (rms preferrably) of the late model ford premium sound system?
bowser is offline
