Tandem axle pickup conversions? - Diesel Forum - TheDieselStop.com
post #1 of 15 (permalink) Old 03-14-2008, 01:22 PM Thread Starter
Does anyone know of any companies or places to buy components to complete a tandem axle conversion for a pickup? Could be a non powered or powered axle. Thanks
As of 4/23/2012, Dieselless for the first time in over 8 years.... Sad day.
gjs1 is offline
post #2 of 15 (permalink) Old 03-17-2008, 09:51 PM
usa6x6.com
JSchuricht is offline
post #3 of 15 (permalink) Old 10-07-2008, 07:39 PM
i was wondering if you ever found a kit, i don't offer a kit but i can build a tandem set-up
hart is offline
post #4 of 15 (permalink) Old 10-08-2008, 03:53 PM
SmokeyWren's Avatar
My Photos: (45)
Originally Posted by JSchuricht View Post
usa6x6.com
No longer an active website:
This domain has temporarily been disabled. To restore the domain, contact your Customer Support.
www.usa6x6.com
SmokeyWren is offline
post #5 of 15 (permalink) Old 10-08-2008, 04:45 PM
USA 6x6 went bankrupt!
UApilot
2008 Dodge QuadCab 2500 Big Horn, CTD, 4x4, auto, tube steps, clearance lights, on-board air, air horns, air-ride coming. 300hp/540lb.ft. stock
2006 KTM 950 Adventure S
UApilot is offline
post #6 of 15 (permalink) Old 10-11-2008, 03:14 PM
My Photos: (9)
Since none of them seem to use a power divider (inter axle differential) we could never figure how they keep from eating tires and diff parts. (They must but no one probably drives their custom truck that much. If you custom mounted one of those old New Process 2xx full time 4wd cases somehow, you could have a power divider. Also deep reduction and lockout.
Birken
Birken Vogt is offline
post #7 of 15 (permalink) Old 01-20-2010, 09:45 PM
Info wanted
Im looking to put a tandem setup on my 2005 Dodge Ram 2500 Cummins. It you can provide me with some information it would be greatly appreciated. My email is jkjohnso87@hotmail.com Thanks
jkjohnso87 is offline
post #8 of 15 (permalink) Old 01-22-2010, 10:29 PM
Wat would you charge to build a tandem axle setup?
post #9 of 15 (permalink) Old 01-22-2010, 11:35 PM
Birken
Big trucks use to use them a lot in the 70s. They didn't eat tires or diff parts very bad. They got stuck on anything but wet pavement. It would be alot better if you could find some kinda of axle with a through shaft and power divider.
equipmentguy is offline
post #10 of 15 (permalink) Old 01-31-2010, 07:49 PM
SIC-E's Avatar
usa 6x6 used to use a spliter and installled a corp. 14 bolt rearend with lug pattern to match rest of truck. they were finallizing a sick airbagged system to sell as kits when they went down. went to OK to check'em out. kit woulda had awesome articulation and ride. they just couldn't get their operation together. too unorganized and too many production issues. other's are dong this tho not as dedicated to it specifically. several in mags. google and see what ya find.
2004 E450 Cutaway, 6.0L, quigley 4x4, ambulance pkg., maxbrake controller, curt 20k fifth wheel. Future mods: 52" sleeper, tandem (6x6?) rear (aint look'n likely
), frame cover. maybe a Herd front bumper.
2003 E350, 7.3l, x-cargo
2003 F350 Lariat, 4x4, CC, SRW, Dark Green Fx4 SOLD
1995 C3500 6.5l work trk, 2x4, CC, DRW, white DECEASED PREMATURALLY
2003 JEEP WRANGLER, ooooops, not anymore!
1986 26' Seaway Northstar w/ 454 Mercruiser
2008 Montana Mountaineer 332PHT
1991 GMC Topkick, CAT, 4' vert. gang boxes, 12' dump. if only all were as reliable!
SIC-E is offline
post #11 of 15 (permalink) Old 02-03-2010, 05:26 AM
magusjinx's Avatar
If it is just a suspension issue and not necessary to be a drive axle why not just use a duplicate axle like the original and mount it behind like a twin axle trailer? ... Basically give you a spare rear end ...
magusjinx is offline
post #12 of 15 (permalink) Old 02-17-2010, 06:02 PM
batkerson's Avatar
I just saw one go through Reese Michigan on Friday. Complete with modified box and everything. I was on my way home after work and did not chase him down to see it.
1995 F-250 4X4 SC LB E40D 4.10 LS: gutted EBPV, tru-cool 4590 trans cooler, ISSPRO Trans., PYRO and Boost gauges, 3"-4" down pipe, 4" exhaust , Tymar intake, Bilstein 5100s, Silver Star Ultra headlights, 4-position switch (stock, high idle, economy and towing), rebuilt trans (myself).
batkerson is offline
post #13 of 15 (permalink) Old 03-10-2011, 10:30 PM
I'm building one now... since mine is already a 4x4 dually, I'm simply adding a second tag axle with airbags... if I ever get stuck I can go into 4x4.
I'm stretching the frame and running semi fenders that go from the front axle all the way back covering the rear axle... just like a std tractor.
I'm going to build a headache rack and run stacks like a semi. Oh, the tag axle will have brakes and carry 1/2 the load over the rear axles.
I have a 18,000 B&W fifth wheel and gooseneck ball...
If I get good response, I'll start doing these conversions...
PS been doing all kinds of custom fab vehicles for 25 years.... www.jd3.com I also moved my front axle forward 3 inches on my 2009 dually... pics on my site.
238mph is offline
post #14 of 15 (permalink) Old 05-06-2011, 02:43 PM
zz tops's Avatar
Ok I am in collage for classic car restoration. I want to build a street rod using a 35 ford pickup I understand that I will have to build a stronger frame is there a way to build it with driving tandem axle. When it is all said and done there will be pics to follow but till then i need to know if everthing planed is possible. Thanks anything will help
zz tops is offline
post #15 of 15 (permalink) Old 11-25-2015, 06:54 PM
Can you do a 6x6 setup on a 2003 mercedes g500? Email me hollyhoodkang@gmail.com
hollyhoodkang is offline
  Diesel Forum - TheDieselStop.com > Other Topics > Other Technical Questions
