2008 6.4L white smoke from pipe - Diesel Forum - TheDieselStop.com
post #1 of 13 (permalink) Old 06-29-2009, 11:35 AM Thread Starter
Gunther's Avatar
Exclamation 2008 6.4L white smoke from pipe
I have a 2008 F250 with the 6.4 and a white smoke/running problem. The problem is erratic in it occurrence. It happens when the truck has been running a while down the highway, pull off to a stop, go to take off again...thats where the trouble starts. The truck will start shuddering and belching white smoke for about 100 yards, then will eventually clear out. I have read most of the posts on white smoke on the 6.4, but most seem to be in cooler climates. I am in Texas (85-100+ degrees) and it has been going on for over six months and the Ford dealers can't seem to find anything wrong. HELP
Gunther is offline
post #2 of 13 (permalink) Old 06-30-2009, 11:05 AM
I believe this is related to TSB 08-28-1 -- Hesitation in rainy or humid conditions. You will see many posts in a variety of forums discussing this. I also live in Texas and have a 2008 F250 which I experienced the same problems for a year or so. I had the TSB performed on my truck a few months ago and have not had a problem since. The TSB involves replacing the very front radiator/cooler on your truck.
2008 SD 250 Lariat CC 2 Wheel Drive
250_SD_Beast is offline
post #3 of 13 (permalink) Old 07-01-2009, 08:31 AM
Harley350's Avatar
Harley350 is offline
post #4 of 13 (permalink) Old 07-01-2009, 02:28 PM Thread Starter
Gunther's Avatar
I just printed this off and I am heading over to the Ford house where they are burning up my diesel trying to "figure" it out.
Thanks SD Beas
t
Gunther is offline
post #5 of 13 (permalink) Old 07-01-2009, 04:35 PM
sawtooth's Avatar
Thanks SD Beast
Yep that should be your issue. Had my CAC replaced a few weeks back and no problems since.
2008 Job 3 6.4 F250 Lariat CC 4x4 Dark Stone
ATS Color Matched Street Flares
Eaton ELocker "front" and Truetrac Limited Slip "rear"
sawtooth is offline
post #6 of 13 (permalink) Old 07-01-2009, 05:17 PM
Harley350's Avatar
I have the same problem except no white smoke, mines grayish so they are giving me a hard time.
What a bunch of ignorant brain dead retards.
post #7 of 13 (permalink) Old 10-28-2009, 05:52 PM
Same problem - White Smoke
I have a 2008 F250 6.4L that I ordered in the Spring of 2007. It now has a little over 70,000 miles on it. I love the truck, but this white smoke issue has been occurring at various times throughout the life of the truck. The first time it was less than a month old and happened in the middle of a 7 mile backroad commute one cool morning. Recently is seems to be happening around town when I take off at a light. I have always thought it was some foreign matter in the fuel burning, and it never lasts more than 15 or 20 seconds. A slight loss of power accompanies the white smoke emission (along with angry drivers behind me!)
If anyone has an insight, I would love to hear it!
I have had all the recall work done, and the only non-routine maintenance I've had done was removing a ball of wax from the water separator around 40,000 miles.
raifdop is offline
post #8 of 13 (permalink) Old 10-29-2009, 11:50 PM
MRBOHN23's Avatar
You guys need to go your local dealership, I like some of you guys was experiencing the same problem. The solution is just what has been mentioned, to change on of the radiators, I believe it was the intercooler! This cured the problem. Had that done approx 5 months ago, and no problems since.
2008 F-250 Lariat Crew Cab, 6.4 diesel, moonroof, reverse sensor, tow command power mirrors, snow plow prep!
MRBOHN23 is offline
post #9 of 13 (permalink) Old 10-30-2009, 01:45 AM
I had all the recall work performed last month, including a replaced radiator. Still having the problem, unfortunately. And my 'Cleaning Exhaust Filter' message has been coming up a lot more since the recall work, but I have also done a lot less highway miles since then.
raifdop is offline
post #10 of 13 (permalink) Old 11-01-2009, 01:33 AM
ssharber's Avatar
The TSB is actually 08-25-1, not 08-28-1. It involves replacing the intercooler and lots of us have had this done. Mixed results. Mine has done fine, some say it comes back, some say the new intercooler is more restrictive and your boost will take a hit. Ive not seen that. But by far its better than pulling out on the interstate pulling 10k and having this happen.
ssharber is offline
post #11 of 13 (permalink) Old 11-01-2009, 06:20 PM
My 08 has some of the same problems but it goes into regen mode every 150 to 200 miles and fills crank case with fuel Ford can't seem to find the problem after 5 diffrent sensors and 10 trips to dealer it still blows white smoke and runs poorly
exc345 is offline
post #12 of 13 (permalink) Old 02-22-2015, 09:45 PM
I'm new to the diesel world. It's a 2008 F250 with 133,000 miles and I'm blowing out whitish grey smoke. After the truck has warmed up the engine will go through sperts of running sluggish, the turbo and RMPs keep dropping and then picking right back up then dropping back down. Over and over again. And blowing the whitish grey smoke? Took it to a ford dealership and they said I had 2 injectors over fueling. Had them replace the 2 injectors (and $1400 later), I'm still having the same problem. I'll be thankful for any help someone may have.
WilliamCG is offline
post #13 of 13 (permalink) Old 03-05-2015, 04:18 PM
I did resurch on the 2008 f250 white smoke and its related to your egr valve it needs to be changed out lubed
wendylue is offline
  Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 6.4L Power Stroke Engine and Drivetrain
