2008 F450-6.4L Rated at 325 HP and 600 Torque - Page 2 - Diesel Forum - TheDieselStop.com
post #16 of 39 (permalink) Old 11-14-2006, 09:42 AM
Re: 2008 F450-6.4L Rated at 325 HP and 600 Torque
As a user(18500 lb fifth wheel RV) Could someone please explain the rationale for doing this. How does this effect my hauling experience. I spend a lot of time in the mountains going over the rockies on 70 for example with long 6,7 percent grades. my 99.5 7.3 even modded doesn't like doing that very much. Especially the R400 which required rebuilding when I got home
Would the 350 with 350,650 be a better choice. I would be right on the max 26000 cgwr in that case. to me the 450 gives me greater margin for error, but also seems like the increased horsepower and lighter truck would result in a better pulling experience. I have electric actuated hydraulic brakes which are known to work with the tow command. I thought I knew what to do but now I am more confused. So, what say you gurus about my choices.
7.3 99.5 550 Lariat Fontaine conversion, auto leveling airbags, auxillary transferflow midship tank, fiberglass bed,liner, 25K pullrite hitch, Diesel Innovations six way chip,pillar gauges, 4 inch exhaust. SOLD
08 f-450 4X4 LARIAT 4.88 Dark Shadow Gray to match my Mobile Suites fiver. Line-x, 0503 Pullrite 25.5k superfifth hitch, Retrax rollcover, 50 gal transferflow under cover aux tank, aftermarket pioneer avicz2 nav to come, SOLD
2013 F350 Lariat, camper package, Sterling Gray, firestone air bags, Bigfoot slide in camper, 5th wheel parked for awhile
larryhutto is offline
post #17 of 39 (permalink) Old 11-14-2006, 02:15 PM
I say go with the F450...your towing experience would more likely be much better with a little bit of a margin (not to mention safer). The heavier truck will actually give you a better towing experience. Ford has rated it to tow more for a reason. The number of HP and torque are not the only deciding factors when towing. You have to take into account stopping ability, gears, frame size, etc., etc.
I would consider Ford the guru here, not us armchair diesel engineers. That's just my opinion though.
fordmantpw is offline
post #18 of 39 (permalink) Old 11-15-2006, 06:52 AM
My 06 F550 at work with 4.88's runs only 55 mph at 2000 RPM. Cruising at 70 mph its turning around 2500 RPM.
2005 F-350 SRW, Lariat, 156" WB, 4x4, auto, True Blue, 96k miles, stock.
Canyonero02 is offline
post #19 of 39 (permalink) Old 11-15-2006, 08:25 AM
I understand about the margin and I am inclined to get the 450.
But, I continue to wonder. I now have the F550 fontaine(4.88) which with hitch and all weighes in at about 10000 lbs. the 5ER weighs 18200 loaded. So, I am at 28200 lbs which is 2200 lbs over the 26000 GCWR. The new 350 with the 6.4 (4.30)would weigh in around 25500 loaded almost 3000 lbs lighter and with evidently more HP and Torque, and probably better fuel mileage than the 4.88. The old 7.3 did a good job but the transmission has been a weak point. So now there would be the better tranny as well, so it seems like no so easy an answer. I would appreciate anymore thoughts that may be out there.
Is the reduced HP and Torque perhaps because you are always running higher RPMs due to the 4.88 rearend?
Larry
post #20 of 39 (permalink) Old 11-15-2006, 09:05 AM
I am in the same situation as larry5thwheel. I have a 2001, F550,
Fontaine, the transmission is definately the weak link. I am on my third transmission, 2nd torque converter, with only 71000 miles on it. I am looking forward to a new tow vehicle. The question is more power F350. Maybe more reliabilty and safety F450. When I first saw the specks I thought that would be great. Now maybe I should have bought a 2007.
boatingbob is offline
post #21 of 39 (permalink) Old 11-15-2006, 11:11 AM
CaptSkup's Avatar
I really need a truck that can tow more weight than my current truck. Our fifth wheel weighs easily 22,000lbs with a pin weight of probably 5,000lbs. I have been holding out for the 08's(really like the new interior) and thought that the F-450 pickup would be all I needed. Now I have found out that the pickup will not be the same truck as the F-450 cab/chassis and the engine is detuned. Well, I guess I am back to square one. I guess only the F-550 heavy tow will be enough truck for our needs. I am not worried so much about the lowered power output or the speed limiter, but the GVWR of the F-450 pickup is it's downfall for me. Is this truck just a upgraded 350 or is it truely a 450 cab/chassis with a factory bed installed?
