Go Back   Diesel Forum - The Diesel Stop.com > 2008-Up Super Duties > 6.4L Power Stroke Engine and Drivetrain
6.4L Power Stroke Engine and Drivetrain Discussion of the 6.4L Power Stroke diesel engine and drivetrain in the 2008 Super-Duty trucks. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
Old 05-01-2007, 01:04 AM   #1 (permalink)
2008 F350 4x4 SRW CC Height Questions
Hi, I have a few questions:
1) Did anybody have a problem fitting their 2008 F350 SRW 4x4 CC under a 7 foot high garage door? My garage door trim is 82.5 inches off the floor. Ford specs say the truck is 81 inches high, but I am unsure how repeatable/accurate that spec is.
2) Could I still fit it if I ordered the roof clearance lights? In other words, how much height do the roof clearance lights add?
3) Has anybody had problems with sufficient clearance between the bed rails on 2008 F350 SRW 4x4 CC and their fifth wheel? I don't want to have to do any funky things like flipping axles, etc. to get enough clearance.
Gary
GWBlack is offline
Old 05-01-2007, 01:23 AM   #2 (permalink)
Re: 2008 F350 4x4 SRW CC Height Questions
I would say not with the roof clearance lights....
the rest i have n clue
2008 F350 CC Lariat 4x4 LOADED to the MAX!
-SCT Tuner
-Pro Comp 6" Radius Arm Lift
-KMC Rock Stars 22" x 10"
-Kumho 37" Mud Terrains
-Pro Comp Traction Bars
2008TTCC is offline
Old 05-01-2007, 09:21 AM   #3 (permalink)
Black05's Avatar
Go to a dealership and measure one of the trucks on the lot (that would be outfitted like the one you want). That's the best way to answer your questions.
Black/05/F350/XLT/CC/LWB/FX4/SRW/3.73/6.0L PSD/ TorqShift/Updated TBC/Upfitter Switches/SEIC Mod/Diesel Site Coolant Filter/Fumoto Valve/ITEC HFCM Drain Plug/Bilstein Shocks/BFG A/T 28565R18/Built September of 2004
Texas Proud.
God Bless our Armed Forces.
Black05 is offline
Old 05-01-2007, 09:22 AM   #4 (permalink)
# 1 and # 2 don't know but # 3 Duane-Miller says this "In one of my "stupid" moments, I thought I needed to lower my 350. Went back and forth with the dealer to get the parts in.... I lowered the rear, hooked up the trailer, and found that it squatted too much. I put the original blocks back in and now everything is fine." This was copied from the towing section.
I also had this concern about the hitch.
JD
08, 6.4, F-350, torqshift, SRW, lariat, 4X4, LB, CC, Pueblo gold (Built the week of 04/09/07)Arrived 4/24/07 brought home 4/26/07
http://rides.webshots.com/photo/2919...01044415MSbgrF
jhughd is offline
Old 05-01-2007, 09:27 AM   #5 (permalink)
I have anew truck..exactly like yours. Haven't measured my garage..but assume it is a pretty much standard height...house is 22 years old. My truck fits....just barely....have no more than 1/2 inch to spare....of course it is too long as to close the door!
2008 F350 Crew Cab 6.4 PSD 4X4
Excel 33RSO 5th Wheel M/C Lift on the back
jayhirsch is offline
Old 05-01-2007, 09:32 AM   #6 (permalink)
The bed clearance should not be a problem. I have about 8 or 9 inches between mine. See PICS.
Cannot help you with the garage door -- mine are 10 ft.
Good luck with your 5th wheel. My truck really tows it well.
DRDON
2008 F350 Lariat CC PSD 2WD Auto. 172" Dark Blue Pearl Clearcoat Metallic/Pueblo Gold 5"Chrome CabSteps Camper Pkg. HD Alt. Tow Command Upfitter Switches, 25K Air Safe Hitch, Retrax Cover, Timbrens, WOLO 120 db air horn, and more.
2007 Ameri-Camp Summit Ridge Reserve 40' 5th wheel trailer, 3/Slides, chrome wheels, Mor-ryde suspension, dual A/C, theatre system, solid surface counter tops, king bed, power jacks front/rear, 50 AMP service, sealed underside, heated tanks and more.
MY PICTURES:
http://good-times.webshots.com/album/558384049kmtqSi
DRDON is offline
Old 05-01-2007, 10:05 AM   #7 (permalink)
Banned
Both of my trucks,f-450 4x4 and f-350 duallies fit in my garage which is standard height.They just make it though.
sicaj is offline
Old 05-01-2007, 04:23 PM   #8 (permalink)
Used a level across the the center Cab Clearance Light on my truck and got 80.5 inches in height. Hope that helps.
2008 SD 250 PSD King Ranch 4X4, SWB, CC, Auto 3.73
Viper 791 XV alarm with remote start. FS2500 bypass filter. Edge Insight multi gauge. Line-X. Retrax.
Sequoia is offline
Old 05-01-2007, 05:28 PM   #9 (permalink)
The door to my barn is 12'6" and my wilson 1000 hits(CB Ant.), its a 1/2" taller, hope this helps. [img]/ubbthreads/images/graemlins/biggrin.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
My trailer is 12'4" so the ant. is like a feeler gauge.
08 F350 FX4 cc sb 6.4L BFG 305/65-18 Harpooned 12MPG MT
Ordered on 2/21 Born on 3/19 Mine on 3/30
SOLD 99.5 F250 sc lb 3.73ls 4x4 100k
08 Ecape Manual XLS 29MPG
28' Jayco Talon ZX toy hauler 10,000# w/o toy's tounge wt 1600# w/o toys or water
22' Renagade 3place snowmobile trailer 2000# w/o toy,s
98 FLHT
wolfe14785 is offline
Old 05-01-2007, 05:36 PM   #10 (permalink)
My 2005 F350 SRW with lights just clears by less than an inch, but to be sure check the lowest point of the door, and measure the truck
first_ford is offline
Old 05-01-2007, 06:19 PM   #11 (permalink)
This is very interesting. The height spec for 2008 F350 SRW CC 4x4 is 81 inches (WITHOUT clearance lights) as shown on the following Ford link: http://www.fordvehicles.com/trucks/s...eatures/specs/
So one would think that WITH clearance lights, the overall truck height would be 82-83 inches. Yet, if I understand correctly, you measured 80.5 inches to the TOP of the clearance lights on the same exact truck model. Is there that much tolerance in these height specs? That's what I was worried about in the first place.
2008 F350 Lariat SRW SWB CC 4x2 PSD Auto, Oxford White with Pueblo Gold Trim
GWBlack is offline
Old 05-01-2007, 06:35 PM   #12 (permalink)
Since the trucks tend to sit higher in the rear than in the front I would guess that the rear of the cab would be the high point. So, it's quite possible the front of the cab where the clearance lights are mounted would measure lower.
tzurick is offline
Old 05-01-2007, 06:57 PM   #13 (permalink)
Very interesting; I hadn't thought about that possibility before. Thanks!
GWBlack is offline
Old 05-01-2007, 07:35 PM   #14 (permalink)
Looking out the window at mine and it looks like the rear top of the crewcab is higher then the clearence lights.
JD
jhughd is offline
Old 05-01-2007, 08:31 PM   #15 (permalink)
OK. Moved the truck to an very flat area and remeasured at the back of the cab at the highest point of the roof ribs. It is exactly 81 inches. Foolishly, I made an assumption about the clearance lights being higher than the rest of the truck. On my truck, they still look higher, but that is not the case. Optical illusion or poor eyesight. 81 inches, measured twice.
Sequoia is offline
