6.4L Power Stroke Engine and DrivetrainDiscussion of the 6.4L Power Stroke diesel engine and drivetrain in the 2008 Super-Duty trucks. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
It has SuperDuty embossed on it at least three or four times. Am I really likely to forget what I'm driving?
They still haven't run the console up under the dash - Chevy gets the points here. Overall I think for took the brutish approach on styling while Chevey took the high road/elegance approach.
No sticker on the window so I could not tell how it was equipped. It was a diesel automatic 4WD and it has clearance lights, NAV radio, tow command and switches.
2008 F450 CC Lariat White/Gold, JAD Solutions Lights, 62 Gal Titan, B&W Hitch, Ford Gold Remote Start, TruckTrunk box, Viair 550+2x2.5gal receiver
yep, saw it last night and thought it looked real sharp. i liked the color and thought the front end looked nice and mean. they had it roped off so it was hard to see much detail inside. i wish they'da popped the hood. [img]/ubbthreads/images/graemlins/mad.gif[/img]
i thought the tail gate step was real nice and easy to use. the cargo coral thingy didn't stow against the sides as tight as i thought they would have.
'03 F350 Dually, 6.0, Supercab, longbed, 4.10 LS, sport pkg, extremely RED, STRAIGHT PIPED, SCT Xcalibrator, full guages
- Job1 programming, Harpooned, Skweeker Mod, Zoodad Mod
- Did that thing that you're not supposed to talk about
'79 Bronco, 468cid Ford 460 marine motor, C6/NP205
Previous -'99 F250, Rg Cab XLT, 7.3/6spd, 3.73
Project truck
- '96 Cummins, 215hp/5spd, Diprocol guages, Plate & AFC full fwd, hi-capacity external lubrication system
To add: 2 1/2T axles, 46" goodyears, etc.
You got closer that I did at the Orlando Show. Here they had one up on the turn table. You could not get close to it and you could not see inside because it was 3' off the ground. [img]/ubbthreads/images/graemlins/frown.gif[/img]
2008 F-450 Lariat W/ Lots-o-Options - Built on Feb 7 2007, Shipped on Feb 12, 2007, Mine on Feb 22, 2007
Seems to be very little cost effective upgrade opportunity for the exh at least. Its all 4" tube and the muffler is 25% the size of the old one - likely means most of the pressure drop is in the filter and cat.
