Why is my New Holland TC 35 hard to start now that I changed the fuel filter? - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 10-10-2007, 12:33 PM Thread Starter
Super Duty John's Avatar
My Photos: (55)
I finally got around to changing my fuel filter in the tractor last week and now that I have, it's hard starting? It used to take about a half a crank and it started. Now it's let the glow plugs cycle and then a 10 second crank! It was bled after the filter was put in and the glass bowl is full? WTH?
BTW, the old filter was spotless....
John
2012 F-350 King Ranch 4x4 Crew Cab LWB dually
Super Duty John is offline
post #2 of 8 (permalink) Old 10-10-2007, 01:01 PM
Re: Why is my New Holland TC 35 hard to start now that I changed the fuel filter?
Sounds like you have a checkvalve stuck open that is letting the line bleed back to the tank.
If it's worth doing it's worth doing right!!
2002 F-250 PSD CC Lariat AIC, AIS filter, Cat delete, Coolant filter.
amb2958 is offline
post #3 of 8 (permalink) Old 10-10-2007, 01:03 PM
KINGTUT's Avatar
My Photos: (19)
Last time that happened on my Kubota it was nothing more than air. I called the tech at my dealership and he walked me through getting it out, once it was out, bam, right back to starting before you can get your hand off the key. If you know how to bleed it do it several times and I believe it will get you fixed.
KINGTUT is offline
post #4 of 8 (permalink) Old 10-10-2007, 01:33 PM
whitjo's Avatar
KingTUT is right on,
Air in fuel system. have had this problem many times with my old Bobcat SkidSteer.
Early '99 F250 SD, 4X4, SuperCab, Long Bed, 7.3L "PowerStroke" Diesel, Auto, PMT1 PCM w/DPTuner 80 tow, 190K miles,
Volant intake, ISSPRO gauges, BDS front leveling kit, 4" straight piped, Dick Cepek 18x9 DC1-Chrome, Nitto Terra Grappler 325/65R18,
Pro GOD, Pro Guns, Pro Life Important Notice, Pro Life changes when someone breaks in.
whitjo is offline
post #5 of 8 (permalink) Old 10-11-2007, 10:25 AM
My Photos: (9)
Probably air. Undoubtedly, this has been posted/addressed on the tractor forum bible... Tractorbynet.com. Looke 'em up.
Smokewagun is offline
post #6 of 8 (permalink) Old 10-12-2007, 05:08 AM
My Photos: (12)
Hmm...
I've had "air = No Can Start problems" with my JD450, too....but SDJohn's problem sounds a bit different. He's writing that it takes him all that to get it started....but that it does start. If he had air in his lines, but is (eventually) does run, wouldn't the running of the engine cause all that air to pass through?
Sold: 1999 White Lariat CC SB F-250. Sold to next-door neighbor in 2001....received final payment 2007! Still going strong at 198Kmiles as of Dec'07
Sold: 2001 Bright Amber Lariat CC LB F-250 with 4 million candlepower of LightForce lights in the bow. Line-X bedliner. Dual alternator. Clearance lights. Glass-tite cap. 250-gallon auxiliary tank for trips to the Lesser 48. 70-gallon auxiliary for trips around Alaska.
Rec'd Dec'07: '08 ForestGreen/Gold F-350 CC LB. Handshaker, as always, Rear stabilizer, rear static video, rear step, dual alternators. B&W turnover ball on its way; soon to be Line-X'd. LightForces on their way.
Alaska Ranger is offline
post #7 of 8 (permalink) Old 10-13-2007, 12:55 AM Thread Starter
My Photos: (55)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Alaska Ranger</div><div class="ubbcode-body">Hmm...
I've had "air = No Can Start problems" with my JD450, too....but SDJohn's problem sounds a bit different. He's writing that it takes him all that to get it started....but that it does start. If he had air in his lines, but is (eventually) does run, wouldn't the running of the engine cause all that air to pass through? </div></div>
Exactly, it didn't start off the bat till I did bleed the heck out of it the it's now hard starting. I've run this machine for about 4 hours since the filter change and it's still hard starting....
John
post #8 of 8 (permalink) Old 10-13-2007, 09:54 AM
whitjo's Avatar
On some older tractors that I have messed with, I had to eventually bleed each line where it connects to the injector itself. (This was usually after it had run out of fuel)
Have someone crank it over while you crack the fitting open SLIGHTLY and watch for air coming out.
The air will EVENTUALLY work its way out on its own, but it may take a while.
whitjo is offline
  Diesel Forum - TheDieselStop.com > Other Topics > Other Technical Questions
