Go Back   Diesel Forum - The Diesel Stop.com > 2008-Up Super Duties > 6.4L Power Stroke Engine and Drivetrain
6.4L Power Stroke Engine and Drivetrain Discussion of the 6.4L Power Stroke diesel engine and drivetrain in the 2008 Super-Duty trucks. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
Old 10-25-2007, 12:43 AM   #1 (permalink)
D_L
08 F-350 Harley Davidson 6.4L
I ordered a F-350 HD fully loaded this past Friday. Should be at my local dealer in 12 -14 weeks?? Ordered 3.73 LS gear, What MPG should I expect? 1-2 MPG less than a F-250?
Anybody know anything about Real Power, offered by Ford Commercial Truck Parts. It's an A/C generator mounted between the frame rails of the truck with a Power outlet box in the bed of the truck. I will sometimes tow my Lightning to the track and a 7 x 16 Enclosed Motorcyle trailer that has a 13000 BTU Heat / A/C unit on the roof. I have a Breaker panel in the enclosed trailer with a 220V cord. Thought it may come in handy to have a Generator permanently mounted in the bed.
What you guys think? Thanks
Real Power
08 F-350 6.4L Harley Davidson
01 F-150 Lightning, Bad to the Bone'
08 Big Dog K-9 EFI "Poison Ivy" paint
D_L is offline
Old 10-25-2007, 09:34 AM   #2 (permalink)
SmokeyWren's Avatar
My Photos: (33)
Re: 08 F-350 Harley Davidson 6.4L
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: D_L</div><div class="ubbcode-body">I ordered a F-350 HD fully loaded this past Friday. ...Ordered 3.73 LS gear, What MPG should I expect? 1-2 MPG less than a F-250? </div></div>
There is no longer an "F-350 HD" available. If you mean F-350 DRW with the standard 3.73 open rear axle, then it should get slightly less MPG than an identically-equipped F-250, only because it weighs more and has more drag from the two extra tire patches on the road. However, MPG is a lot of "luck of the draw". Some F-350 DRWs get better MPG than some F-250s, and vice versa.
If you meant F-350 SRW, then there should be no difference in MPG compared to an identically-optioned F-250.
<div class="ubbcode-block"><div class="ubbcode-header">Quote:</div><div class="ubbcode-body">What you guys think? ... Real Power </div></div>
There are two flys in the ointment.<ul>[*] If you ordered the truck with automagic tranny, then you had to also order the "PTO provision". On stick shifters, the PTO Provision is standard, i.e., free.[*] Be prepared for sticker shock. The small Real Power generator puts out 12 KW. That is more than enough to power even the biggest RV trailer with two 15,000 BTU AC units, but it's not cheap. Count on several thousand dollars.[/list]I don't know anything about that brand, but PTO-powered generators have been installed in work trucks for years. For example, oil field well-service trucks with PTO-powered generator, air compressor, winch, etc., are common around here. They first install a PTO and hydraulic pump, plus tanks for the required hydraulic fluid. Then they install the generator that is powered by a hydraulic motor. The generator can be mounted almost anywhere, but most of them are in a side compartment of a service body. Some are under the frame of the truck, similar to the Real Power unit.
SmokeyWren is offline
Old 10-25-2007, 10:26 AM   #3 (permalink)
D_L
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: SmokeyWren</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: D_L</div><div class="ubbcode-body">I ordered a F-350 HD fully loaded this past Friday. ...Ordered 3.73 LS gear, What MPG should I expect? 1-2 MPG less than a F-250? </div></div>
There are two flys in the ointment.<ul>[*] If you ordered the truck with automagic tranny, then you had to also order the "PTO provision". On stick shifters, the PTO Provision is standard, i.e., free.[*] Be prepared for sticker shock. The small Real Power generator puts out 12 KW. That is more than enough to power even the biggest RV trailer with two 15,000 BTU AC units, but it's not cheap. Count on several thousand dollars.[/list]I don't know anything about that brand, but PTO-powered generators have been installed in work trucks for years. For example, oil field well-service trucks with PTO-powered generator, air compressor, winch, etc., are common around here. They first install a PTO and hydraulic pump, plus tanks for the required hydraulic fluid. Then they install the generator that is powered by a hydraulic motor. The generator can be mounted almost anywhere, but most of them are in a side compartment of a service body. Some are under the frame of the truck, similar to the Real Power unit. </div></div>
I was told like 4K for the unit and 1K for the install from dealer, I can save a bunch on the install and have it done myself on the side with a Ford Tech friend. I ordered the PTO option, just in case.
