Go Back   Diesel Forum - The Diesel Stop.com > 2008-Up Super Duties > 6.4L Power Stroke Engine and Drivetrain
6.4L Power Stroke Engine and Drivetrain Discussion of the 6.4L Power Stroke diesel engine and drivetrain in the 2008 Super-Duty trucks. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 6.4L Power Stroke engine.
Old 02-21-2008, 12:53 PM   #1 (permalink)
2008 F350 help
Hello, I did try a search, but was unalbe to find what I am looking for... So I humbly come to you guys with my problem.
Here goes....... I have an 2008 F350 with 12,324 miles on it, it has dual exhust that being the only up grade. I have not pulled anything with this truck, on 3 occasions the truck has lost power and blown grey/white smoke out the exhust, I mean a lot of smoke! I have an appointment at the Ford garage on Monday (Feb 25), I live in a fairly small town and IMO the diesel mechanic is....welll lets just say crapy. Do you guys know what is wrong with my truck? Thanks!!!!
justcruzin is offline
Old 02-21-2008, 05:23 PM   #2 (permalink)
Did you cut off the DPF? Did you cut into the Y pipe for the duals? It is normal to see some white smoke, and to experience a loss of power during a REGEN. My assumption is you did one of the above, and the computer is confused because of a loss of back pressure and lower exhaust temps. I assume your fuel consumption has gone up as well? Let us know...but this is my opinion.
BTW, I think its funny Chevy is advertising on a Ford site.
Michael B.
2008 F350 XLT, SC, LWB, SRW. 6.4 L. 4x4. 6 spd. Job 1. As of 17OCT08, 29,342 miles.
Traded: 2008 Nissan Frontier King Cab NISMO, 4.0 V6, 6spd, Majestic Blue, Cargo Mgt System.
2009 VW Jetta Sedan, 2.0L TDI, 6spd, Silver, Protection Pkg. Bought 23OCT08
CMB430 is offline
Old 02-21-2008, 05:51 PM   #3 (permalink)
Wow, i just saw that. ROFL
Rednecks have more fun!
1992 F350 CC LB 5.8L 5-speed 4.10 L/S. Stock
92F350CC is offline
Old 02-22-2008, 06:27 AM   #4 (permalink)
It's been my observation that if you remove the DPF, you have to get a chip to help the computer cope with the lack of need for the regen.
Red 2002 F-350 XLT SRW 4x4 7.3L reg. cab 6-speed rubber floors traded at 50K for:
Red 2005 F-350 XLT SRW 4x4 6.0L reg. cab 6-speed rubber floors BFG 12.5x35 mud-terrains, no lift traded for:
Red 2008 F-350 XLT SRW 4x4 6.4 reg. cab 6-speed. Got carpet this time- audiophile stereo deletes rubber floors. BFG 12.5x35 mud terrains, no lift.
torino73 is offline
Old 02-22-2008, 03:02 PM   #5 (permalink)
I do not believe the DPF (what is that?)was removed, the exhust is after the particulate filter. Does this help? My son did the install, was told he did nothing to void the factory warranty. Thanks guys!
Old 02-22-2008, 04:54 PM   #6 (permalink)
Your truck went through regen, which is when the computer elevates exhaust temps to clear the Diesel Particulate Filter (DPF) of the soot it collects from the exhaust. If you don't know what that is, it's not your fault, but your dealer is in the same class as the mechanic. Look over your diesel supplement to your owner's manual carefully. It should explain what regen (or regeneration) is, and how to drive to allow your engine to complete its cycle.
torino73 is offline
Old 02-22-2008, 07:29 PM   #7 (permalink)
So..... this is "normal"? Was never informed, Thank you so much for the info.
Old 02-22-2008, 09:53 PM   #8 (permalink)
I thought the white smoke during regen is caused from an excess amount of soot build up....which i don't know how you could have that since you don't tow with it but i wouldn't really worry about it much...all of the 08 lose power and suck fuel during regeneration mode....and i get a regen every 1000miles
08PowerStroke08 is offline
Old 02-22-2008, 10:12 PM   #9 (permalink)
Why would the fact that he does not tow with it make the pdf not clog up? IMO it would be just the opposite. If you tow with it regularly the exhaust temps would be higher therefore less unburnt fuel in the pdf.
JOHNNYWEB is offline
Old 02-23-2008, 08:32 AM   #10 (permalink)
skidmarks's Avatar
I'd bet almost anything that your truck is regening alot more often than every 1000 miles.
2008 F-350 Loaded Lariat 4x4 CC DRW 4:10's Auto 6.4 Pearl Blue and silver
skidmarks is offline
Old 02-23-2008, 12:41 PM   #11 (permalink)
Stymie's Avatar
The white smoke during regen is usually when the truck is not up to operating temps yet. My truck has regened way more than twice, but only two times have i had the cloud of smoke.
2008 Ford F-250 CC SB
6" Stage II Pro Comp Lift
17x9 Pro Comp 7189
37x12.5 Pro Comp Xtreme Mud Terrains
Try the SEARCH Button
Stymie is offline
Old 02-23-2008, 07:11 PM   #12 (permalink)
If this is normal... then would you suggest I still take it to the garage? Trust me when I tell you the mechanic is less that desireable. In fact 2 years ago he was a guard at the prison... I know you may think I am full of it but I just dont trust him, Tucson is 75 miles away and would be a hassle. I am greatful for the info!!
If this is normal, then I will just deal with it, if it is unusual I will take it in. Thanks again! Joan
Old 02-24-2008, 03:20 AM   #13 (permalink)
Stymie's Avatar
i took mine to the shop the first time. they printed off the tsb for the concern and showed it to me. all the symptoms matched what i was see, and i was satisified. I personally would just call and cancel
17x9 Pro Comp 7189
Stymie is offline
Old 02-25-2008, 11:34 PM   #14 (permalink)
About how often do they regen for? also how long do they regen for, is it a set amount of time or does it change every time?
Boycea is offline
Old 02-26-2008, 07:44 AM   #15 (permalink)
Seapig53's Avatar
Holy Cow Stymie, my Walla Walla neighbor!!!!
Mine did the EXACT same thing. It was almost like it needed a really good belch.
But my regens did go down afterwards and MPG's went up.
How odd.
~Mike~
2008 F-450 CC Lariat...Plus moon roof
Seapig53 is offline
Locate Ford Dealerships to find a new Ford
