2008 F250 6.4 liter loss of power and loss of turbo - Diesel Forum - TheDieselStop.com
Old 08-10-2011, 07:39 PM   #1 (permalink)
Thumbs down 2008 F250 6.4 liter loss of power and loss of turbo
Randomly while pulling and not pulling with this 6.4 liter i will loose all my power and looks like the turbo but i think its mostly due to me loosing power and most likely exhaust pressure. The truck has 143,000 miles on it with no aftermarket attachments. When this lose of power happens i have to pull over and turn off engine and restart. A few days ago even restarting the truck when i didnt have a trailer, didnt even fix it. I always have my oil changed every 5,000 and my fuel filters every 10,000 miles. My trailer i pull is about 8,000 pounds. I figure its prob the HPFP but wanted to get some feed back about it. Also i have been looking into EGR deletes and programers for the delete/ fuel milage, Any quality recommendations would be grately appreciated.
Corey Schoener - 2002 F250 7.3 liter w/ Edge chip, 2008 F250 6.4 liter, another 2008 F250 6.4 liter, 2006 F250 6.0 liter w/ Edge chip(finally got rid of), And a 2012 6.7 liter
CoreySchoener is offline   Reply With Quote Quick reply to this message
Old 08-11-2011, 07:36 AM   #2 (permalink)
Jburcham04's Avatar
I lost power before when my dpf stopped working, it was clogged and not letting any exhaust out in turn the turbos wouldn't spool, ended up blowing a hole in the side of the dpf... When you shut it off and start it back up does it go into Regen?
My drinking team has a racing problem!!!!
08 F-350, diamond 5" turbo back exhaust (dpf/cat delete), AFE air filter (stock intake), back maxx, Nitto 325/60R20 (35's) terra grappler tires, 2.5 daystar leveling kit, bds shocks, icon adjustable trackbar, painted fender vents
Jburcham04 is offline   Reply With Quote Quick reply to this message
Old 08-11-2011, 08:13 AM   #3 (permalink)
senix's Avatar
This to me sounds more like it is limiting the power as in low on fuel or low pressure. I would almost bet there is a code that has been stored in there.
I would suggest an investment to get the code read.
08F250 CC 6.4 PSD
Banks 6 gun/ram air
40' Stoneridge 5th wheel, coming in at 15.4K.
senix is offline   Reply With Quote Quick reply to this message
Old 08-11-2011, 04:42 PM   #4 (permalink)
Same thing happened to me. Took it to get the code read and turned out a short in the high pressure pump. Lucky for me i was under 100000 miles barely. I do hope it is something cheaper for you
kric is offline   Reply With Quote Quick reply to this message
Old 08-11-2011, 06:18 PM   #5 (permalink)
Well it seems to me i def should buy a code reader, any recommendations? The engine has 145,000 on it so out goes the warranty. But i have def considered a EGR and DPF removal. Im guessing it doesnt matter which blocker plates i go with but any one have real good mileage with a chip the goes with the EGR and DPF blocks?
Old 08-11-2011, 06:24 PM   #6 (permalink)
senix's Avatar
probably spartan for the tuner and dpf delete. EGR delete I don't know..but spartan can turn it off for you and then cycle it at idle.
08F250 CC 6.4 PSD
Banks 6 gun/ram air
Old 08-11-2011, 09:25 PM   #7 (permalink)
Now i am unfamilar with the DPF, is that part of the exhaust? and is that what cleans the exhaust filter out?
Old 08-11-2011, 09:29 PM   #8 (permalink)
Jburcham04, I have not noticed that it goes into regen(filter cleaning?). But i do notice that the truck will say its cleaning but i dont notice any power loss and smoke. But 10% of the time of cleaning it will smoke and lose power. It'll randomly clean after the motors warm prob every 150 for about 50 miles at a time. And it always goes into cleaning when i am 75 miles till Empty. Go figure dump fuel into the exhaust when i start looking for a diesal station. I do travel alot every week
Old 08-11-2011, 10:54 PM   #9 (permalink)
cdgriffin3's Avatar
Excuse me for being blunt but get rid of the 2008. It was a horrible year for Ford. You might just be spending too much $$$ on it. I had a 2008 for about a year and a half till I got fed up with it. They replaced the radiators, computer, torque converter and finally the motor. I had enough! Ford actually worked with me and put me in a 2010, which is the same motor but I haven't had a problem since. First thing I did do was remove the DPF and it helped! I hope everything works out and good luck!
Sent from my Autoguide iPad app
cdgriffin3 is offline   Reply With Quote Quick reply to this message
Old 08-12-2011, 05:22 AM   #10 (permalink)
senix's Avatar
the DPF is the diesel particulate filter. It is what traps the soot. A properly working system should be seamless to the driver. Aside from maybe a change in engine tone and a message display you should not have any smoking or driveability concerns. Regens according to your posting are a little too frequent but more info is needed to determine if that is truely the case.
Ford will say that regens should be anywhere from 100-600 miles apart depending upon duty cycle and of course the type of fuel.
08F250 CC 6.4 PSD
Banks 6 gun/ram air
Old 08-12-2011, 12:08 PM   #11 (permalink)
So while cleaning the exhaust filter it should not blow white smoke? And pretty much a DPF delete is a new exhaust?
Old 08-12-2011, 12:54 PM   #12 (permalink)
senix's Avatar
White smoke on a rare occasion with cold ambient temps is about it.
Not a complete exhaust for the dpf delete. Only that portion of the dpf and then a straight pipe installed.
08F250 CC 6.4 PSD
Banks 6 gun/ram air
Old 08-12-2011, 03:51 PM   #13 (permalink)
Alright Guys, threw my first code P 0088. Fuel Rail/System Pressure Too High.
Old 08-12-2011, 07:54 PM   #14 (permalink)
But im not running a programmer
Old 08-12-2011, 10:55 PM   #15 (permalink)
I trying to get my Mechanic to take a look at it but of course when i take him out for a ride with the computer it doesnt back down on me.
Wheel & Tire Center
Powered by vBulletin® Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