2008 F-450 Lariat Dark Stone Metallic over Pueblo Gold 4x4(manual shift transfer case, manual hubs), High capacity tow 4:88s, Off Road, Camper packages, Sirius Sat, Upfitter switches, DVD entertainment, tailgate step, traction control, Audiophile 6-disc, PTC Supplemental heat and heated seats(warm buns), rear sensors, traction control, tailgate step. Built May 8, delivered May 24
Reese Signature Series 24k fiver hitch, I installed it myself, best hitch I have found yet
Line-X bedliner, heavy duty floor mats
2003 Sunline F281SR(weekend getaways)
Sea Ray 240 Sundeck
CaptSkup is offline
post #22 of 39 (permalink) Old 11-15-2006, 11:24 AM
JESSE 1's Avatar
My Photos: (19)
I believe SmokeyWren reported that the framerails were the same width apart as the F-350. The F-450 pickup would benefit from the bigger brakes w/19.5" wheels and higher capacity axles. Otherwise it's probably the same as an F-350 Tow Boss. I think I would consider an F-450 Chassis Cab with a tow body. No doubt it will also have the reduced hp/tq ratings but have a higher GVWR.
'15 F-450 King Ranch
JESSE 1 is offline
post #23 of 39 (permalink) Old 11-15-2006, 03:05 PM
RVrs R US's Avatar
Send a message via AIM to RVrs R US
And we are in the same situation. Have a 99.5 F-450 w/Fontaine bed rated 26,000# GCWR. Truck weighs 9600#'s and Travel Supreme weighs 20,000#'s for a total just shy of 30,000#.
I'm looking at the possibility of moving to the 2008 F-450 Pickup. Look at the 2008 Super Duty Order Guides The F-450 Pickup is available with the heavy duty tow package which churns out 33,000# GCWR.
Waiting to see the specs so I can check out the height of the pickup bed side rails and determine what height 5th wheel hitch I need to keep the fiver level and give me adequate clearance.
Dave
2008
F-450 6.4L LARIAT 4X2 DRW CREWCAB, JOB 2 BUILD (10/22/07), X-Plan, White/Silver w/Chrome Package, Gray Leather Interior, Torqshift Tranny, 4.88, 33K Tow Package, Sirius Sat Radio w/Audiophile, Supp. Htr, Rear Video Camera, Traction Control - DEALER INSTALLED OPTIONS Line-X Bedliner, Advance Folding Tonneau Cover, Chrome Bugshield, Dually Splash Guards, Remote Start.
2003 40' TRAVEL SUPREME Triple Slide Fifth Wheel - (OUR COW - Condo On Wheels)
Retired Fulltime RVers "Goin' Places, Makin' Friends, Havin' Fun!"
RVrs R US is offline
post #24 of 39 (permalink) Old 11-15-2006, 03:20 PM
I am sure that the power reduction is done via software. Just give some of the tuners a little time and they will be blowing that little difference away. Or even better just have the dealer flash your 450 with a 350 program(if you have a good dealer).
99.5 F-350 4X4 reg. cab flatbed dually 6spd., Tunes by MCN diesel, Wicked Wheel, dieselsite brv, HX mod, LUK clutch upgrade, Dipricol pyro,boost,fuel. Tymar intake, CCV mod.
