2008 f350 6.4 cleaning exhaust system? - Diesel Forum - TheDieselStop.com
post #1 of 9 (permalink) Old 09-25-2012, 05:37 PM Thread Starter
Hi guys I recently purchased a 2008 f350 6.4 for my lawn care business and when I'm not pulling my trailer full of mowers it does fine and only cleans system once per tank but if i have it under strain it says it cleans the exhaust at least 2 times a day and it makes the exhaust hott(which I know is normal) but is it normal to clean it so much what would cause this? Also it kills my fuel mileage is there a way to unhook and bipass this? Any help would be appreciated thanks
charles23 is offline
post #2 of 9 (permalink) Old 09-25-2012, 06:34 PM
superduty6.4's Avatar
The only way to bypass it is to remove the dpf and get a tuner that turns off the regen. Have you taken it out on any long drives since you've had it at speeds above 80 kph?
2008 F350 JOB 1, H&S MINI MAXX W/S1M, SINISTER EGR/COOLER DELETE, AFE CAI, FLO-PRO IC PIPE & INTAKE ELBOW, CCV MOD, 5" FLO-PRO DP BACK EXHAUST, ROTELLA EC-1 RATED COOLANT, DIESELSITE COOLANT FILTER, 6000K BEAMERS HID HEAD & FOGLIGHTS, 2.5" LEVELING KIT, AIR LIFT 5000LB AIR BAGS W/ONBOARD COMPRESSOR, KMC XD HOSS WHEELS W/35X12.5R20 NITTO TRAIL GRAPPLERS
superduty6.4 is offline
post #3 of 9 (permalink) Old 09-25-2012, 09:03 PM
davydee's Avatar
On ours it's normal. Pulling loaded in mountainous areas and accelerating to merge were typically high smoke events for our 7.3L, and I assume the same with our current truck. That makes a ton of soot and the need to clean more often. For two years now, when traveling along I-90 through Idaho and Montana, we've had our current truck give the "Drive to Clean" message almost hourly. David
2001 F250 7.3L PSD Lariat CC 4x4; Sold Jan 2009
2009 F450 Pickup Lariat Plus w/Nav, 4X4 Off-Road Pkg; Sold Feb 2017
2017 F350 CC DRW Platinum 4x4
2011 MS 36RSSB3 w/vanity slide and a nice 4,285 lbs of hitch weight
davydee is offline
post #4 of 9 (permalink) Old 09-26-2012, 12:57 AM
Typically if you are getting the "drive to clean" message you have been doing short trips and not letting the regen finish. When I still had my dpf mine regened about once a tank maybe 2 at the most once in awhile but I do mostly highway driving.
post #5 of 9 (permalink) Old 09-26-2012, 05:02 AM Thread Starter
See that's what mine is doing I don't do a lot of highway driving more in town and it cleans about once an hour or so and I always let it finish cleaning before shutting it off.. so than this is normal? My question is is there a way to unplug the regen cycle without doin a DPF delete like unpluggin the sensor on top of DPF or will that cause the DPF to get full and not allow air through? I would really like to eliminate this to get better fuel mileage but I can't do the complete DPF delete because I have to have D.O.T inspection for my truck and it won't pass if I do
post #6 of 9 (permalink) Old 09-26-2012, 05:23 AM
senix's Avatar
you will hve to tune in order to get rid of the DPF. DPF-R may be your low cost ticket. But you will need s pipe to replace the DPF.
That in town driving is killing you. Are you also letting it idle alot? Shut it down if you are.
08F250 CC 6.4 PSD
Banks 6 gun/ram air
40' Stoneridge 5th wheel, coming in at 15.4K.
senix is offline
post #7 of 9 (permalink) Old 10-02-2012, 04:31 PM
I tow an enclosed car trailer about once a month. The whole package weighs about 8Klbs. When I am towing it I get about 11mpg and regen every quarter tank.
wheelhopper is offline
post #8 of 9 (permalink) Old 10-02-2012, 04:34 PM
hkyplr's Avatar
Send a message via MSN to hkyplr Send a message via Yahoo to hkyplr
That seems about right, the longer you could stretch your hwy time on these trips, the frequency between cleanings would get longer.
2008 F350 CC Long Bed Lariat 4x4 SRW Job 1. H&S Mini Maxx running Mild tunes (for the moment) and S2L Trans tune. 4" Diamond Eye Downpipe back exhaust. S&B CAI. 5th Wheel Hitch. Front Receiver Hitch. Bakflip Tonneau Cover.
hkyplr is offline
post #9 of 9 (permalink) Old 10-02-2012, 06:30 PM
cory151's Avatar
Not only is constant regen killing your MPGs its also stressing the number 7 and 8 cylinder as well as the turbo/s.
In order to NOT have that happen you must have a tuner and a delete pipe.
cory151 is offline
  Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 6.4L Power Stroke Engine and Drivetrain
