Skid steers, can someone help decide what kind, hp, used? - Diesel Forum - TheDieselStop.com
Old 12-19-2007, 02:56 PM   #1 (permalink)
My Photos: (5)
I would like the machine to able to have a backhoe attachment. I am looking at used machines. This will be used for personal use and light commerical. Can someone get me started in the right direction? Thanks
2002 F-250, PSD 6-speed, CC, short bed, 4X4, Toreador Red w/ Silver accent, A.R.E mx cap, Weld Super Single II and 33s in the summer, x-springs, F-350 blocks and badges, AIC, proflaps, ITP intank mod, AirDog with 3 micron filter, isspro guages and TTM, scangauge, husky liners, alarm, xm stereo,stull 5399-p grille, centramatics, ccv mod, AIS Air Filter, Southbend CON O, Detroit Truetrac LSD, coolant filter, 203 stat with billet housing, blackcloud intake heater plug/boost fitting, reese titan hitch, fabcraft PTO cover/temp sender port, prodigy brake controller, ITP Boost Annihalator, oilguard bypass filter, Mag-Hytec rear dif, bilsteins, hellwig rear stabilizer bar, ATS housing, non-ebpv pedistal and exhaust flange, magnaflow 3.5dp exhaust, ITP reg return, turbomaster wastegate controller, and ceramic coated bellowed up pipes, PHP 50t and 80p, currently 96,100 miles. truck Pictures
clydesdale is offline
Old 12-19-2007, 08:35 PM   #2 (permalink)
FINE69's Avatar
Re: Skid steers, can someone help decide what kind, hp, used?
My brother-in-law has a fairly large landscaping company, he uses only Bobcat skid loaders and has had VERY good luck with them. He currently runs their rubber track style loaders. I've used them a few times, very nice machines.
2009 F350 CCLB Larry-at, 6.4, all the toys....
http://community.webshots.com/user/FineFord
FINE69 is offline
Old 12-19-2007, 09:06 PM   #3 (permalink)
I like the Case 60XT Uniloaders. The Bobcat's backhoe is better, but I think the Case is an overall more durable machine. The Uniloader uses the Cummins B3.9, while Bobcats come with MAN's and Kubotas. Uniloaders are easier to work on.
Louisville Joe, L_Series_Joe, now Louisville_Joe.
Louisville_Joe is offline
Old 12-19-2007, 09:17 PM   #4 (permalink)
88beast's Avatar
go bobcat everyone here swears by them and most use tracks over the wheels because they will run in mud so well youll think youre on hard dirt
bobcat is the only one who has refined the system to the point where its set in stone an older one can be easily upgraded when it breaks down just use a newerpart
most wont give a backhoe though all companies have them but they cost almost double just to have it set up for one
if you need the backhoe then just go with a small tractor
and skidsteers are great for snow plowing
88 F-250 body,550 rear frame setup, 7.3 idi, back up camera, class 5 bumper hitch welded to frame and gusseted, front mount hitch and off road lights,93 front clip, headache rack, 37" humvee tires, ac power converter,factory buckets from quadcab, power windows and locks,cobra 29 cb w/ 102" whip, high lift jack behind seat, toolbox for the junk, visor, running lights, huge front bumper, oba,
in progress western style mirrors, holset turbo, airhorns, and some other goodies
88beast is offline
Old 12-19-2007, 10:47 PM   #5 (permalink)
We have a fairly big size landscaping company and we use bobcat skidloaders and escavaters they are awsome machines to use and if something happans to them usaully easy to fix and bobcat always has great support. We have ran demo machines from different companies like john deere, Cat, and Case they all had thier ups and downs. And if I were to plow snow the only bobcat that i would want to use is the bobcat tool cat 5600. Not no skidloader !
92 F-250 with luk clutch, got 304,000 miles out of old motor, now have IDI out of a 94 With factory turbo. Bought and installed ATS Exhuast housing, wastegate, downpipe. Turned up pump electric fuel pump. Runs like a bat out of hell.