2000 F-250 crew cab auto 4X4. Traded on 5-8-07 because of crappy trans for:
2007 Dodge 5.9 cummins 4x4 6-spd. CC dually
1987 F-250 6.9 IDI, Old Smokey
phale is offline
post #25 of 39 (permalink) Old 11-24-2006, 10:10 AM
For all you wondering about whether or whether not this new body model F-450 has the chassis of the current 350 or the chassis of the current 450 model. As a Ford technician at a dealership in the metro atlanta area, I can tell you that the F-250, 350, 450, and even the 550 all have the exact same chassis, engine, steering box, and transmission. The difference lies in the front and rear axles, the F450 and F550 of current (or past) relies on a much larger rear axle with the F550 being much heavier than all. But folks, the heart of this matter is that the Ford super duty is so far superior in its absolutely industrial build, that this new 450 will dominate as its predecessor has. Sorry, duramax lovers, but I am not convinced in a diesel with an aluminum block and heads, yeah its quieter, less dense metals compose the duramax, for the long haul, and the rock solid suspension and axle setup, you cannot beat that solid Dana 60 under your front end. Ford knows what they are doing when it comes to trucks, and yeah, that 6.0 was a slip up, but they realized it... believe me, I have seen my share of 6.0 problems. But I have faith in this new 6.4l
fernando8150 is offline
post #26 of 39 (permalink) Old 11-24-2006, 02:36 PM
I thought the 450/550 have a different width frame rail set-up for body upfitters.
IBUILD is offline
post #27 of 39 (permalink) Old 11-24-2006, 04:15 PM
Parts Jimmy's Avatar
I hate to dissappoint you BUT the 250-550 cab and chassis have a narrower frame than the trucks that have beds on them. The cab and chassis models also have a flat frame rail to accomidate commercial add-on bodies. They do have for the most part the same axles steering and so-forth but the frames are definetly different.The C&C 250-350 SRW share frames which are not the same as the C&C 450-550 which also share frames. The dually C&C F350 is all alone. The pickups have a wider frame. I don't know about the 08 F450 pickup yet. Its not in the current parts catalog. I sell frames on a regular basis at a Ford Dealership. I have been selling parts for 22 years. The frames are not all the same per the parts catalog that I sit in front of right now. Don't believe me? Get your tape measure out. [img]/ubbthreads/images/graemlins/wink.gif[/img]
7.3 Power Stroke Diesel, 4R100, 4" MBRP Exhaust, Ford AIC, Motorcraft Air Induction System,
DP-Tuned, AIH Deleted, EBPV Deleted, Bellowed Up-Pipes, Dieselsite Coolant Filter, Bilstein 5100 Shocks, Timbren Overloads, Husky Mudflaps, Hella 700FF Driving Lights, Autometer Gauges
Parts Jimmy is offline
post #28 of 39 (permalink) Old 11-26-2006, 08:00 AM
Jonboy -if your a tech you should know that the Duramax has a cast iron block--only the heads are aluminum
Stock -- 2004 F350, Oxford White, 4WD, Torqshift Auto, Short Bed, Crewcab,6.0 PSD, Dual Alts., TT Mirrors, Lariat,Parchment Int.,Kenwood Stero w/ XM Satellite Radio, Custom full length running boards, Handy Tool/Fuel, Ultimat, Banks Gauges & A-Pillar, ,Fumoto Valve with Nipple [Ham (KC7QJZ), ---- pullin a 30' Starwood 5er at 10.5K (and often with a 2.5K tandem trailer with GYRO or ATV's ,OR ,a 2006 Jeep Rubicon Unlimited.
Mike Schallmann is offline
post #29 of 39 (permalink) Old 11-27-2006, 12:03 AM
rednck21's Avatar
As a Ford technician at a dealership in the metro atlanta area...
Which dealership?
2000 F-250, reg. cab, 4x4, XLT, 7.3, built 6/00-forged rods!, DP Tuner F5, AFE stg. 2, MBRP 4", Autometer Ultralight boost/pyro/trans temp gauges, 285 BFG's
2011 F-150, 2wd, XLT, Ecoboost
rednck21 is offline
post #30 of 39 (permalink) Old 01-18-2007, 11:00 PM
My Photos: (20)
It is 100% true, the F450 & F550 trucks will only be 325/600. Top speed of the F450 Pickup will be 81 mph
That might have been true on 11/12/2006 in the Preview Guide but I have only seen the 350HP 650TQ rating on every Ford website and order guide for 2008 F450/F550 6.4L PSD's this month.
Ford Fleet F550 specs
media.ford.com F450 specs
Ford F450 PU Order Guide
Kawasaki ZX-11
jogiba is offline
  Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 6.4L Power Stroke Engine and Drivetrain
