Stuck disc brakes on boat trailer - Diesel Forum - TheDieselStop.com
Old 09-08-2009, 06:33 AM   #1 (permalink)
Can someone give me a crash course run through on lubricating and releasing the brakes on my boat trailer. It's been sitting dormant too long and brakes appear to be dragging. They are Tie Down surge stainless disc brakes. I've got a diagram of all the parts, just not sure what to do. Thanks, Nick. Attached what I'm looking at for a diagram.
1996 F250 4x4 ext. cab, long bed 5 spd. 3.55ls, Tymar Intake, Tymar 4" downpipe and 4" exhaust. AIC, B&W turnoverball, EBPV brake, tranny temp gauge, boost gauge, and egt gauge. 2.5" axle drop bracket, F350 springs up front, and F350 rear axle blocks. 260k miles. RETIRED.
NEW (to me) 2005 F350 FX4 Crewcab shortbed, SRW, Lariat, auto, V10. 5600 lbs front end.
NickKent is offline
Old 09-08-2009, 08:26 PM   #2 (permalink)
DIESELDUTTON's Avatar
I normally spray the pistons with penetrating oil, then try to free them up with a pry bar. Most of the time the wheels will turn if you can get some weight on the trailer, at our yard we just use the forklift and set a boat on the trailer which makes it easy. Also remember disc brakes will lock up in reverse unless you power up the solenoid or put a pin in the surge brake hitch so it wont go in when backing up. Good luck
Frank
http://community.webshots.com/user/dieseldutton
2004 Pitbull Motorsports rigid chopper
121 TP 130rwh 250 avon
04 CRF250 mine
02 CR80 sons
03 XR100 daughters
425 Polaris magnum
500 Polaris sportsman and 300 lakota everyones
1998 27.5 Wilderness 5th wheel
DIESELDUTTON is offline
Old 09-09-2009, 01:45 PM   #3 (permalink)
I had to take the whole caliper off by removing the mounting bracket and then hammer the stainless bolts loose so I could get everything apart. Pads are toast. Not sure about the calipers though. I can clean up the exterior, but there isn't any way to really tell if the interior is ok.
NickKent is offline
Old 09-11-2009, 06:45 AM   #4 (permalink)
Update. I'm not going to bother screwing around with the calipers. tie down system. They suck. Stay away. Get Kodiaks.
NickKent is offline
