windshield removal - Diesel Forum - TheDieselStop.com
Old 08-12-2009, 08:16 AM   #1 (permalink)
88beast's Avatar
windshield removal
on the truck in sig
how do it do it i just need to fix a leak in the sealer
mostly i need the trim off
88 F-250 body,550 rear frame setup, 7.3 idi, back up camera, class 5 bumper hitch welded to frame and gusseted, front mount hitch and off road lights,93 front clip, headache rack, 37" humvee tires, ac power converter,factory buckets from quadcab, power windows and locks,cobra 29 cb w/ 102" whip, high lift jack behind seat, toolbox for the junk, visor, running lights, huge front bumper, oba,
in progress western style mirrors, holset turbo, airhorns, and some other goodies
88beast is offline
Old 08-12-2009, 09:28 AM   #2 (permalink)
chuckster57's Avatar
It's been a while, but IIRC there is a locking bead in the middle of the seal. It will be on the outside of the windshield seal.
1997 Jayco 323RKS fifth wheel w/2 slides, Air Lift 5000 bags
Train Horns: Pictures here
PM please not visitor message
chuckster57 is online now
Old 08-12-2009, 10:20 AM   #3 (permalink)
88beast's Avatar
ya like a clip ? so its just put some force into it?
88beast is offline
Old 08-12-2009, 10:43 AM   #4 (permalink)
Don't ue a lot of force or you'll be buying a new windshield. I believe the center of the seal has a pressed in bead. Look for the seam where the two ends of the bead come together. then using a flat screwdriver, lift it out. Make note of where the ends are in relation to the window. After that I believe the winsheild seal will collapse into the the glass for removal. When you go to re-install it, use a long piece of cord in the outside "well" of the seal. then as you pull the cord it will pull the seal past the body seam. Then just press the center bead back in and the seal is locked in.
Old 08-12-2009, 10:51 AM   #5 (permalink)
88beast's Avatar
oh im not changing the seal too much time im just putting the black gunk in there but thanks anyway
its only 2 spots i think and theyre small leaks in the right driving wind
88beast is offline
Old 08-12-2009, 10:54 AM   #6 (permalink)
If you get the center bead out, it will allow you to manipulate the windshield seal so that you can put the goop in where you need to. The glass won't fall out.
Old 08-12-2009, 11:45 AM   #7 (permalink)
88beast's Avatar
ok thanks that seems like itll work
88beast is offline
