Go Back   Diesel Forum - The Diesel Stop.com > Other Topics > Other Technical Questions
Other Technical Questions Discussion of other technical topics. Please see the sticky post at the top of the thread listing for specific rules. The rules for this forum are more restrictive than they have been in the past. Topics will expire automatically in 60 days.
Old 09-15-2008, 10:32 PM   #1 (permalink)
Towing Capacities
My son's friend has a 04 Chevy 1500 Extended Cab 2WD SB. He is looking to purchace a travel trailer. We were looking for weight capacities, after looking on a couple of sites I said TDS was the place for the answers.
So if ya don't mind... What size/weight trailer would be recommended without going over the safety limits for his truck?
Thanks!
2000 F350 SD 4X4 CC LB Lariat
4"DPPI Turbo back
aFe Magnum
50/80/110 Bill's flip chip W/PMT1,and a DP 120
A-Pillar Autolites Trans/EGT/Boost-GOS Racing
APCM(AIC)
Boost Bleed off
4" Lift W/315's
Dual alt's.
ATS housing
Wicked Wheel
Banks 1.0 A/R housing
ISSPRO TTM
Warn Premium Hubs
J/S IDM
Racor 4500 CCV
ARG SuperPump and Gear
GOS Racing-Head Light Harness
2004 Sprinter 292FWRLS
SOLD: 97 F250HD CC SB 4X4 7.3L E4OD 4.10
drdenny1 is offline
Old 09-15-2008, 10:43 PM   #2 (permalink)
chris u's Avatar
What motor and tranny does he have? I have a half ton gmc 4X4 with a 350 and a five speed manual and it pulled a 5000 pound travel trailer with no problems I did put a extra set of springs in the rear because I also haul my 4 wheeler in the back hope this helped some.
97 F 250 4 inch lift with toyo LT 285/75/16 tires on ultra 16/ 10 wheels. Five speed manual transmission. Edge evolution programmer set on level 2 race. MBRP 4 inch turboback exhaust DYI 6637 intake and s&b cold air intake still trying to
decide what to use, ISSPRO pillar mounted gauges and a nice stereo system not going to list all that.
2007 chevy cobalt K&N cold air intake,Eibach prokit springs and 205 50 ZR 17 BFG g force sport tires on Konig wheels. With a sound system that will make you deaf.
2004 polaris sportsman 700 twin EFI with ITP 589 tires.
2001 honda cr 500 last year of the big 2 stroke.
98 polaris rmk 700 with big bore and way to much to list.
97 rmk trail 500 a little clutch work.
2005 ford focus ZX4 wifes car. Totaled 10/08
07 Mazda 6 wifes new car.
2000 F150 5.4 auto wifes truck
chris u is offline
Old 09-15-2008, 11:02 PM   #3 (permalink)
4.8L Auto Trans.
4"DPPI Turbo back
aFe Magnum
APCM(AIC)
Boost Bleed off
4" Lift W/315's
Dual alt's.
ATS housing
Wicked Wheel
ISSPRO TTM
Warn Premium Hubs
J/S IDM
Racor 4500 CCV
drdenny1 is offline
Old 09-16-2008, 10:14 AM   #4 (permalink)
chris u's Avatar
I am not sure what the weight limit is, it should say in the owners manual or on the truck inside the door or under the hood. I would recommend a brake controller and a light weight trailer around 17 to 19 foot and a tranny cooler if it doesnt have one. Even with that wont be very fast in the hills and depends on the gearing. Good luck.
chris u is offline
Old 09-16-2008, 10:45 AM   #5 (permalink)
MarkEkberg's Avatar
My Photos: (13)
I think most small 1/2 tons are rated to 8K worth of trailer. That is with trailer brakes and a leveling hitch.
MarkEkberg is offline
Old 09-16-2008, 11:35 PM   #6 (permalink)
SmokeyWren's Avatar
My Photos: (33)
I know zippo about bowties, but I assume it's competative with the F-150.
F-150 max trailer weights depend on rear axle ratio, cab, engine, wheelbase (or bed length)and 4x4/4x2. The comparable F-150 is a 2004 SuperCab 4x2 shorty with 4.6L engine. Max trailer weights are:
Code:
axle    GCWR    Max tag
                trailer weight
3.55   11,700   6,300
3.73   12,200   6,800
Those numbers are max, and assumes there is absolutely nothing in the truck except one skinny driver, so the truck grosses no more than 5,400 pounds before you tie onto the trailer. No tools, no jacks, no bedliner, no luggage, no cooler, no passengers, no pets, nothing. So for most of us, if we don't want to be overloaded when we reach the CAT scale, we have to subtract about 1,000 pounds from those max weights because we have other stuff in the truck besides one skinny driver.
If it were my grandson, I'd advise him to not even look at trailers with a GVWR over 5,500 pounds to tow with that truck. That just about rules out all the regular and even the "lite" travel trailers. So look at pop-ups. My camper was a pop-up "tent" camper from 1968 until about 1992, with a GVWR a lot less than 5,000 pounds. We drug that camper all over the USA, coast to coast and border to border. It was a lot better than the tent we had before we bought the popup.
SmokeyWren is offline
Old 09-17-2008, 02:10 AM   #7 (permalink)
THEBUNDO's Avatar
My Photos: (13)
Maybe he needs to get an old Oldsmobile
THEBUNDO is offline
Old 09-17-2008, 02:47 PM   #8 (permalink)
SmokeyWren's Avatar
My Photos: (33)
Yep. Way back when, I had a new '65 Olds Delta 88 with the 454-or so premium-gas "Rocket" engine. Later as my commuter car I had a used 7-years-old '63 Ninety-Eight with a similar huge gas-gulping engine. Lots of power for dragging a trailer. Modify it by adding good shocks and an oil cooler, and it would tow a good-sized trailer cross country. But it got only 8 MPG without towing and about 5 MPG when towing. On "premium" gas. And I didn't try to drag anything over 5,000 pounds back then. So no thanks, I'll stick with my ole '99.5 PSD. It gets over 11 MPG when dragging an 8,000 pound 5er.
