Sump pump to power lawn sprinklers - Diesel Forum - TheDieselStop.com
Old 06-19-2009, 06:13 PM   #1 (permalink)
We have recently installed a rain barrel and would like to be able to use it to feed a lawn sprinkler. I think I will just get a submersible pump to power the water, but how many GPM will I need to make the sprinkler run?
2002 F350 CC, SB XLT 6spd, Luk clutch, 285/75R16 Goodyear Wrangler Silent Armor
4" Magnaflow Turbo Back Exhaust
DP Tuner: 80econo, 60econo, 40tow high Idle
gjs1 is offline
Old 06-19-2009, 06:58 PM   #2 (permalink)
chuckster57's Avatar
Last time I bought a replacement sprinkler for my lawn the flow rate was printed on the box. If you know the make and model of the sprinkler, maybe a trip to HomeDepot or Lowes might yield the info on another box. What type of sprinkler is it?
1997 Jayco 323RKS fifth wheel w/2 slides, Air Lift 5000 bags
Train Horns: Pictures here
PM please not visitor message
chuckster57 is offline
Old 06-20-2009, 01:55 PM   #3 (permalink)
My Photos: (11)
Will the sump pump provide adequate pressure at the volume required? Sprinklers usually require 40 to 50 PSI to reach full flow.
2010 Ram 3500 Cummins, AT, 4x4, CC, LB, Line-X, B&W Turn Over Ball, RBW Lil Rocker modified to fit B&W, Milemarker hyd. winch. Elkhorn 9VS slide-in, Nomad 24 ft. fifth/w slide, Century topper, old classic Sooner 18' 4 horse stock trailer. StarFlyte by DynaMax 6.8 V10.
Formerly: 97 F-250 SC LB PSD. 4x4, With lots of Goodies. Twas a good truck.
If you don't care where you are, you ain't lost.
Larry
Larry S. is offline
