6.4L Power Stroke Engine and DrivetrainDiscussion of the 6.4L Power Stroke diesel engine and drivetrain in the 2008 Super-Duty trucks. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
It seems like I read something awhile back that the TorqShift transmission for the 08's had some new upgrades/plates in it. Does anyone know about the changes and specifically why they where made? This is important to me as I had problems with an 05 Torqshift at about 28,000 miles.
Thanks,
Marc
2008 King Ranch F450 - 4.30 Gears
2008 XT F550 - 4.88 Gears
2006 Caterpillar 420D Backhoe
1957 Wife - Not a diesel burner, but sometimes does a Regen
From the file I downloaded that someone on this forum provided.
Transmission specifics:
*Torque converter design maximizes low-speed torque output
*All new more robust gear sets and a three-plate two-stage torque converter help reduce turbine noise when the converter is locked
*Large fluid pump provides superior lubrication and cooling
*Pure electronic shift controls work with the Electronic Throttle Control of the engine to optimize shifts and vehicle performance and responsiveness
*WhenHauling a heavy load or trailer, the Tow/Haul mode reduces gear hunting, improves power delivery and even uses engine braking to help control vehicle speed when descending hills
*Spin-on fluid filter for convenient serviceability
Transmission can be equipped with power takeoff port-must specify order code 62R (PTO obstructed by catalyst placement on 5.4 and 6.8 engines.
So seems quite a few improvements, not sure if these were on the '07's or not. My '04 Torqueshift has been great, no problems at all.
2008 F-450 Lariat Dark Stone Metallic over Pueblo Gold 4x4(manual shift transfer case, manual hubs), High capacity tow 4:88s, Off Road, Camper packages, Sirius Sat, Upfitter switches, DVD entertainment, tailgate step, traction control, Audiophile 6-disc, PTC Supplemental heat and heated seats(warm buns), rear sensors, traction control, tailgate step. Built May 8, delivered May 24
Reese Signature Series 24k fiver hitch, I installed it myself, best hitch I have found yet
Line-X bedliner, heavy duty floor mats
2003 Sunline F281SR(weekend getaways)
SeaRay 215EC http://community.webshots.com/user/C...host=community
I'd have thought the transmission was totally electronically controlled by now. What aspect of it was not?
1998 12v 5 spd 2wd dually, 271k on truck, bhaf, piers 370's, timing at 16.5 deg, 3k gsk, #0 plate full forward, afc arm on shelf in shop, htb2 64-14 turbo with wastegate set at 45 psi, southbend dual disk clutch, detroit locker, has broken 2 stock dana 80 limited slip units, has run 14.65 at 98 granny shifting the 5 spd, dynoed at 450 hp and 906 ft/lbs on REALLY STINGY dyno
I'd have thought the transmission was totally electronically controlled by now....
it is.
the way i see it the only differences is the new converter, and beefed up gearsets. it doesn't say that the pump is larger, just large. those other bullets are marketing hype.
doesn't bother me, though - i feel that the torqueshift is the best performing auto out there*. so don't fix what ain't broke. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
*note: i haven't driven a new dodge 6spd. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Travis
'03 F350 Dually, 6.0, Supercab, longbed, 4.10 LS, sport pkg, extremely RED, STRAIGHT PIPED, SCT Xcalibrator, full guages
- Job1 programming, Harpooned, Skweeker Mod, Zoodad Mod
- Did that thing that you're not supposed to talk about
'79 Bronco, 468cid Ford 460 marine motor, C6/NP205
Previous -'99 F250, Rg Cab XLT, 7.3/6spd, 3.73
Project truck
- '96 Cummins, 215hp/5spd, Diprocol guages, Plate & AFC full fwd, hi-capacity external lubrication system
To add: 2 1/2T axles, 46" goodyears, etc.