Still expensive, But, I need to buy a portable generator anyway, the ones I was looking at cost 3 - 4 K.
I'm not getting a dually. I just ordered a F-350 HD SRW, it is listed in the Ford brochure, You can buy a 08 F-250 or F-350 Harley Davidson SRW.
D_L is offline
Old 10-25-2007, 10:29 AM   #4 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: D_L</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: SmokeyWren</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: D_L</div><div class="ubbcode-body">I ordered a F-350 HD fully loaded this past Friday. ...Ordered 3.73 LS gear, What MPG should I expect? 1-2 MPG less than a F-250? </div></div>
I was told like 4K for the unit and 1K for the install from dealer, I can save a bunch on the install and have it done myself on the side with a Ford Tech friend. Still expensive. But, I need to buy a portable generator anyway, the ones I was looking at cost 3 - 4 K.
I'm not getting a dually. Hate to say you are wrong, I just ordered a F-350 HD SRW, it is listed in the Ford brochure, You can buy a 08 F-250 or F-350 Harley Davidson SRW.
</div></div>
Smokey is not wrong, just a little confused on the abbreviations. He is thinking HD as in Heavy Duty, not H-D as in Harley-Davidson.
As for the Real Power units, they are not cheap but work great. The have been well tested by both Ford and Real Power on the 08's. Ford had a couple of the pre-production 08's equipped with Real Power units.
'04 F-250 Harley-Davidson 6.0L CC SB
PowerStrokeHD is offline
Old 10-25-2007, 10:36 AM   #5 (permalink)
D_L
<div class="ubbcode-block"><div class="ubbcode-header">Quote:</div><div class="ubbcode-body"> Smokey is not wrong, just a little confused on the abbreviations. He is thinking HD as in Heavy Duty, not H-D as in Harley-Davidson.
As for the Real Power units, they are not cheap but work great. The have been well tested by both Ford and Real Power on the 08's. Ford had a couple of the pre-production 08's equipped with Real Power units. </div></div>
Your right, I figured out he was talking about Heavy Duty and edited my previous post. I met the District Dlue Diamond Parts Rep. at my local Ford parts dept. yesterday, we had a long talk about the real power units. My local parts dept. Mgr. said he would sell me one at cost. So I'm thinking about it.
D_L is offline
Old 10-25-2007, 10:48 AM   #6 (permalink)
It sounds like a nice feature, but for the size of the load, is probably overkill, most PTO,s that I know of raise the idle. I would think that a single or twin cylinder would use less fuel than any eight, let alone the noise. unless you needed a big generator. just a thought.
first_ford is offline
Old 10-25-2007, 09:48 PM   #7 (permalink)
D_L
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: first_ford</div><div class="ubbcode-body">It sounds like a nice feature, but for the size of the load, is probably overkill, most PTO,s that I know of raise the idle. I would think that a single or twin cylinder would use less fuel than any eight, let alone the noise. unless you needed a big generator. just a thought. </div></div>
That's a good point, I may just get a portable Honda and save some money..
D_L is offline
Old 10-26-2007, 10:04 AM   #8 (permalink)
12-14 weeks, good luck. The UAW has struke the 6.4 engine plant.See my other post if moderators have not deleted it. Who knows when they will be back at work. Decides if contract demands are met.
