Slightly off-topic (Onan question) - Diesel Forum - TheDieselStop.com
Old 09-07-2009, 10:26 PM   #1 (permalink)
I don't have a Super Duty (working on it though), but I've always been thoroughly impressed by the knowledge I've seen browsing this forum and used lots of Smoky's advice when buying a trailer to tow with my 2007 F150. My question has to do with an Onan generator (MicroQuiet 4000) that has been giving me trouble. Like I said, slightly off topic but you folks tow all the time so I figure you'd be the first to know what this problem could be. When I tried to start my generator, at first it cranked over for two 10 second attempts just fine but didn't start. Then, I try to start it again and it clicks very rapidly (Similar to a car with a tiny bit of juice left in the battery but not enough to crank it over), and now it just clicks once and you can hear the whine of a solenoid (I think) trying to force power into it to move it but it doesn't turn over at all. I hooked it up to the TV, directly into 120 from my house, and later tried it after I'd leached off of a friend's power and fully charged the batteries; with no luck. I'm thinking bad starter solenoid or the starter itself. I've cleaned all the contact patches to ensure proper flow and grounding, as well as checked fuel level and primed the carb before starting it. Has anyone else had a similar problem? Thanks a ton for any info you guys might be able to provide, and sorry for straying a little off-topic.
-Zac
408f150 is offline
Old 09-08-2009, 04:38 PM   #2 (permalink)
Flywheel's Avatar
My Photos: (6)
It might have a low oil shut off switch - so check the oil level.
99.5 F-250 CC LB 4x4 7.3 Red New Pics 1/5/10
Trail Boss Replacement Bumpers, Tool Box, Headache Rack, Full Length Running Boards, Bilstien Shocks, BFG AT/KO 285/75x16E, 2003 Cup Holder, Marinco Heater Plug, Weather Tech Rain Vents / Hood Guard, B&W GN Hitch, X-Springs, Rear 4" F350 Blocks, Hellwig front and rear sway bars, Timbrens, Duraflaps
Isspro A-Pillar Gauges, Isspro TTM, Ford AIS, Magnaflow 3.5" DP - 4" Exhaust, Garrett GTP38R Turbo, Turbo-Master, High Flow Outlet, Non EBV Pedestal, IH Up-Pipes, DS 203 degree Stat, DS Boost Relief, BTS Tranny, 6.0L Tranny cooler, DP-Tuner F5, DieselSite HPX
99 F-250 CC SB 4x4 7.3 White
Ranch Truck, Ranch Hand Bumpers, Original Cup Thrower, B&W GN Hitch
Autoenginuity
Flywheel is offline
Old 09-08-2009, 05:10 PM   #3 (permalink)
johnm's Avatar
My Photos: (148)
if its water cooled it may have a low fluid level switch also
jm
100% Disabled Viet Nam Veteran (Agent Orange and its' complications)
SOMETIMES I'M ALL CAPS...BECAUSE OF MY DIABETIC EYE DEGENERATION
Pic under name is record holder high mileage vehicle. 3469.6 MPG. Built by UNLV Mechanical Engineering students.
2009 Mitsubusi Outlander SE - (24 MPG in town)
2004 VW Golf TDI - (42 MPG in town)
click on or cut & paste for forum rules
http://www.thedieselstop.com/forums/...=rula#faq_rulz
johnm is offline
Old 09-09-2009, 01:15 PM   #4 (permalink)
Is it possible it built up compression from the first attempts, and you need to bleed the compression off by taking out the spark plug?
Also, make sure the battery cables are clean and tight.
I have an older (circa 1994) pull-start generator, and I had problems with it running for a while, then starving for fuel (even with a full tank and a fresh fuel filter). I ended up having to suspend my fuel line to make sure that the fuel filter and line were higher than the inlet to the carburetor to keep it from developing an air bubble. just my .02 cents worth
short_stuff
Y2K F250 CC PSD Auto, Short-bed Lariat, Woodland Green/Gold, ordered 07/10/99, born 09/12/99, delivered 10/08/99, Access bed cover, Bed Rug, Zoodad mod, Viper Remote Start Alarm, Fumoto valve, 103K somewhat error-free miles (so far) [never back to dealer for anything]
Repairs: CPS, Water Separator Valve assembly, rear axle bearings, VSS, batteries, brakes, alternator, serpentine belt (x2), driver door pwrlock actuator, water pump
2009 VW Tiguan 2.0 l turbo 200 hp gas engine (TDI engine not available for it yet)
short_stuff is offline
