Go Back   Diesel Forum - The Diesel Stop.com > 2008-Up Super Duties > 6.4L Power Stroke Engine and Drivetrain
6.4L Power Stroke Engine and Drivetrain Discussion of the 6.4L Power Stroke diesel engine and drivetrain in the 2008 Super-Duty trucks. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
Old 06-07-2008, 01:12 PM   #1 (permalink)
08 F-450 popping fuse??
When I have the Toy hauler hooked up to the truck and the truck is running everything is fine and the truck is charging the batteries. If I push the slide button or run the jacks, this pops the 30 amp charging fuse. My other Fords did not do this. Is this only on 08's or is there something wrong with mine. Took it to Tork Lift and everything checks out ok on the truck as far as no shorts. Under load it seems to pop.
08 F-450 (Red)
EDAZS is offline
Old 06-07-2008, 01:27 PM   #2 (permalink)
it sounds like the batteries in the trailer are not strong enough to support the load and you are trying to pull too much through the trailer connector. I would load test the trailer batteries and make sure the connections are all good there.
2008 F-450 Lariat loaded on order 7/3/07 delivered 9/13/2007 Pueblo Gold and all the goodies except Nav radio and moonroof and Fisher 8'6" X-blade
2005
F-350 Lariat LOADED CC SRW LB 6.0 SOLD
Med. Wedgewood Blue
All Options except moon roof
8'6" Fisher X-blade SS
2003 PSD 6.0 Lariat CC SB SOLD
All options but the moon roof
Scottb NY is offline
Old 06-16-2008, 02:38 PM   #3 (permalink)
Ok I am going to put it to the test. I just installed four 6 volt batteries. I had a new camper for a couple of months with four 6 volts and it popped the fuse with that setup also.
08 F-450 (Red)
EDAZS is offline
