Tile and bathroom guys, what do you recommend to fix this? - Diesel Forum - TheDieselStop.com
Old 01-02-2008, 10:57 AM   #1 (permalink)
My Photos: (5)
I bought this place 9 years ago and at that time I decided to use some caulk between the tile floor and the one-piece tub and surround. It has cracked over the years. What is typically used between the floor and bottom of the tub. Please look at the pics. Sorry about the piece of my wife's hair, didn't see it when I took the pics.
http://good-times.webshots.com/photo...41641901QEtYGa
http://good-times.webshots.com/photo...41641901XPXmeW
2002 F-250, PSD 6-speed, CC, short bed, 4X4, Toreador Red w/ Silver accent, A.R.E mx cap, Weld Super Single II and 33s in the summer, x-springs, F-350 blocks and badges, AIC, proflaps, ITP intank mod, AirDog with 3 micron filter, isspro guages and TTM, scangauge, husky liners, alarm, xm stereo,stull 5399-p grille, centramatics, ccv mod, AIS Air Filter, Southbend CON O, Detroit Truetrac LSD, coolant filter, 203 stat with billet housing, blackcloud intake heater plug/boost fitting, reese titan hitch, fabcraft PTO cover/temp sender port, prodigy brake controller, ITP Boost Annihalator, oilguard bypass filter, Mag-Hytec rear dif, bilsteins, hellwig rear stabilizer bar, ATS housing, non-ebpv pedistal and exhaust flange, magnaflow 3.5dp exhaust, ITP reg return, turbomaster wastegate controller, and ceramic coated bellowed up pipes, PHP 50t and 80p, currently 96,100 miles. truck Pictures
clydesdale is offline
Old 01-02-2008, 12:34 PM   #2 (permalink)
VCRacing's Avatar
Re: Tile and bathroom guys, what do you recommend to fix this?
i'd clean out the old caulking and go with a 100% silicon caulk. Theres not much else that i know of that will solve your prolbem. I have seen some stuff that is a Caulking tape . I have no experience with it, but When i remodeled our Master bath 2 yrs ago, i used the 100% silicon and it still looks as good as the day i applied it.
Ya'll buckle up and pull them belts tight, its gonna get rough..
Mine :01 F-350 CrewCab Lariat 4x4, 7.3 PowerStroke, auto, ShortBox. Mods: 3-Gauage A-pillar W/ Autometer Lunar Guages: boost,pyro,trans; DIY Tymar, Muffler Delete, Galaxy DX-33 Radio W/ Wilson 1000, and Optima RED TOP's, Centramatics, Lund Soft Tonneau
Play:
'82 Ford Bronco 302, auto, Galaxy 33v, Wilson 1000
04 Yamaha G22 E , Jake's Long travel lift kit, Fairway Alloy "Hazard " wheels , 23" EFX Blade tires, Jake's SST Safari Bar and Rear Tube bumper.
Color : PPG Orange Crush Pearl w/ Hi- Gloss Black trim ....
Hers: 00 Pontiac Trans Am, (stock)LS1, auto, T-tops.
VCRacing is offline
Old 01-02-2008, 05:44 PM   #3 (permalink)
I would agree that it just needs to be cleaned out really well and recaulked. I've done quite a few of these, nothing hard just time consuming.
If it's worth doing it's worth doing right!!
2002 F-250 PSD CC Lariat AIC, AIS filter, Cat delete, Coolant filter.
amb2958 is offline
Old 01-02-2008, 06:32 PM   #4 (permalink)
My Photos: (5)
What do you recommend to clean it out? Any particular type of scraper? I assume caulk is the way to go and not grout, since it sort of needs to be flexible with the tub. Thanks
Old 01-02-2008, 06:39 PM   #5 (permalink)
I just had to do mine a couple of weeks ago around the shower pan. I used a small chisel to carefully work the old grout out. After cleaning all the loose stuff up, I put down a bead of white silicone caulk all the way around the floor pan. You can use baby oil on a rag or paper towel to clean up any smudges.
btw, they make a dremel tool attachment to remove grout, but in your place, I would just try a small chisel. Just be careful not to gouge the tub, and be patient with the progress.
short_stuff
Y2K F250 CC PSD Auto, Short-bed Lariat, Woodland Green/Gold, ordered 07/10/99, born 09/12/99, delivered 10/08/99, Access bed cover, Bed Rug, Zoodad mod, Viper Remote Start Alarm, Fumoto valve, 103K somewhat error-free miles (so far) [never back to dealer for anything]
Repairs: CPS, Water Separator Valve assembly, rear axle bearings, VSS, batteries, brakes, alternator, serpentine belt (x2), driver door pwrlock actuator, water pump
2009 VW Tiguan 2.0 l turbo 200 hp gas engine (TDI engine not available for it yet)
short_stuff is offline
Old 01-02-2008, 07:26 PM   #6 (permalink)
use a hook knife to clean it out. vac it out clean and use mild bleach to get out any mold and let it dry. use penoseal or silicone type 2. any questions let me know.
