2008 F250 Upper and Lower Radiator Hose Replacement Instructions? - Diesel Forum - TheDieselStop.com
post #1 of 3 (permalink) Old 04-10-2013, 01:29 PM Thread Starter
Does anyone know where I can locate instructions on replacing the upper and lower rad hoses? It seems fairly straightforward, but I want to make sure I don't miss anything. Thanks!
Haleiakala is offline
post #2 of 3 (permalink) Old 07-02-2014, 03:48 PM
I was hoping that there was some info here on your request. I have to say that this place doesn't offer much help like it did 10 years ago
2008 F350...Lariet Super Cab , 6.4, 3:73 with all the goodies,169,000 miles, 35 foot 11K Fiver,
New Radiator, new EGR Cooler...#6 Injector replaced twice... TCM at 105K, Alternator at 115K, Fan Clutch at 165K
TIM K is offline
post #3 of 3 (permalink) Old 07-03-2014, 08:50 AM
You won't find directions because its a fairly easy, straight forward job.
When you buy your new hoses you will see the retaining clip on the end of each hose. By inspecting the new hoses, you will understand how to remove the clip on the old hoses. I use cheap shop tweezers to reach into a tight area, grab the clip and pull the clip off a hose. Once you pull the clip, you simply yank the hose off. To replace a hose you simply push it on, clip installed, till it seats. Make sure it seats completely, especially the lower hoses, where they join together beneath the radiator.
Changing hoses mean your flushing coolant too. Lots of discussion about this; what sort of cleaners to use, what coolant to use, how to flush properly, how to fill properly, ......
fatboytx is offline
  Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 6.4L Power Stroke Engine and Drivetrain