Y2K excursion XLT 2wd, ordered july '99, built august '99, delivered september 9 '99, 4R100 fried & replaced at 900 miles still running like a champ
exoval is offline
Old 10-27-2007, 08:48 AM   #9 (permalink)
Hey DL long time no see. You will love the new 6.4 I love mine. How you been?
2008 F450 CC Black
KAT Transport Services Inc Media , Pa
Support your local Ford Technician buy a 6 Liter
SVTKYLE is offline
Old 10-28-2007, 12:43 PM   #10 (permalink)
D_L
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: SVTKYLE</div><div class="ubbcode-body">Hey DL long time no see. You will love the new 6.4 I love mine. How you been? </div></div>
Hey Kyle, What's up...I've been fine...Got a BigDog chopper motorcycle a couple of years ago, been doing the biker scene a little bit and attending some local drag racing. Got a few local good friends into the Outlaw Pro Mod scene, Blown Alcohol Hemi cars...Haven't been traveling to any NMRA or FFW races this year.
I'm finally stepping into the Diesel arena, I need a new truck to tow my enclosed bike trailer with. It's gotta be a Ford Diesel.
D_L is offline
Old 10-28-2007, 12:44 PM   #11 (permalink)
D_L
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: exoval</div><div class="ubbcode-body">12-14 weeks, good luck. The UAW has struke the 6.4 engine plant.See my other post if moderators have not deleted it. Who knows when they will be back at work. Decides if contract demands are met. </div></div>
What???? They are on strike???
D_L is offline
Old 10-28-2007, 05:10 PM   #12 (permalink)
DL glad to hear you are ok. You gotta give me a ring someday if you are ever up this way. Mabye we can see if we can beat out our old "worlds biggest bar tab"
2008 F450 CC Black
SVTKYLE is offline
Old 10-28-2007, 09:53 PM   #13 (permalink)
D_L
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: SVTKYLE</div><div class="ubbcode-body">DL glad to hear you are ok. You gotta give me a ring someday if you are ever up this way. Mabye we can see if we can beat out our old "worlds biggest bar tab" </div></div>
If I come up that way, I'll give you a call. That was one night to remember, plus the burnout contest at the hotel...We had a awesome time.
D_L is offline
Old 10-29-2007, 01:14 AM   #14 (permalink)
loft306's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: D_L</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: exoval</div><div class="ubbcode-body">12-14 weeks, good luck. The UAW has struke the 6.4 engine plant.See my other post if moderators have not deleted it. Who knows when they will be back at work. Decides if contract demands are met. </div></div>
What???? They are on strike??? </div></div>strike yeah...But there are also non-union international plants that make the engine and ford dosnt expect any delays
~ Mike
2008 BLACK F350 XLT RC SRW 4x4, 6.4, Auto,3.73ls, ManualTransferCase,PTC-Heater. Pic's She is Sweet...
DORA recieved:9/14/07 || ReceiptDate:9/14/07 || SerializeDate:11/01/07 || SegmentDate:11/01/07 || SequenceDate:11/10/07 || BlendDate:11/13/2007 || GesitmatedBuildWeek: 12/10 || ProducedDate:11/21/07 || GateRelease:11/21/07 || ShipDate:11/24/07 || ArrivalDate:11/30/07 || SoldDate:11/30/07 ||
1992 F150 | 1987 E250 | 1983 CutlassCiera | 1979.5 K5 blazer
loft306 is offline
Old 10-30-2007, 12:08 AM   #15 (permalink)
D_L
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: loft306</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: D_L</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: exoval</div><div class="ubbcode-body">12-14 weeks, good luck. The UAW has struke the 6.4 engine plant.See my other post if moderators have not deleted it. Who knows when they will be back at work. Decides if contract demands are met. </div></div>
What???? They are on strike??? </div></div>strike yeah...But there are also non-union international plants that make the engine and ford dosnt expect any delays </div></div>
I got to call the dealer and check on my order. How about the KTP plant, will it affect it?
D_L is offline
» Site Navigation
» Home
