welding cast steel - Diesel Forum - TheDieselStop.com
Old 01-01-2008, 07:52 PM   #1 (permalink)
welding cast steel
I have some fertlizer brackets for a planter that are cast steel and one needs welding. What does it take for rods and prep to weld it? Thanks Kurt
1990 F-250 4X4 ATS turbo 5 spc 165,000
Nebraska_Farmer is offline
Old 01-02-2008, 01:12 PM   #2 (permalink)
My Photos: (27)
Re: welding cast steel
Depending on the size and other factors, many times we had better luck brazing rather than using cast rod. Also depending on size, etc, you have to preheat the casting then cool it REAL slow to avoid cracking.
'91 F-250 SC 4X4, 5spd. ATS Turbo http://sports.webshots.com/album/180135797kNEIOu
LMJD is offline
Old 01-02-2008, 01:28 PM   #3 (permalink)
Use nickel rods and work very slowly, "stitching" the repair and allowing time for the temperature extremes to level out some. If you work too quickly, the cast iron will expand from the heat and will then crack. If possible, it is recommended to preheat what your going to weld in an oven to minimize the above problem.
I've fixed several broken cast iron things over the years and had pretty good luck. One small nit is the nickel rods are over a dollar each.
Good luck.
2001 Cab and Chassis F350 SuperCab DRW 4x4. 7.3L. 6spd & manual xfer. snow plow pkg.
DirtFarmer is offline
Old 01-02-2008, 02:07 PM   #4 (permalink)
MarkEkberg's Avatar
My Photos: (13)
Isn't that called "White mettal"?
If so,and if it has to bear any weight welding will not hold unless you can reinforce it very well by plating and bolting.
UPDATED 1/1/09 Replace so far. 1 LUK flywheel+clutch, 2 thermostats, 2 set of brakes, 1 set of calipers, 5 CPS, 3 sets of tires, 2 Transfer pumps, 1 Injector modual, 1 Computer, 2 Alt, 2 sets of batteries, 1 Water pump, 6 Belts, 1 PS hose, 2 Sets ball joints, 2 set u-joints, 2 carrier bearing, 2 Speed sensors, 1 oil pres sender, 1 temp sender, 4 sets of e-break cables, 1 front fuel tank, 2 rear fuel tanks, 2 set of glow plugs, 7 Glow plug relays, Oil galley o-rings, Turbo pedistal o-rings, EBPV o-rings, 3 sets of Injector O-rings, 1 Vac-pump, 1 new carpet, 1 total paint job.Total $$$ in repairs v/s miles driven = 4.6 cents per mile. Add fuel to that it jumps to 16.5 cents per mile over the life of the truck.
MarkEkberg is offline
Old 01-02-2008, 02:47 PM   #5 (permalink)
Guys - He says it's cast STEEL. There's still a few steel casting foundries left in this country. One I used to work for welded stuff every day. Depending on alloy which on a planter depending on color could be anything from cast mild steel to cast alloy steel I'd start with something like 7018, or maybe a higher tensile low hydrogen rod like 10018. Foundry I worked at used a LOT of 11018. They'd buy it by the pallet. Pre-heat is also required and draw the hardness out of the weld afterwards with a torch to cool slowly. Depending on how thick the part is where You have to weld it You probably want to "VEE" the area to be welded to increase penetration.
If it's really cast IRON that's a totally different animal. With the price of nickle rod now days I think I'd look for a new or used part in a salvage yard.
Denny
'96 F-250 Reg. Cab 4X4 5-sp POWERSTROKE
298,500 mi & NO Problems, LUK Clutch
Dr.Evil is offline
Old 01-02-2008, 10:47 PM   #6 (permalink)
Don't know about cast steel, but I've repaired cast iron stuff using a silicon bronze tig rod and it seems to work fine. I heat it up and cool down slow.