andre7910 is offline
Old 12-19-2007, 11:31 PM   #6 (permalink)
88beast's Avatar
the guy i bought my truck from used a bobcat largest one made skidsteer to snow plow he plowed 18inches no problem with it
88beast is offline
Old 12-20-2007, 10:49 PM   #7 (permalink)
My Photos: (5)
Another question I have is: How many hours is a lot on a used machine. I see used machines with anywhere from 500-3500 hours. What is the expected life? Granted it will depend on how it is used, but what is average? Thanks
Old 12-20-2007, 11:45 PM   #8 (permalink)
88beast's Avatar
well if your looking in that area its about average it depends who youre buying from some commertial uses will go till 5000 some homeowners have 300 hrs of moving it around the farm to get it out of the way
1500-2500 will be good for weekly use and not much upkeep
anything more you may have a few problems show up anything less youll pay a pretty penny for but sometimes its a good idea to buy one for cheap with a known problem and fix it lots cheaper
but find one low hrs used commertialy because some homeowners with them abuse them
88beast is offline
Old 12-21-2007, 07:47 PM   #9 (permalink)
I have a Cat 246 wheel machine and 272 wheel machine with the Loegering VTS track system. They are both around 80 hp, turbocharged, and the 272 is intercooled. I have had very good luck with these machines. The 246 was bought with only 400hrs on it and the 272 was bought new. I like the Cat because of the smooth controls and good service and parts support in my area. Parts and service availability should also influence your decision. However, you will pay more for the Cat name than you would a Bobcat, Case, etc. The 246 machine is on the yard everyday and is constantly started and shut down. It hasn't missed a lick yet! Good luck with your decision!
...John...
1994.5 powerstroke F-350 Reg. Cab. 5 Speed 2WD DRW 4.10, Oxford White, Cab and Chassis converted to electric over hydraulic dump bed. Diy Aic, switched 10k mod, Diy exhaust brake, Autometer Boost and Pyro gauges. DIY tymar. 3" downpipe. No exhaust after downpipe Dp-tuner F5, No Start, Stock, 40 Tow, 80 Eco
1997 F-350, 2WD, 4.10, White, ZF5, CC, XLT, Downpipe, DP Tuner, No start, stock, 40 Tow, 80 Eco, 120 Race
2003 F-550, XLT CC 4wd, 4r100, Tuscany Automotive Starhauler Conversion. DP Tuner F5. 6.0 Trans cooler. DiPricol Optix Boost, EGT, Trans
lawnboy1988 is offline
Old 12-30-2007, 11:22 AM   #10 (permalink)
I am partial to a Case myself, Cummins 4BT motor, and damn near idiot proof. They also have alot less computer stuff than a bobuscatus. If a 743 Bobcat with a Kubota came up, that is another great machine. My buddy has a CAT, and it is nothing but problems(for 48K you think it would be flawless).
2000 F-350 4X4 Diesel Welding Rig
70' Lincoln SA200 powered by a Red Seal Continental
"Weld It And You Wont Be Screwed"
bigblue250 is offline
Old 12-31-2007, 07:11 PM   #11 (permalink)
dondiesel444's Avatar
New Holland, all I've ever had, all I'd ever buy [img]/forums/images/%%GRAEMLIN_URL%%/smile.gif[/img]
2001 F-250 PSD Crew Cab short bed, 4x4 Lariet, only 97k miles bone stock for now
previous trucks:
2001 F-250 PSD CC SWB 4" lift, 315's, DP Tuner..
late '99 F-350 PSD CC LWB 4" lift, 315's, DP......
early '99 F-250 PSD SC SWB short shifted 6-speed, 5" stacks, 5.5" lift, 4.30 gears, DP Tuner, etc....
1997 F-350 PSD 4x4, 4" lift, 35's, Superchips tuner
TRUCK PICS
dondiesel444 is offline
Old 01-01-2008, 01:09 AM   #12 (permalink)
We use a Bobcat 873 on our farm and it does all we expected and more. One important thing is the fact that our dealer also rents a wide assortment of attachments, more than the dealers for the other makes so this may of may not be a deciding factor for you to research. We have a snowblower for ours and it does a great job! It plays with our round bales, having no problem with the second row off the top of our semi trailers, always nice and stable on uneven ground and the grapple fork works well for manure. There are some days in the wet crap when I wish we had tracks!!
2008 F-250 Lariat SRW 4x4 CC SWB...
··· 6.4L & Torqshift w/3.73
··· Dark Stone Metallic / Pueblo gold
··· Readylift 3.5" levelling kit
... Toyo MT 315/70/18(bigger than 35-12.50-18)
----- --- BIG$HOW -------<Õ¿Õ¬
Bigshow is offline
Old 01-01-2008, 09:36 AM   #13 (permalink)
I had steel tracks that go over the tires (Grousers) on my 785 and my Lx865 and those machines would push like a 350 dozer!! for deep mud and deep snow you can't live w/o them once you've used them, they are incredible. the only bad thing about them is they cost over $2000, they tear up the grass, and if you use them on ice, watch out!!
previous trucks:
TRUCK PICS
Old 01-01-2008, 01:02 PM   #14 (permalink)
Have you had any experience with the rubber tracks that mount the same way? I heard they are lighter and easier to install and dont act like skates when you get on ice.
Bigshow is offline
Old 01-01-2008, 02:09 PM   #15 (permalink)
I haren't used them, I did know a guy that had them on a Case, he said they were better than nothing but there is no way they had the traction of the steel tracks. they seemed to do a better job of "floating" over the mud...
previous trucks:
TRUCK PICS