1997 f-250. 3" down pipe with 4" bully dog exhaust, edge plug in- maxed out, KYB, flatbed with BF goodies M/T,air bagged out and can tow anything.
spaz1 is offline
Old 01-03-2008, 01:11 PM   #7 (permalink)
I generally use a 5 in 1 painters tool, razor blade, and hook knife. Anything you can use that will fit in there. Also you can try to cut it along the bond surface (tub to tile) and pull it out in chunks.. sometimes it will come out in large pieces.
amb2958 is offline
Old 01-03-2008, 10:17 PM   #8 (permalink)
Going_Going_Gone's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: clydesdale</div><div class="ubbcode-body">What do you recommend to clean it out? Any particular type of scraper? I assume caulk is the way to go and not grout, since it sort of needs to be flexible with the tub. Thanks </div></div>
I think that Lowes or H/D carry a set of steel picks (like a dentist uses only slightly larger). They work great--especially for removing old caulk and silicone caulk.
December, '02 build F-250 CC 4X4 Lariat 6.0/Torqshift,Toreador Red over Arizona Beige 4X4 FX4 w/ moon roof. Stull grill insert, chromed tow hooks/bed tie downs, painted door handles, King Ranch flares, '08 aluminum differential cover, Inyati bed liner, Edge 3" lift Bonspeed eight spoke wheels w/BFG AT KO 305/65R18s Pics http://community.webshots.com/user/going_going_gone
Going_Going_Gone is offline
Old 01-03-2008, 11:11 PM   #9 (permalink)
88beast's Avatar
also they make curved razor blades which ive found work great get one that curves out and another that goes in youll be fine
88 F-250 body,550 rear frame setup, 7.3 idi, back up camera, class 5 bumper hitch welded to frame and gusseted, front mount hitch and off road lights,93 front clip, headache rack, 37" humvee tires, ac power converter,factory buckets from quadcab, power windows and locks,cobra 29 cb w/ 102" whip, high lift jack behind seat, toolbox for the junk, visor, running lights, huge front bumper, oba,
in progress western style mirrors, holset turbo, airhorns, and some other goodies
88beast is offline
Old 01-04-2008, 02:02 PM   #10 (permalink)
Me, I'd use a product called Pro-Flex by Geocel. I just hate silicons, period. If, or I should say when you have to do it again it will be much eaiser to remove the PF than the silicone. PLUS, if for some reason you have to paint, paint won't stick to silicone.
Paul B
2001 Excursion Limited PSD,2wd,Auto. Toreador Red,10/2000,4.5 Racor,unTAGed,203*,DP-Tuner,AIS Filter,Riley Coolant Filter,6.0 cooler,Cat ELC,Son/Tri,Underdash Lunar Gauges,Hadley Air Horn,On Board Air,Fumoto,2006 31' Flagstaff TT 6.5K,Prodigy
2000 Honda CRV EX
PIC'S
pabrannan is offline
Old 01-07-2008, 07:14 PM   #11 (permalink)
Atlantaboy's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: VC_Racing</div><div class="ubbcode-body">i'd clean out the old caulking and go with a 100% silicon caulk. </div></div>
That's what did when we tiled our bathrooms. A real wide bead.
2001 F250 CC 4x4 (Blown motor @ 148k)
Garmon's Diesel Performance (bang bang bang)
01' F250 CC 7.3
6.5" ProComp on 35's Motometal 951's
03' headlights/corners, billet grill, Alpine/XM
16.5:1, Mahle's .0050 with harden forged
Comp 910's, 4130 pushrods, Mac/K&N
H11 studs, HT turbo, DP tuned,
Bean's singles/plentums, DI's fuel system
Mag-Hytec cover, Autometer gauges
Built trans with Red Altos/Mojo VB/PI triple disc.
My Rig
Atlantaboy is offline