1996 F250 4x4 ext. cab, long bed 5 spd. 3.55ls, Tymar Intake, Tymar 4" downpipe and 4" exhaust. AIC, B&W turnoverball, EBPV brake, tranny temp gauge, boost gauge, and egt gauge. 2.5" axle drop bracket, F350 springs up front, and F350 rear axle blocks. 260k miles. RETIRED.
NEW (to me) 2005 F350 FX4 Crewcab shortbed, SRW, Lariat, auto, V10. 5600 lbs front end.
NickKent is offline
Old 01-03-2008, 01:49 AM   #7 (permalink)
johnm's Avatar
My Photos: (148)
read here for some help
http://www.esabna.com/euweb/oxy_handbook/589oxy16_1.htm
http://www.eng-tips.com/viewthread.c...=184452&page=1
100% Disabled Viet Nam Veteran (Agent Orange and its' complications)
SOMETIMES I'M ALL CAPS...BECAUSE OF MY DIABETIC EYE DEGENERATION
Pic under name is record holder high mileage vehicle. 3469.6 MPG. Built by UNLV Mechanical Engineering students.
2009 Mitsubusi Outlander SE - (24 MPG in town)
2004 VW Golf TDI - (42 MPG in town)
click on or cut & paste for forum rules
http://www.thedieselstop.com/forums/...=rula#faq_rulz
johnm is offline
Old 01-04-2008, 06:25 PM   #8 (permalink)
Cast steel welds like a dream, 7018 and you should be good to go.
2000 F-350 4X4 Diesel Welding Rig
70' Lincoln SA200 powered by a Red Seal Continental
"Weld It And You Wont Be Screwed"
bigblue250 is offline
Old 01-05-2008, 12:17 PM   #9 (permalink)
GEODON's Avatar
if it is cast steel use 7018
G3
hey there tozzi
'96 F-250, ext. cab, 2 wheel drive, long bed, AFE stage I intake, Baby Swamps, down pipe and 4" exhaust with cat delete, Edge Evolution (soon to be TS 6 position chip). works hard every day on the job hauling pipe and tools and then on the farm at night and weekends. the best never rest!
GEODON is offline
Old 01-05-2008, 09:01 PM   #10 (permalink)
88beast's Avatar
white metal is a no repair but its nothing like steel or iron
if its a way old part its iron but make sure first what it is and if you can call up the company and find the original alloy they used then any good welding shop can tell you how they would do it
and a v shaped cut will help a lot with future strenth
88 F-250 body,550 rear frame setup, 7.3 idi, back up camera, class 5 bumper hitch welded to frame and gusseted, front mount hitch and off road lights,93 front clip, headache rack, 37" humvee tires, ac power converter,factory buckets from quadcab, power windows and locks,cobra 29 cb w/ 102" whip, high lift jack behind seat, toolbox for the junk, visor, running lights, huge front bumper, oba,
in progress western style mirrors, holset turbo, airhorns, and some other goodies
88beast is offline
Old 01-06-2008, 12:16 PM   #11 (permalink)
Not trying to hijack this, but does anyone know what the front(and rear for that matter) superduty axle pumpkins (not the tubes) are made from-cast steel or cast iron? I tried welding a bracket to the front one the other day and it didn't take using 7018 rod. Any ideas? [img]/forums/images/%%GRAEMLIN_URL%%/eek.gif[/img]
2000 F250 PSD XLT CC LB 4x4 Autumn Red, AIS w/DPP Fender Mod, Pro-Comp 2" Leveling Kit, ARE 16x10 058's , 305/70/16 General Ameritrac TR's, Line-X, Delta Tool Box, Chrome GoRhino w2w nerf bar, Firestone Airbags, Stull Billet Grill, Gator Ramp, '01 Cupholder, '02 Headlights, APC Euro corners, Sonnax Valve w/Springs, Optima Batterys, C-BETR Mirrors, ITP Pre-pump/In-Tank, Harpooned, Amsoil Dual By-pass 15W-40, Dieselsite Coolant Filter w/custom bracket, Diesel Manor H/X, Dieselsite Heater By-pass
TomzToyz2 is offline
